Results 1 to 16 of 16
Thread: e36 instrument cluster swap questions/problems
    Sep 2017
    Thailand
    1994 E36 325i
    Apr 2014
    UK
    1995 BMW 328
    There is a BMW tech note for using later clusters with coding plug in older cars that means adding one wire pin to a plug teed off another existing wire. I do not know what the Z3 is like.
    Sensible option is to look up the plug pinouts and see what is different and then re-pin if required.
    You may need to code the dash also for rev counter (if different no of cylinders)and speedo to read correctly)
    No warranty of any kind implied or given and no liability for any loss, damage or injury, no matter how incurred accepted.
    Sep 2017
    Thailand
    1994 E36 325i
    Apr 2014
    UK
    1995 BMW 328
    THE PART NUMBER PUT INTO REALOEM will list the cars it fitted
    Sep 2017
    Thailand
    1994 E36 325i
    awesome, thanks
    germany
    6/96 318is
    Quote Originally Posted by ladron View Post
    awesome, thanks for the reply, could you point me in the direction of the tech note?...
    Perhaps it is this one.
    Sep 2017
    Thailand
    1994 E36 325i
    good looking out, thanks. when I pull the cluster back out I will have a look at the part number to try and track down what specifically I need to do. I'll be back with more stupid questions, I'm sure.
    Jan 2006
    Dublin, Ireland
    E36 M3 3.2 EVO
    Z3 and E36ti (compact) use the same cluster with no economy gauge.
    Obviously pinouts are slightly different, so you need to get a pinout for your car and a pinout for E36ti/Z3, match them and see what wires are different or in different locations.
    Most likely, it will be the ones you are having the issues with - temp and tachometer.
    I don't know if you will find any exact explanation anywhere on the web world, as most people tend to stick with E36 clusters with MPG. Personally, I haven't seen anybody try this what you did as there is no advantage other than getting the cluster for free. E36 clusters are going for fairly low price. So it is not that hard to get an exact replacement.
    So you will have to figure out the pinout differences yourself.
    E36 clusters have 3 plugs in the back (BLACK, WHITE and BLUE). They all have specific names (X16, X17 and X271). I would recommend printing the sheets of their pinouts of one and the other cluster, sit down and match the pins and color codes of the wires. It also explains what each wire does, so you will know exactly where your problem is, once you find the difference.
    You will find pinout information in BMW electrical wiring diagrams.
    You can find all necessary electrical diagrams here:
    http://wedophones.com/BMWManualsLead.htm
    The Netherlands
    DE-spec E36 328i/M3 cab
    Quote Originally Posted by DJ Genius View Post
    ...E36 clusters have 3 plugs in the back (BLACK, WHITE and BLUE). They all have specific names (X16, X17 and X271). ..
    For complete info's sake. There is also an SMG version of the cluster, which has an extra plug for the gear display (X1699)
    IG:
    Jul 2010
    Murrieta, CA
    '94 325iC, '08 328i, E93
    Also, the engine in the Z3 might be a 4-banger, your car is a 6. The tach will work differently. I'm don't know how to adjust for this.
    The Netherlands
    Quote Originally Posted by JDStrickland View Post
    With NCS expert you can code for what engine/cylinder count the cluster is for.
    IG:
    Sep 2017
    Thailand
    1994 E36 325i
    Sep 2017
    Thailand
    1994 E36 325i
    update, if you care:
    I pulled the cluster back out and got a part number of :62116901494 which leads me to :http://www.realoem.com/bmw/enUS/partxref?q=62116901494 which tells me this cluster is from a 2000+
    here I find the wiring pins for the 2000 and 2001 clusters: http://wedophones.com/BMWManualsLead.htm
    I quick look and I can see the temp gauge pin numbers are different, so I think I am on the right track.
    Sep 2017
    Thailand
    1994 E36 325i
    update for completion for future searches:
    I was all ready to try rerouting pins and whatnot when a used oem cluster popped up super cheap, so I snatched that and will be installing that instead of dicking with the wiring.
    Sorry to disappoint all of you with a non-exciting conclusion.
    Apr 2014
    UK
    1995 BMW 328
    Not disappointed. I fitted a compact cluster picked out of a pile for 10 mins then noticed the mpg gauge missing and picked another out the pile. Don't remember any issues.
    TBH thought you were making life hard for yourself swapping
    Sep 2017
    Thailand
    1994 E36 325i
    Quote Originally Posted by E36328Coupe View Post
    yeah, but beggars and choosers, you know?
  1. E36 Instrument Cluster Problem
    By ashkan in forum 1991 - 1999 (E36)
    Last Post: 09-04-2016, 11:53 AM
  2. Instrument cluster swap question
    By mooll in forum 1995 - 2001 (E38)
    Last Post: 04-15-2015, 04:55 AM
  3. E36 Instrument Cluster problems
    By diegomejia5 in forum 1991 - 1999 (E36)
    Last Post: 12-18-2012, 01:55 PM
  4. Instrument cluster swap - E36
    By Geno325is in forum 1991 - 1999 (E36)
    Last Post: 01-21-2005, 10:14 AM
  5. Instrument Cluster Swap on E36. Mileage?
    By joebigfun in forum 1991 - 1999 (E36)
    Last Post: 04-04-2004, 08:06 PM
