Results 1 to 12 of 12
Thread: Could It Be My Left Side Cat Is Toast?
    Aug 2008
    Hesperia, CA
    2001 740 i Sport
    Multi cylinder misfires with fuel cutoff plus the o2 front sensor code p0153...p1341, p1357, p1355, yesterday it was p0306 now it's p1353 5-8 with coil pack and spark plug swap from L side to R side and I get the same results even after clearing codes. I should've gotten something correct by accident right?.... new intake gaskets and OEM OSV and no air leaks can be detected.
    Sent from my LGLS676 using Tapatalk
    [/IMG]
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Could well be - remove the Lambda sensors (physically) and see if that makes a difference - also, a garage can measure the back-pressure at the sensor apertures - more info here:
    http://www.meeknet.co.uk/e31/E31_840...l_Throttle.htm
    My BMW Repair YouTube Channel
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    I thought the problem cats on a TU engine were the ones in the manifolds? Would pulling the O2 sensors in this case only diagnose the secondary cat?
    I’m having similar codes and figured it was these manifold cats. If there was a good way to test this I’d be pretty pleased.
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
    Aug 2008
    Hesperia, CA
    2001 740 i Sport
    OK I'll do that tomorrow. Thanks for the link it shows the same symptoms I'm encountering
    [/IMG]
    Aug 2008
    Hesperia, CA
    2001 740 i Sport
    If it turns out to be that cat, I'm screwed. I just moved to Cali. I've read about the smog emissions here are SUPER strict...
    [/IMG]
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Quote Originally Posted by clarkitect View Post
    The Lambda sensors are in front (upstream) of both cats.....
    Dec 2011
    Lancaster CA
    e34,e38,e39,e46,e70,e90
    Quote Originally Posted by 4liter View Post
    No, just replace cats with CA compliant ones and you’ll be fine. I think the Flowmaster ones at Autozone are about $200 each. Have a muffler shop weld them in and you’re good to go.
    Mar 2012
    Queensland, Australia
    1995 730iL (M60B30)
    Don't sweat it, there are aftermarket cats that aren't too pricey that have worked just fine for members in the past with California emissions requirements. Worry about successfully diagnosing the issue first - we can help you get the right part once you work out exactly what you need
    Aug 2008
    Hesperia, CA
    2001 740 i Sport
    Quote Originally Posted by kouks View Post
    Those cats are generally under the car for $200. The one in question go for $800-$1000. Those are on the exhaust manifold. Do they chop, weld and pass here?
    [/IMG]
    Rutland, Vermont
    Thanks! I should have studied the RealOEM diagram more I guess!
    I was going to pick up used low mileage pair of cat/manifolds.
    Aug 2008
    Hesperia, CA
    2001 740 i Sport
    Well I've tried to break down the exhaust system to clear out the debris in the cats and noticed that from the manifold, it comes out as a whole and not in sections. The pipe won't come out because the rear is connected so, I can't get to manifold cat. I don't have the space (jack not strong enough to lift higher on to jack stands) to do it...nor do I have a pry bar long enough to break up the material even if I could get the rear cat off. If anyone has removed the exhaust, please chime in. I may be doing something wrong...
    [/IMG]
    Aug 2008
    Hesperia, CA
    2001 740 i Sport
    Ahhh skip it...I'm going to check in with a local muffler shop Monday.
    [/IMG]
  1. Could it be my VANOS??
    By IAmChad in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-17-2012, 11:49 PM
  2. Could it be my ICV or MAF? Seriously, advice please!
    By eman67 in forum 1996 - 2003 (E39)
    Last Post: 01-01-2009, 06:56 PM
  3. Could it be my E46 bearings??
    By copepod in forum 1999 - 2006 (E46)
    Last Post: 05-04-2008, 02:34 PM
  4. Could it be my VANOS is bad?
    By goobos101 in forum Middle Atlantic - US
    Last Post: 03-23-2006, 09:35 AM
  5. Could it be my amp?
    By Luftwaffe1O1 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 06-23-2004, 07:14 PM
