Results 1 to 3 of 3
Thread: Does not start after project
    Jan 2018
    Finland
    Bmw e30 320i 1990
    I have a e30 320i 1990 project build and i havent done any changes to the engine other than changed the exhaust manifold and now it dosent want to start good and when it’s started it dosent want to hold on idle. What can be the problem? I have taken the intake manifold off for painted but i’ ve put it back correctly. Can there be any air leaks or is it something wrong with the fuel system?
    Nov 2009
    Des Moines, IA
    90 ix, 91 i & ic, 02 325
    Broad question - could be anything - may not be related with the work you did at all- or it could be.
    Check all electrical connections and then make sure you have no vacuum leaks (sounds like a vacuum leak).
    Was the intake manifold gasket new?
    Jan 2018
    Finland
    Bmw e30 320i 1990
    Yes i’ve changed the intake gasket but i should check if there’s any leaks and if all the connections is conected
  1. Car does not start after NCS update in GM5 module.
    By pankracy in forum 1999 - 2006 (E46)
    Last Post: 12-30-2017, 08:57 AM
  2. Car does not start after replacing starter
    By elton123 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 10-16-2016, 01:48 PM
  3. Replies: 12
    Last Post: 08-22-2006, 11:48 PM
  4. 318is does not start after driving it has been driven a while
    By Mooobunnny in forum 1991 - 1999 (E36)
    Last Post: 09-19-2005, 09:44 PM
  5. e 34 engines turns but does not start after use
    By ebantegui in forum 1976 - 1989 (E24)
    Last Post: 09-28-2004, 09:14 AM
