Results 1 to 13 of 13
Thread: Leaking coolant from intake manifold
    Jul 2015
    Los Angeles, CA
    98 E36 M3 Vert,82 E21 iS
    I have a '82 E21 and there is a coolant leak from under the intake manifold that seemed to be coming from a hose. When I removed the hose, the metal piece that comes out of the intake manifold came out with it and it is corroded. I called Pelican and the metal piece that comes out of the intake manifold cannot be purchased on its own and I would either have to find another intake manifold or either have the piece machined or find a welder.
    Does anyone have any suggestions regarding this?
    Thank you
    Jun 2012
    Savannah, GA
    83 320i 00 540i6 85 535i
    The only coolant pipe I know of under the manifold is #14- http://www.realoem.com/bmw/enUS/show...diagId=11_0644
    It runs front to back and I had to replace mine as well due to corrosion. Easily obtainable though.
    If that is not what you are referring to, can you locate it on REALOEM and provide a visual?
    Jul 2015
    Los Angeles, CA
    Quote Originally Posted by Bonsaibacker View Post
    I can't find a good image and I'm not with the car at the moment but please refer to:
    http://www.realoem.com/bmw/enUS/show...diagId=11_0831
    The hose is directly attached to the intake manifold and comes out at the bottom. Based on the schematic I just posted, is there a hose that goes to #3 or #4?
    Jul 2010
    San Jose, California
    E21 320i, E30 325i
    Quote Originally Posted by Bimmersaurus View Post
    I believe #3 and #4 are studs that are used to attach the #22 arm using the #14 and #15 nuts and washers.
    Maybe you're looking at #9 which caps a vacuum port on the intake (red cap in the second picture)?
    Or could it be the throttle assembly that has some cooling hoses going to it? http://www.realoem.com/bmw/enUS/show...diagId=13_0159
    Can you point it out in one of these pictures?
    '81 E21 320i / '90 E30 325i / '̶9̶2̶ ̶E̶3̶4̶ ̶5̶2̶5̶i̶t (sold) / '15 Toyota XW30 / '̶̶8̶0̶ ̶E̶2̶1̶ ̶3̶2̶0̶i̶A̶ (sold)
    Jul 2015
    Los Angeles, CA
    Quote Originally Posted by amarino View Post
    I believe it's where I circled in the red. I remember the hose has a clamp on it. Do you think I need to find a welder or is there an alternative? Thanks
    Jul 2010
    E21 320i, E30 325i
    I'm pretty sure that is used to heat up the throttle body in colder climates. In LA you shouldn't really need it.
    • You can try to find another throttle body and just swap it out
    • Find a welder to put a new barbed fitting in
    • Drill a tap a new barbed fitting in
    • Just bypass the throttle body entirely by connecting the two hoses together. (probably the cheapest and best solution)
    Jul 2015
    Los Angeles, CA
    @amarino thanks for the reply. I'll think about what to do. Hopefully the car can be on the road again soon.
    Pioneer, CA
    73' tii 79 320i 73'2002
    Yeh bypass the coolant lines with a hose, it will make your intake air cooler. Just ran a new section of hose form the supply off the water pump tee straight back to the block. It is designed to keep the intake from icing up in very cold climates. (below zero F)
    Sep 2015
    North Carolina, USA
    1981 BMW 320i
    Amarino you got it I had to replace mine about a month ago.
    Looks like Realoem listed it as #18 (vent hose) runs from the hard line to under the intake manifold.
    It's a real PITA to replace, especially with the awkward position under the manifold, I'd suggest using a long screwdriver for the hose clamps and a magnetic tool grabber for if you lose the screwdriver or hose clamps under the manifold.
    Mar 2017
    Boston, MA, USA
    '81 E21,'14 F30,'17 F87
    Hi
    Do you know the part numbers for the coolant hoses under the intake manifold from the picture you sent?
    I need to replace the one that goes from the intake manifold to the steel pipe right before the water pump.
    Thank you so much in advance
    Eli
    Corona California
    79 320/6 81320i 65malibu
    I have run my 80 e21 for 28 years with the hoses not connected to the TB. Personally I think in the summer it is a smart idea cooler air and fuel make for better running car. Put plugs on the tube and pipe where the hose start on the block.
    Always FUN TO DRIVE - Build Thread & Tech info - 79 320/6 track car build thread -- Videos of track car -Adam in car Auto-x video - Start-up video - 4/2011 Adam's TOP BMW time San Diego BMWCCA - 4-5-15 Dyno break-in run new M20B25 - Exhaust Thread - Link
    Mar 2017
    Boston, MA, USA
    I am planning to drive it in the winter on cold dry days (before snow and after snow season) will this affect it? In any case, do you know what the part number is for this or what are the hose dimension? Thank you for your help again
    Eli
    Pioneer, CA
    If it was so cold out that the air temperature adversely affected the engine, you wouldnt want to drive the car, anyway.
    I think it's 3/8" coolant hose. buy a few feet at your local parts store.
  1. M3 Coolant leak under the intake manifold
    By emericanmilitia in forum 1992 - 1999 M3 (E36)
    Last Post: 11-13-2013, 08:24 PM
  2. Could P0011 error be from intake manifold leaks?
    By supark in forum 1996 - 2003 (E39)
    Last Post: 02-16-2009, 03:39 AM
  3. Coolant leak visible under intake manifold
    By jcumba in forum 1995 - 2001 (E38)
    Last Post: 04-08-2006, 01:51 AM
  4. Quick Question: Disconnecting PCV from Intake Manifold
    By toddman35 in forum 1991 - 1999 (E36)
    Last Post: 10-27-2004, 08:54 PM
  5. help... clicking/tapping sound from intake manifold area.
    By shhuang in forum 1991 - 1999 (E36)
    Last Post: 04-06-2004, 02:24 PM
