Results 1 to 5 of 5
Thread: M50 with getrag 240, Help needed!
    Oct 2017
    New Zealand
    BMW E30 316i
    Hey guys, sorry if i have posted in the wrong thread.
    I am needing a bit of help with my m50 swap. I am unsure which driveshaft to use as I will be using the getrag 240 and there doesn't seem to be a whole lot of info around that. I am wanting to know which driveshaft to use, which car it is out of, auto or manual etc. Any help would be much appreciated.
    Cheers
    warwick RI
    E30/E32/F25
    The g240 from an m10 based car will not fit an m50 you’d need a 260 from a m20 base car. The only thing I remember a g240 fitting is an m30. If you use a 260 trans you can use a stock e30 drive shaft (manual) just need to change gears to a 3.73. You can use an e36 transmission but you then need to do a bit more playing with diff and drive line variants, that’s if I remember correctly
    Me E30 87/ 325i + F25 12/ M-Sport + E32 94/ 740i
    G/F’s E34 92/ 525iT + F48 18/ X1
    Oct 2017
    New Zealand
    BMW E30 316i
    Quote Originally Posted by e30luv318i View Post
    Hey man. I have a g240 from an m40 engine, so im not entirely sure if the bellhousings patterns are different or not. I know it has been done before but I dont have a whole lot of info to support it.
    May 2009
    OBXNC
    1988 M3 2001 325ci
    A 240 will work ! I tracked a m50/g240 then a s50/g240 for two seasons.
    Oct 2017
    New Zealand
    BMW E30 316i
    Which clutch and fly did you use with the m50/g240? And also gear linkages
  1. M50 with Getrag 260, which pilot/throwout bearing?
    By RahgBag in forum 1983 - 1991 (E30)
    Last Post: 12-24-2008, 11:17 PM
  2. M50 HG + Camshaft installation help needed in Central, NJ
    By ICatchx22I in forum New York / New Jersey / Connecticut
    Last Post: 07-10-2008, 10:11 PM
  3. m3 flywheel/clutch on m50 with getrag tranny?
    By skiboard06 in forum 1991 - 1999 (E36)
    Last Post: 01-21-2007, 03:27 AM
  4. Anyone With Legal Background? Help Needed!
    By Boston Killer in forum 1995 - 2001 (E38)
    Last Post: 03-21-2006, 02:38 PM
  5. m50 intake manifold install help needed
    By LeMansGTS in forum 1992 - 1999 M3 (E36)
    Last Post: 05-22-2005, 12:07 PM
