Results 1 to 4 of 4
Thread: E46 m54 FSR or just a dead battery?
    Jun 2014
    baku, azerbaijan
    2001 bmw e46 320i
    Hi, may seem stupid question but i wanted to know whats the difference when battery is bad and FSR draining it. Sorry for my English.
    Recently i did retrofit of radio frequency key as mine was only with infrared so when connecting the wires i disconnected the battery just in case. And after reassemling fuse box in place i reconnected battery and test the key which worked fine. But heater blower started making noise like it has something on it's while spining whennkey is in position 1. I tried to start the car but starter did not engage, just clicking and headlights flashing. Later i jumpstarted the car and drove it fine like 2 days. Then had to leave it for couple days. So after 2 days of sitting i started it with no problems and let it warm like 10 mins to be battery is charged then turned engine off and connected diagnostic cable to look at some errors. 15 mins later i try to start the car and again no starter sound.
    As i'm low on a budget i wanna know for sure if it's battery gone bad or just FSR or something else cause it drain so fast. Thanx in advance
    Mar 2016
    Portland, OR
    2002 325Ci Cabriolet
    Quote Originally Posted by freestyle31225 View Post
    I can't offer a lot of help but I do have a suggestion - next time you park and lock the car, look at the RED LIGHT on the gear selector. It should go OFF after about 45 minutes or sooner. If it's still on after an hour, the car isn't going into SLEEP mode. At least this is what I've been told.
    Dec 2013
    Chicagoland area
    EXOTICS
    I believe it's more like 16~18 minutes before sleep mode kicks in.
    I suspect a failing starter solenoid.
    Next time it won't start, have a helper knock on the solenoid with a wrench,
    while you simultaneously turn the key, and attempt to start.
    Jun 2014
    baku, azerbaijan
    2001 bmw e46 320i
    Thanx for replies. I will try starter knocking next time.
    The problem is it sleeps fine cause it does not drain it when locked. If it was not sleeping then it would not start after 2 days of sitting in garage.
    I wonder if something drains it while the key is in ignition
  1. E46 WTB: damged or non working E46 MANUAL 6 speed tranny, or just the bell housing
    By quicksylver in forum BMW Parts Wanted sponsored by Bavarian Auto Recycling
    Last Post: 02-25-2014, 03:58 PM
  2. Another dead battery thread. Dead or just recharge?
    By therealpbgamer in forum 1999 - 2006 (E46)
    Last Post: 10-27-2011, 07:41 PM
  3. Wtb oem e46 m3 wheels (or just rears)
    By millertimebmw03 in forum Wheels and Tires
    Last Post: 10-17-2008, 01:59 PM
  4. Dead alternator? Dead battery? Or just incompetence?
    By moroza in forum 1988 - 1996 (E34)
    Last Post: 01-21-2008, 01:24 PM
  5. Is my battery dead or just in need of maintenance?
    By cosM3os in forum 1992 - 1999 M3 (E36)
    Last Post: 01-16-2004, 08:40 PM
