Results 1 to 3 of 3
Thread: Passenger Side Headlight Not Working After Battery Drainage
    Jul 2010
    Irvine, CA
    1995 BMW M3
    Recently, I had a body shop repair my car and over the time they had the car, the battery got drained for some reason and I experienced a few electrical issues afterwards (outside temp not reading, trunk not opening, etc). Now everything is solved but the passenger side low beam.
    First I thought it was the bulb but I swapped the bulbs side to side today and the result is the same.
    Where do I start? I would love to fix it but just not sure where to start looking,
    Could it be just a bad battery?
    Thanks,
    Feb 2015
    Atlanta, GA United States
    1994 740iL, 2004 645Ci,
    I am having a similar issue. My passenger-side headlight is out. Not just the actual forward projecting Xenon, but the entire unit. Halo Eyes, high-beams and low-beams are out and the whole corner of the car is dark at night minus the right blinker should I activate the turn signal switch motioning a right turn. The fog lights operate normally. Very first time I have seen condensation inside of the the headlight assembly too. I am sure it's related but not sure why or how. I have disconnected my negative post for a while to clear the computers, but maybe not for long enough. Got a car wash with undercarriage jet-spray done almost 2 weeks ago but this started yesterday so I don't think that's the reason. Would my alternator be able to short my headlight assembly control unit? If so, would simply replacing the control unit resolve the issue?
    2004 645Ci 6 Speed Manual
    Could it be the need of an alternator and/or battery replacement? The lights worked perfectly until I had a power glitch while driving on a long downhill behind a slow driving Smartphone user who felt it ever so amusing to continuously tap her brakes or purely ride them all together. These big-boy cars don't like SLOW. Coasting now dims my digital display as well... Any suggestions are greatly appreciated ahead of time. Any Indie-Shop here in the Atlanta Metro with a quick-fix... HELP!!!
    Nov 2009
    czech republic
    E 34, E39
    Quote Originally Posted by wutanec View Post
    Thanks,
    check it before charge, most probably yes, weak battery, just use votometer before cranking and after.t o test the charging system,
    Sent from my SLA-L22 using Tapatalk
  1. 1989 735i A/C & passenger side controls not working
    By crakerg in forum 1988 - 1994 (E32)
    Last Post: 06-07-2008, 01:02 AM
  2. Convertible top not working after battery disconnct
    By arenaej in forum Convertible Questions
    Last Post: 04-07-2007, 03:51 PM
  3. passenger side wiper not working
    By Eurogp in forum 1991 - 1999 (E36)
    Last Post: 03-16-2007, 08:17 PM
  4. one xenon headlight not working after washing car
    By supark in forum 1996 - 2003 (E39)
    Last Post: 10-04-2006, 10:39 AM
  5. E34 OBC not working after battery change. Help
    By mihai77 in forum 1988 - 1996 (E34)
    Last Post: 09-30-2005, 03:35 PM
