Results 1 to 2 of 2
Thread: Driver's seat
    Dec 2017
    sc
    2007 bmw 325
    Driver's seat
    Power driver's seat on 2009 328 i works intermittantly. Works about 5 percent of the time. Swapped out used switch and seat control module but same results.
    Did some initial inspection of wiring under seat but nothing obvious. Any thots?
    May 2017
    Ontario, Canada
    335i E93 N54
    I suggest run wires from the voltage supply on the switch up front, leaving a meter on them while you drive.
    See if the voltage holds steady.
    If it does not, then you chase up stream.
    If it does hold, perform load testing while driving to see if it's a current issue (less likely?).
  1. Frt driver side seat stuck!!
    By wewu in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-28-2002, 08:17 PM
  2. Driver's seat lever
    By Janolaw in forum 1991 - 1999 (E36)
    Last Post: 12-23-2002, 12:07 AM
  3. Driver's seat loose. How to tighten?
    By twentyfourseven in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-24-2002, 10:09 AM
  4. Clunking/sliding drivers side seat fix???
    By KmanM3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-08-2002, 05:26 PM
  5. Driver's seat, Door pin
    By mrdenial in forum 1991 - 1999 (E36)
    Last Post: 01-27-2002, 10:50 PM
