RM European Auto Parts
Results 1 to 3 of 3
Thread: 328i replacing the heater control valve . . .
    Apr 2012
    ny
    1998 328i
    ve seen a video on Youtube and it looks easy to remove the hoses
    but how tough is it to put them back on ?
    Not much room to work and u have to stick the hoses back on
    in a tight space.
    Even if jacked up it looks hard to get your hands in there
    from the bottom of the car.
    Video says to remove the valve from the bottom of the
    car. Anyone remove it from the top ?
    so many wires and small hoses in the way topside.
    and tips on making this job easier ?
    thanks
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Do it from the top. Drain most of the coolant from the system and remove the hoses. Lube the new valve with a bit of liquid dishwashing soap and slide the hoses back on.
    Jun 2002
    boonies, western NC
    E39M5
    +1. There's really not much to it - the difficult part is making sure that you've bled all the air from the system, afterwards. If you don't get all the air out, the engine is very likely to overheat. Personally, I use a vacuum-fill tool, but there is a good DIY on the bleeding process in the FAQ thread at the top of this forum.
    Chris Powell
    Master Auto Tech, at an independent, formerly @ dealer
    BMWCCA 274412 SCCA 334928
  1. 328i replacing the heater control valve . . .
    By enf1945 in forum 1991 - 1999 (E36)
    Last Post: 01-13-2018, 07:10 PM
  2. Need the heater control valve/aux heater from an E38 740/750 or E39 540/M5
    By TC535i in forum BMW Parts Wanted sponsored by Bavarian Auto Recycling
    Last Post: 06-01-2008, 11:17 PM
  3. Could it be the heater control valve?
    By tarheal2323 in forum 1992 - 1999 M3 (E36)
    Last Post: 12-04-2007, 08:53 PM
  4. Replies: 0
    Last Post: 11-26-2007, 09:57 PM
  5. new owner. how hard is it to change the heater control valve
    By ryan86242 in forum 1988 - 1996 (E34)
    Last Post: 09-19-2007, 12:05 AM
