Results 1 to 5 of 5
Thread: E36 track build in Florida
    Apr 2017
    Florida
    E36
    Good day
    looking for advice on sway bars to purchase ASAP. I am currently running with HOD and PDG and maybe one day compete.
    car was originally my sons 318 that came with the M50 vanos motor.
    i had a blast installing turbo 6 months ago.
    recently installed ZF tranny and 318 lsd diff. Welded in all rear subframe supports and installed M3 rear components.
    6 puck 1 series brakes in front and also installed oil cooler. Also BR coil overs
    i am hopeful to improve cornering before next week, if I can make it.
    on sweeping corners I feel the back end wants to break loose as well as the whole car push/ I believe understeer.
    Im also looking for advice on rear lower control arms to allow more camber, currently m3 stock
    Aug 2012
    Central, MD
    1995 M3
    Lots going on there.
    For your last question, Turner Motorsports adjustable LCA's.
    As for ARBs, most run a larger adjustable front bar and OEM rear. But, it's a big depends. The ARB should be for fine tuning, and if you're still running stock rear camber, you've got more than fine tuning to do. Spring rates, ride height, camber will make the biggest differences. And tires of course.
    Apr 2017
    Florida
    E36
    I you can see, I have a long way to go , lot to learn.
    Turner LCA with bushings or without?
    gonna start with LCA s and have realignment with proper track camber.
    with camber I could lower car possible 1 more inch.
    i am correct lower is Better?
    currently running BC BR coil overs. Any suggestions on spring changes?
    thanks for feedback
    Aug 2012
    Central, MD
    1995 M3
    I'd recommend the Turner LCA's with rubber bushings.
    Lower is better up to a point,....too low and you're on the bump stops and/or your roll center is too low. Rake is more important than getting crazy low. Most recommend about 0.75" rake (rear higher) measured somewhere around the car lift points between the wheels. Lowering the car around an 1" from stock is a safe amount. Springs depend on what you're using the car for, tires, and dampers. If you're just starting tracking, use what you've got. Do you know what your current rates are?
    What tires are you running?
    FYI, this car will do VERY VERY well with a fresh OEM suspension and OEM brakes. All it really needs to come alive is a little extra front camber.
    Apr 2017
    Florida
    E36
    Thanks for feedback
  1. E36 WTB:E36 manual M3 in florida
    By ganzibye in forum 3 series & Z Series
    Last Post: 08-06-2010, 05:18 PM
  2. White e36 track car in Downtown Danville last night?
    By E90DTM in forum California sponsored by Avus Autosport
    Last Post: 08-17-2008, 08:16 PM
  3. What are E36's Racing in Florida?
    By bryantcm in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 07-31-2008, 05:18 AM
  4. E36 Race Classes in Florida
    By bryantcm in forum Florida
    Last Post: 07-25-2008, 07:40 AM
  5. Still WTB e36 5 speed in Florida
    By Kelso in forum BMW Cars For Sale / Wanted
    Last Post: 12-03-2005, 07:42 PM
