Results 1 to 9 of 9
Thread: Flat toing a z3
    Jul 2017
    Pacolet, S.C.
    1996 z3 / 1997 328ic
    Flat toing a z3
    Anyone have any experience flat towing a z3 ?? Do I need a drive line disconnect ?? If so where do I find one ??
    Oct 2003
    Seattle
    99 M3
    You mean with a dolly w/two tires/wheels on road surface? Auto or manual? ‘Flat tow’ on a flatbed truck? With a strap w/ALL wheels/tires on road? Auto or manual?
    Jul 2010
    Murrieta, CA
    '94 325iC, '08 328i, E93
    If you have the rear wheels on the ground, you need to disconnect the drive shaft. TIP mark the yoke where the shaft connects to the differential so you can connect the drive shaft in the same orientation as when you took it off. Home Depot and Lowe's and your local Mom & Pop hardware store have Appliance Touch up Paint that comes in a small bottle like the paint for a model car/airplane, the appliance paint has a brush. Alternatively, you can buy some model car/airplane paint at the hobby shop. Get white so you can see it easily. Disconnect the drive shaft and suspend it with rope or bungie cord, or whatever so it does not hang down.
    Where do you find one? Find one what? Crawl under the car and take the bolts out that hold the shaft to the diff.
    I'm getting a bad feeling here.
    You are not going to flat tow your BMW. The front bumper, or the rear bumper for that matter, will not tolerate a tow bar. You are going to get a tow dolly and put the front or the rear of the car onto the dolly and leave the other end on the ground. If the front tires are on the ground, then you do not need to worry about the drive shaft connection to the differential, but you do need a scheme to keep the front tires pointed the right direction. Technically they could be pointed in any direction, but the direction must not change while towing. You really should be getting a car hauler trailer and dragging it with a pick up truck, a full size 1/2-ton to larger. Do not drag your your car on a trailer with a truck such as a Tacoma, you need the full size.
    Oct 2016
    Austria
    e36 323i, M3 3.2
    why do you advise him to disconnect the driveshaft when its not clear if he has auto or manual
    Jul 2010
    Murrieta, CA
    Doesn't matter. Well, it could matter, I suppose. But the insurance of not destroying the trans is worth the effort of taking four screws out.
    I had a Jeep that I flat towed, and with the trans in N and the failure of putting the t-case into N also resulted in the trans overheating and taking out some syncros. Turns out that the oil is not mixed well unless the input shaft of the trans is turning.
    But, you ask a good question. What kind of trans does the car have?
    My E36 manual says to not flat tow and not to leave the back tires on the ground with the front tires in a dolly.
    Oct 2016
    Austria
    e36 323i, M3 3.2
    you can flat tow it (whatever that is) if you have a manual without disconnecting the driveshaft. that the oil wont be circulated correctly is not possible. all the gearwheels are turning as they would be when the engine was running and a gear was engaged. only autos need that driveshaft disconnecting. and some manufacturers say you can tow it 20 miles if you stay under 25mph. or something in that range. but not all manufacturers say that. most say you have to disconnect it. and "just take 4 bolts out"... ever did it? not that easy, and when you disconnected it, what then? leave the driveshaft hanging there ? you know how much space most cars have there? how do you want to make sure the driveshaft flange won't rub on the differentials flange? and maybe all that out in the cold in the darkness ? before doing all that i'd try to do something where you don't have to disconnect it. but not enough infos from OP at this point anyway.
    May 2017
    Owings, Md
    1998 328i
    I have towed mine with the rear wheels on a dolly and while the steering column was locked, it wandered and got squirelly around 60 mph. This was behind a 1/2 truck with a long wheelbase.
    The RV community would be a good source of info regarding flat towing. I am regularly suprised by things they flat tow, they have a good knowledge base of what works and what doesn't. As old as these cars are I would expect it to be settled (regardless of what BMW recommends). I am not assuming BMW is wrong but I don't take their word as gospel (see lifetime ATF).
    Jul 2010
    Murrieta, CA
    QUOTING FROM THE OWNER'S MANUAL FOR 1994
    Towing vehicle equipped with automatic tranmsision
    If the vehicle must be towed with the rear wheels on the ground, towing speed should not exceed 30 mph and the distance should be limited to 25-30 miles. (if a 320, then 43 mph and 93 miles)
    Personally, if one is renting a tow dolly, spend a few more dollars and get the trailer and avoid the pitfalls that will just make you miserable in the end.
    Mar 2012
    millville, nj, usa
    Mine 99 z3, Wife 07 x5
    Where there is a will there is a way. Mine was a manual just took it out of gear.
    Quote Originally Posted by 2oldbimmers View Post
  1. Z3 E36/7 Want to buy Z3 BSW speakers
    By Deniz Y in forum Z3,Z4,Z8 Classifieds
    Last Post: 04-17-2017, 05:56 PM
  2. Going racing - going to sell Z3 :^)
    By mijgilbert in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 09-10-2002, 04:52 PM
  3. Convert my car to this? Z3 Coupe GT
    By JediZ in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-17-2002, 03:47 PM
  4. Want To Buy Z3 Stuff
    By Drexelbmw in forum BMW Parts Wanted
    Last Post: 05-01-2002, 01:25 PM
  5. Welcome A W to the Z3 Forum!
    By SilverStreak in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 04-11-2002, 01:32 PM
