Results 1 to 11 of 11
Thread: Fuel pump removal procedure (DIY)
    Orlando, FL USA
    Was wondering if there's a DIY write-up someone has done on pulling and replacing the fuel pump under the rear passenger seat. Wanted to study it and ensure I have all the parts before tackling the job.
    Thanks.
    Nov 2008
    South Florida
    93 850 Ci, 11 FX35,
    If you do a search on here you will find some. From what I remember you just need the fuel pump assembly, a new ring/seal and probably some new fuel hose. I was able to get my fuel clamps undone using a 1/4 drive and an extension and universal joint but a couple are a challenge. One write-up said they had to drill a hole to be able to get to the clamp loose but I didn't have to. The other thing is using a piece of wood to loosen the ring holding the pump unit in.
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    This is the BMW Tool that removes and installs the fuel pump retaining ring. You need to be sure that it is FULLY seated or you will have a leak.
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
    Orlando, FL USA
    That looks like a one off custom made tool, TxGR8White. Where would I find something like that? Any chance I can loan/rent from you?
    Dec 2013
    San Antonio
    850,76 2002 &530,84 633
    This is the tool I bought, CTA 2491. You need one with shoulders to clear the hose and electric fittings. Some people just use huge channel lock pliers.
    http://www.ctatools.com/index.php?ro...arch=Bmw+fuel+
    Orlando, FL USA
    Thanks for the link to the tool, JDP530. I sent you a PM by the way.
    Thanks for the tips 53helofe. I have a brand new pump assembly waiting to be installed. Just been too busy and haven't gotten around to it, but, figured it's time to do that now.
    I'll study the parts diagram and start pulling the seat out to see what's what down there. It's was leaking fuel every time I had the tank more than 3/4 full. Pump finally died on me right around November of last year.
    Dec 2013
    San Antonio
    I don't think the fuel lines or carriers had ever been replaced on my car because the lines still had oem crimped clamps on them. So I drilled access holes to remove and replace them.
    The tool to remove the fuel ring is used on many of the BMWs and Minis so there must be someone in your vicinity that would have one you could borrow.
    I called AutoZone and they stock a loaner tool for the BMW fuel tank ring. My local store had two of them in stock. You just have to put down a deposit to borrow it.
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    This is the tool I use, works very very well.
    https://www.amazon.com/ABN-Module-Sp...fuel+pump+tool
    Nov 2005
    Langley BC Canada
    91 850 Panzer
    And, I use this one - the JTC 1550
    http://eng.jtc.com.tw/product/index....eywords=&sort=
    91 850 (Panzer), 2012 Mini Cooper Countryman (WifeMobile) www.wuffer.ca
    Orlando, FL USA
    Thank you everyone for all the leads and tips!
    May 2013
    Stamford, CT
    1991 BMW 850i
    Here's mine. First I just used one of those rubber strap wrenches, but that was a pain in the butt. When I looked for the proper tool, it was just too pricey (I think it was over $50, but I don't really remember). Found this bowl at Walmart for .99 cents, cut some slots on the table saw, and a hole to stick an extension through. Fit perfectly and worked great.
    My Cars - 1991 BMW 850i - mine for fun, 1993 Saab 900c - mine for fun, 2008 Lexus is250 - my daily driver, 2003 Dodge Durango - my wife's, 1994 Acura Legend - gave it to kid
  1. Question on fuel pump - removal of rear seats
    By M3Alpine99 in forum 1983 - 1991 (E30)
    Last Post: 11-04-2007, 05:31 PM
  2. E36 M3 Fuel Pump Banjo Clamp DIY
    By cstang68 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-12-2007, 08:00 PM
  3. Replies: 6
    Last Post: 04-21-2004, 10:56 AM
  4. Fuel Pump removal on a 4 Door
    By RRdawho? in forum 1991 - 1999 (E36)
    Last Post: 11-07-2003, 12:28 PM
  5. Fuel Pump Removal
    By bandit1911 in forum 1991 - 1999 (E36)
    Last Post: 05-27-2003, 10:04 AM
