Results 1 to 12 of 12
Thread: 2000 750il Battery indicator light
    Sep 2016
    Michigan
    1997 528i, 2000 750il
    2000 750il battery light.
    Issue.
    Top battery is at about 90%
    Bottom battery is at about 80%
    My sons truck got stuck so I gave him a jump from the Top battery.
    Now...my battery light is on and when I run the system voltage check, its at about 10.8~11.00. Wont go past that.
    Did I F something up on my car?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Unfortunately you have damaged the regulator on the alternator, or the battery isolation switch that connects the two batteries under control of the DME. If it is the alternator regulator - this can be replaced as a separate unit rather than replacing the complete alternator.
    http://www.meeknet.co.uk/e38/Alternator/Index.htm
    For V8 - but V12 similar:
    http://www.meeknet.co.uk/e38/Alterna...eplacement.htm
    If it is the battery isolation switch there's more information here:
    http://www.meeknet.co.uk/e38/E38_Dua...ery_System.pdf
    Reading your post again I would guess that the switch is the problem as jumping from the top battery would have demanded excessive current from the switch.....
    Nov 2016
    NY
    E38
    Timm is right. There are rebuild kits for the water cooled alternators, but a rebuilt alternator is a better choice - beware that the 750 gets a different part from the v8. If you jump, I think you should do it from the under hood terminals, not the battery terminals. I don’t know if that caused your alternator to fail.
    (northeast) Indiana
    97 740iL & 06 X5 4.4i
    Quote Originally Posted by CPHES View Post
    ... If you jump, I think you should do it from the under hood terminals, not the battery terminals. I don’t know if that caused your alternator to fail.
    Ditto...if at all possible...always jump and be jumped using the jump start teminals in the engine bay:
    {see last paragraph in far right column}
    {V12 engine bay jump start terminals}
    (if my grammar, spelling, or sentence structure is screwed up....don't blame me...it's my dang bluetooth keyboard...I try to catch & correct the mistakes...but I may not catch all of them.)
    Q {BMW CCA Member #191509}
    1997 740iL (Arctic Silver) 3/97 mfg date <<~>> 2006 X5 4.4i (Sterling Gray) 12/05 mfg date
    (SOLD)
    1999 540iT (Orient Blue) <<~>> 1995 525iT (Alpine White)
    1991 735iL (Schwarz) <<~>> 1985 325e (Bronzit)
    Sep 2016
    Michigan
    Has anyone ever rebuilt a watercoolded Alt??
    Nov 2016
    NY
    E38
    Look at Timm’s site. The meeknet links are excellent. Yes, it can be done, and there are kits, but you need to know what you are doing. Are you skilled that way - not to be harsh, but learning to do this on a 750 is a bad idea.
    Jul 2016
    Chicago, Illinois
    02 540/6, 89 750iL
    Quote Originally Posted by Magus528 View Post
    You can use one from the M62TU which is dime a dozen in junkyards, reuse the 750's pulley if it's different (some cars might still be equipped with the 49mm pulley).
    Quote Originally Posted by WBAD530i View Post
    M62 is an uncontrolled substance, and when abused can cause severe side effects. Do your drugs in moderation kids.
    Sep 2016
    Michigan
    If I went into the "hidden menu" and went to test 9...and the voltage is only 10.8~11.00 when running...then is sounds like it would be the alternator an not the battery isolation switch correct?
    I feel pretty comfortable getting the alternator out and rebuilding it if necessary...but the link only gives information about the isolation switch...not how to repair it.
    Also...If anyone knows Max Lumens....tell him to get at me...I need some info. Thanks
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Yes, the battery indication light does mean the alternator is at fault - the signal for the warning light comes from the alternator itself - but make sure it is actually turning first!
    Jul 2016
    Chicago, Illinois
    02 540/6, 89 750iL
    Spare yourself the time of rebuilding it, water cooled alternators for the TU are everywhere.
    Nov 2016
    NY
    E38
    Timm’s Page is great. There are many links on it. His links above in this thread should cover most of what you need. From above http://www.meeknet.co.uk/e38/Alternator/Index.htm
    Sep 2016
    Michigan
    Quote Originally Posted by XAlt View Post
    Lowest price I have seen is about $250-$275.
  1. 2000 750il Battery issues...draining.
    By Magus528 in forum 1995 - 2001 (E38)
    Last Post: 02-16-2017, 08:38 PM
  2. 2003 325xi battery indicator light
    By bimmerdude09 in forum 1999 - 2006 (E46)
    Last Post: 04-27-2014, 08:52 AM
  3. E34 battery indicator light on ignition off
    By vnusflyboy in forum 1988 - 1996 (E34)
    Last Post: 07-21-2012, 12:29 PM
  4. Help!! Battery Indicator Light, Transmission Indicator
    By camobarbie in forum 1999 - 2006 (E46)
    Last Post: 02-28-2008, 10:36 AM
  5. battery indicator light
    By JonPerezinSD in forum 1996 - 2003 (E39)
    Last Post: 06-19-2007, 02:55 PM
