Results 1 to 7 of 7
Thread: Battery/start issue
    May 2012
    houston TX
    99 BMW M Roadster
    Battery/start issue
    2008 x3 3.0 getting ready to take car to dealer to work on some oil leaks valve cover presumably and transmission pan. Showing son how to change wipers. Battery goes dead on us. Jump start. no response. Charge battery. No response. Charge battery seemingly full after 5 hours with cables disconnected and now nothing. lights etc all come on but no sign of cranking life. is there a reset or security code need possible? frustrating! I suspect I need a new battery as it has been slow to crank but seems it should start off a jump start or a full charge from a decent battery charger. Thoughts?
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    If the battery is more than 4-5 yrs old it's probably toast. Have it load tested. Check all cables and clean with a wire brush. Otherwise maybe a key transponder issue.
    May 2012
    houston TX
    99 BMW M Roadster
    don't think its key as both keys have same outcome.
    Lansdale, PA
    00 M '96 Z3
    My X3 did the same thing. It ended up being the starter. Have it tested before spending $200+ on a battery.
    2011 Z4
    2010 MB GLK 350
    2000 M Roady
    1998 Lincoln Mark VIII LSC
    1996 Z3
    Feb 2010
    Portlnd OR
    1995 325i
    Quote Originally Posted by Tazmanian Devil View Post
    +1. Same thing on mine
    Oct 2007
    Middle TN
    Too many/Not enough
    Sounds like the same symptoms I had when my starter went out. It's worth a try to give the starter a rap with something to see if it starts afterward. I was able to give mine a hit from underneath using an 18" breaker bar.
    Current Garage:
    91 e34 M5 - spoiled & demanding 27 y/o -glanzshwarz
    91 850i/6 -another spoiled & demanding 27 y/o- schwarz-gone but never forgotten
    06 325i - undeserving, spoiled & demanding 27 y/o daughter's DD-hellrot
    03 MINI Cooper S JCW -spoiled & demanding, yet deserving wife's DD - Chili/Panther
    05 X3 3.0i -family workhorse - diamond schwarz
    12 X5 3.5d - torque monster - space gray metallic
    86 GMC Cabellero - Old Faithful 32 y/o DD BMW Support Vehicle
    08 Cub Cadet 19HP 46" hydrostatic- yard vehicle
    88 Schwinn Sierra - 1WD Off Road Vehicle
    e31 & OHC BMW CCA #385540
    Tampa, FL
    '06 BMW X3
    Only other thing could be bad ground straps
  1. Replies: 17
    Last Post: 03-06-2019, 06:32 PM
  2. Help with battery - start issue
    By redcobra407 in forum 2004-2010 (E60,E61)
    Last Post: 04-03-2017, 04:43 PM
  3. Odd 540i no start issue: not battery or starter related
    By kmoy2002 in forum 1996 - 2003 (E39)
    Last Post: 08-25-2009, 12:48 AM
  4. Starting issue; something draining the battery?
    By nowbimmin in forum 1991 - 1999 (E36)
    Last Post: 01-20-2009, 10:13 PM
  5. Battery/Alternator/Starting issues?
    By Number40 in forum 2004-2010 (E60,E61)
    Last Post: 06-10-2008, 09:08 AM
