Results 1 to 12 of 12
Thread: Misfiring at several cylinders
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    I have been trying for ages to solve my "additive mixture adaptation..." error with no luck. Used a brake cleaner to try to find a vacuum leak, but nothing happens when spraying it on. But now got some brand new errors about misfiring. Any idea what could be those, are they related somehow to the mixture error? Thx!
    Errors:
    DME* -> 1C/00 - Additive mixture adaptation, bank 1, control limit reached
    1D/00 - Additive mixture adaptation, bank 2, control limit reached
    3E/00 - Misfiring at several cylinders
    32/00 - Misfire detection, cyl. 1
    33/00 - Misfire detection, cyl. 5
    34/00 - Misfire detection, cyl. 4
    39/00 - Misfire detection, cyl. 2
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Misfires that are predominantly on one bank are usually due to the failure of one of the catalytic converters - more info here:
    http://www.meeknet.co.uk/e31/E31_840...l_Throttle.htm
    My BMW Repair YouTube Channel
    Nov 2016
    Hansville, wa
    2001 750il Chrome line
    A simple test may be to unplug the MAF and see if anything changes. I had adaptation limits for months. Even an aftermarket MAF didn't fix it I had to buy a OEM MAF for $400. It was on Timm's advice. It got so bad that I thought at one point it was the transmission.
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Quote Originally Posted by acspecialists View Post
    I have just put in an aftermarket MAF (Bremi), could they be that bad? I mean I had the same error before putting in the new MAF, it just didnt make any change. Somehow doubt an original BMW one would matter.
    Thanks, checking it out!
    Nov 2016
    Hansville, wa
    I know I thought the same thing. I tried three different MAF's with no change, I even tried a VW MK4. Timm recommended an OEM. I bit the bullet and the CEL has been off for months. You can always return it if it doesn't fix the problem. Maybe someone has a used OEM MAF, they might let it go for less than $400?
    Aug 2016
    New jersey
    2001 740i Sport
    I have a used OEM maf if interested
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    You werent kidding, this is really $389 https://www.fcpeuro.com/products/bmw...z8-13621433567
    Would buy it if solve the problem, but not sure if I could return it if not.
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Quote Originally Posted by Njcrackbaby View Post
    Thanks, I'd rather try a new one.
    Bonita Springs, FL
    01 740i, 09 X5, 12 335i
    Quote Originally Posted by georgebest View Post
    oembimmerparts:
    https://www.oembimmerparts.com/BMW-M...1433567e38.htm
    2001 740i Sport - Anthracite Metallic, Gray Interior, 750 Porn Lights, 750 Seat Backs, Hoen Xenon-match Fogs, Crossed drilled, slotted rotors, LED Interior Swap.
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Quote Originally Posted by robo740il View Post
    Is this the same as the genuine BMW? I already have an aftermarket one.
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    I went with a Bosch one erased codes and will make a 200 miles trip over the weekend. Curious if the 'adaptive mixture' error comes back. I can send it back in 90 days if not solving the issue.
    Aug 2008
    Hesperia, CA
    2001 740 i Sport
    These misfires seem to be happening very often lately...Timm pointed me to my cats being worn out...he was right. Good luck and I hope it's nothing seriou$$$.
    [/IMG]
  1. P0301 Cylinder 1 Misfires at random
    By viciouz in forum 1992 - 1999 M3 (E36)
    Last Post: 05-19-2013, 08:41 PM
  2. Cylinder 4 Misfire, at idle in cold weather
    By Kermdaddy in forum 1992 - 1999 M3 (E36)
    Last Post: 02-01-2012, 06:39 PM
  3. P1340 multiple misfires at startup
    By hecubus in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-05-2005, 05:29 PM
  4. E30 Misfire at part load
    By e30gearhead in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-07-2005, 11:30 PM
  5. Car being serviced at dealer, "Cylinder Running Lean".. ??
    By allthewayfive in forum 1995 - 2001 (E38)
    Last Post: 01-23-2004, 12:19 PM
