Results 1 to 13 of 13
Thread: Is the LCM IV Really That Beneficial?
    Sep 2016
    Phoenix
    E46 E39
    Going into a facelift E39?
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Depends on what you want. Do you just want the car to work same as it always has? Then no, its zero beneficial.
    Only benefit is having a little more control over parameters to run LED and/or other custom lights in the car.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Sep 2016
    Phoenix
    E46 E39
    What controls are these?
    Mar 2010
    If you have to ask you don't need them.
    2003 M3CicM6 TiAg
    Former:
    Dec 2009
    Annapolis, MD, USA
    2012 JSW 2.5
    +1 You don't need to upgrade your LCM until you add a feature to your car that it does not support but is supported on a newer LCM version.
    In my case, I replaced my LCM IIIA with a LCM IIIB to get the facelift tails on my pre-facelift touring configured. A LCM IV would have also done the job but for a higher price.
    [IMG][/IMG]
    Sep 2016
    Phoenix
    E46 E39
    I have the chance of picking one up for $20. I have read somewhere, sometime ago, that LCM IV would give me the option to have my angel eyes work as my DRL. That would be a nice feature.
    Philadelphia, PA
    2005 M3 & 2004 330i
    Quote Originally Posted by M5XTu View Post
    IF that is a possible feature, I couldn't figure out how to do it when I retrofitted an LCM IV to my friend's E39.
    Nov 2010
    Charlotte, NC
    03 M5/05 RR/06 Cayman S
    Quote Originally Posted by TerraPhantm View Post
    Nope, it's not a feature of the LCM IV. You need to use a separate circuit board wired up to do it. I made a design for one, but it works with any LCM that is currently in the car (assuming LCMIIIa or LCMIIIb if it's got angel eyes).
    -Paul
    2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers,
    Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread
    2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    LCM IV can enable factory-style bi-xenon integration, and LED turn signals w/out the need for resistors, IIRC. As I understand it, those are its best features.
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
    Dec 2009
    Annapolis, MD, USA
    2012 JSW 2.5
    I made my Angel Eyes behave like DRLs by using a wiring harness with a relay triggered by a wire that is hot when the key is turned. Then I installed 18w LEDs in each one so they are bright enough to be seen on sunny days.
    Google search: angel eye harness
    May 2014
    Los Gatos, CA
    05 330i
    Are these the facelift angel eyes?
    05 330i Alpine White
    Past:
    02 330i Titanium Silver
    R56 MCS
    00 540i6
    Los Gatos CA
    1987 325is, e34, Z3, e39
    On somewhat related note, I recently had one angle eye lamp burn out on my MY2002 e39 with xenon headlight.
    The assembly is a special part. It is listed at $35+ from BMW, which means that the local dealers will charge $50+. I couldn't find one during a quick pass at the boneyard, so I ordered a pair of LED replacements.
    After they arrived I took apart the original failed lamp assembly by breaking the two melted together points. Inside I found a standard bayonet base halogen bulb. It was marked Philips 120?? 12V 10W. This matches a 64113, which is a 10W/12V halogen with Ba9S base. These are used in various models as indicator and map lights. Doh! I could have easily found one of those at the boneyard, or even a parts store.
    The LED modules were fairly hefty, with a reasonable aluminum heat sink. I put them on the bench supply to check them out. They lit at 6.2V and were at full brightness by 6.6V. I measured them as drawing 300mA at 10.0V and 200mA at 15.0V, so they are 3 watt modules. That's less than half the 7 watt claimed power. I'm tempted to leave a negative review, but probably won't because they are significantly brighter than the originals and emit a white light without blue or purple spots. Still, they wouldn't be suitable as DRLs.
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    I used the Chip-on-board LED angel eyes when I rebuilt my headlight. They are far brighter than any LED bulb for the factory fiber-optic angel eyes that I have seen.
    Nate J.
  1. Is the 1988 750il really that bad ?
    By I hump my M3 in forum 1988 - 1994 (E32)
    Last Post: 09-24-2008, 12:22 PM
  2. Is the Shark upgrade really that good?
    By M3in in forum 1991 - 1999 (E36)
    Last Post: 09-11-2008, 05:33 AM
  3. What is the largest size speaker that will fit in the front kick panels?
    By Cobra Jet in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 08-11-2002, 09:17 AM
  4. Replies: 5
    Last Post: 08-07-2002, 12:23 PM
