Results 1 to 7 of 7
Thread: Replacement side view mirrors
    Jul 2016
    San Diego
    1998 E38 750iL
    I'm looking at replacing the side view mirrors on my prefacelift 750iL. My current ones are the normal non-dimming version, but heated as all USA cars were.
    There are piles of replacement mirrors on eBay, both new and used, but most of them look to have 4 mounting clips on the back:
    But I've only seen that style referenced for E39 installation. Any E38 installation has referenced the version with a ring on the back:
    The latter would appear to be incompatible with the former. So which is correct?
    Jul 2016
    San Diego
    1998 E38 750iL
    I wonder if I've answered my own question. RealOEM lists part number 51168209809 for the heated and auto-dimming mirror (left), which FCP Euro shows with the ring (and 4 wires) on the back. https://www.fcpeuro.com/products/bmw...ex-51168209809
    But RealOEM lists 51168165109 for the heated but non-auto-dimming versions, which don't have the ring on the back and no sealed black border. https://www.fcpeuro.com/products/bmw...ne-51168165109
    So I think I'm just going to order the latter and see how it turns out. Happy to hear if anyone else has confirmed this.
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    You're correct...the regular glass heated mirror glass for the e38 uses the same set-up as the e39 and older e34...they all just pop on/off.
    If you have the auto dip/dim mirrors...then you have the small bayonet at the bottom that releases the mirror from the housing...as well as the thicker black band around the circumference of the mirror glass.
    Have you decoded your VIN to see if you have the auto dip/dim side mirrors?
    Below are images of my heated (NON dimming) e38 mirror glass:
    {e34 regular heated mirror...same design...different color motor...but mirror mounts the same}
    {e38 regular driver/pass heated mirror glass below(no thick black band around circumference}
    {rear}
    [front}
    {rear side of auto dim/dip mirror...has the bayonet on the lower side}
    Jul 2016
    San Diego
    1998 E38 750iL
    Quote Originally Posted by Qsilver7 View Post
    Thanks. I wish they hadn't called them auto "dip" mirrors. I don't have the auto-dimming side mirrors, but I do have the "other" dip function that pivots the passenger mirror down when reversing. So mine are like your first set, without the thick black band around the outside.
    I ordered a set like them - a Euro-style driver's aspherical/blind spot mirror, and an USA-style passenger side (with "OBJECTS ARE CLOSER..." text).
    (northeast) Indiana
    Great...I really appreciate the aspherical/wide angle mirrors. I wish the USA would mandate them.
    BMW's use of "auto dip" has long been a strange interpretation of the electrochromatic auto-dimming mirrors. But I think it goes back to when BMW actually had mirrors that physically moved when headlights from behind shined on the little "eye". Those mirrors failed miserably (back in the late 80s/early 90s)...and were replaced with the type of EC mirrors that we have today....but "auto-dip" seems to remain in the BMW vernacular in regards to auto dimming mirrors. Auto-dazzle is another term that I've seen.
    The passenger side feature where the mirror "moves" when the transmission lever is moved into REVERSE...is called/referred to as..."tilt"...not "dip" when you run across the feature in BMW documents.
    Jul 2016
    San Diego
    1998 E38 750iL
    Nice. Thanks!
    Sent from my XT1575 using Tapatalk
    Mar 2011
    England
    750iL; 330Ci cab; 5GT
    In the very last image from Q, be careful in operating that little lever in the red box as it can break off, if pushed the wrong way.
  1. Replacing side view mirror on E46 2001 330Ci
    By woodrodius in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-17-2015, 10:06 PM
  2. Need help replacing side view mirror memory drive
    By Ripped4rce in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-03-2008, 10:20 PM
  3. Side View Mirror Replacement
    By iwantbmwm3 in forum 1991 - 1999 (E36)
    Last Post: 05-03-2008, 01:00 AM
  4. replacement side view mirror?
    By featherpillow in forum 1996 - 2003 (E39)
    Last Post: 11-11-2006, 05:28 PM
  5. Side view mirror glass replacement
    By crewdog843 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-06-2005, 01:55 PM
