Results 1 to 11 of 11
Thread: N52 block deck
    Feb 2015
    Long beach
    2006 bmw 330i
    N52 block deck
    Hi everyone, Iím in the process of a head gasket replacement. I wanted to ask whatís the best way to prepare the deck for the new head gasket?
    Just to add I did use a machinist ruler the see if the block deck is wrapped, but the out of the two i ordered one was too long to fit in the engine bay so I used the small one. Iím waiting for another one to come in but for the most part i checked in horizontally and vertically( its 12-13 inches), I couldnít fit.004 under it.
    So I think my deck is ok.
    Thanks !
    Atlanta, GA
    2017 Ram 2500d
    Clean both the deck and the head. BMW has a special sanding block. You can use a brillo pad or other abrasive pad to clean it. Just nothing that will gouge or damage the surface. Sometimes a razor blade works well too.
    BMW Level 1 Master Technician
    2017 Ram 2500d
    2017 Jeep Grand Cherokee
    2014 Moomba Mobius LSV
    Feb 2015
    Long beach
    2006 bmw 330i
    Where can I find the sanding block, the old gasket wasnít scorched on the deck.
    Thereís slight residue but not much.
    Atlanta, GA
    2017 Ram 2500d
    It'd be a special order from a dealership. Which would require the part number. I don't have access to it at the moment. Try using a scotch Brite scuff pad
    2017 Ram 2500d
    Feb 2015
    Long beach
    2006 bmw 330i
    The scotch pad has aluiminiun oxide, is there an alternative that doesnít have Aluminium oxide?
    Feb 2015
    Long beach
    2006 bmw 330i
    I just got my cylinder head from the machine shop, they took off .006 in. Can I used a stock head-gasket?
    Atlanta, GA
    2017 Ram 2500d
    Yes. I've never used anything but a stock head gasket.
    2017 Ram 2500d
    Feb 2015
    Long beach
    2006 bmw 330i
    So I donít need to get a thicker gasket then, right ?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Your question was answered by a top-flight BMW tech.
    Charleston, SC
    01e39 540/6, '11F25
    Please note it is very important to keep debris out of the cooling jackets and oil passages, or make sure you flush them.
    Feb 2015
    Long beach
    2006 bmw 330i
    I thought the way I asked my question was vague.
    So thatís why I wanted to reiterate it in the form of a new question.
    Quote Originally Posted by ptarditi View Post
    I have the blue clothes in the oil passages, and bought a plastic razor to scrape off the old gasket.
    But there is still some confusion on my part on how to clean the deck so it can mate with the mls gasket, Iíve read on other forums that scotch bite shouldnít be used whilst others say using a high grit silicon carbide paper should work.
    I did see a scratch between the cylinders tomorrow I will look in detail to see if it can be buffed out.
    How would I go about flushing the oil passages ?
  1. M50 block deck height
    By blink977 in forum Engine Conversions
    Last Post: 12-12-2011, 04:55 PM
  2. Block deck, just how clean?
    By brothergross in forum 1988 - 1996 (E34)
    Last Post: 10-13-2010, 05:01 PM
  3. Vin local on a 2008 528i N52 block
    By 2barxr in forum General BMW sponsored by Intercity Lines
    Last Post: 07-11-2010, 08:10 PM
  4. s54 head on a n52 block
    By v8e21dreamer in forum Forced Induction
    Last Post: 11-16-2008, 02:20 AM
  5. m52 block deck height
    By alex11r in forum 1991 - 1999 (E36)
    Last Post: 09-20-2006, 10:31 PM
