Results 1 to 9 of 9
Thread: Oil additives advisable?
    Jan 2018
    Bay Area, California
    2002 BMW 325i
    Just inherited a 2002 325i w/ sport package, dinan intake/exhaust, 168K miles on it. Motor has slight leak on the oil pan (will replace gasket soon) and just wondering if it is advisable to add a high mileage additive to mitigate any current & future leaks. Manual says BMW does not recommend but is that sacred gospel?
    I've been using high mileage oils and additives on my older Japanese cars and so far they work meaning no leaks.
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    I've tried high mileage oil to see if it would help slow an oil pan gasket leak and nothing worked. However, Castrol LL02 0w40 made the leak worse. Switched back to Mobil 1 LL02 0w40 and it slowed back down. Whatever you do, don't use "Restore" or anything in its likeness as you will clog the vanos solenoid screens.
    Jan 2018
    2002 BMW 325i
    Thanks dhurley! I do use M1 0w40, I guess my main concern is also if these additives can do more harm than good to the motor.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    I wouldn't waste your money on oil additives, as the Mobil 1 has plenty in there for the LL-01 standard. Now is you want to add some to the fuel tank, well that would be a different story.
    The key is to replace the oil on a regular basis, and the only additive I add is right before changing the oil every couple of years is ATF to clean the motor out.
    The pictures are from last year when the car had it's valve cover replaced around 110k miles.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    Tell me more about how you use ATF to clean the engine.
    1) how much do you add?
    2) do you drive it xxxkm or just let it idle for so many minutes?
    1999 2.8L Z3 Roadster,
    2000 3.0L Z3 Roadster,
    Jan 2016
    Ca
    2001 525it
    Change the oil every 5k
    dworthy's Avatar
    Nov 2010
    Quote Originally Posted by Muzz258 View Post
    I use a quart in total.
    1) Add 1/2 quart drive for about 100 miles.
    2) Add the rest and drive for about another 100 miles, then change the oil and filter.
    I do this before any Inspection I/II on the car and keep the motor nice and clean, so about every 20k-25k miles.
    Normally I will do an average of 10k miles on the wagon every year, if you want to change your oil sooner that is up to you. The manufacture of the Oil you put in the car has spent a lot of time, money and researching showing that it can go the distance.
    Lastly Oil threads are the worst. Everybody likes to weigh in on their opinion on this subject, just do the research on the oil you plan on using and make your own decision, BMW already has.
    Darin
    Current:
    Past:
    M-Flight Member
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Let me chime in here! I am typically against adding anything to the oil except more oil! Yes, adding ATF will clean the engine innards. But, so will more frequent oil/filter changes. As far as adding high mileage oil to the BMW LL01 rated oil, it worked for my departed 2001 330Ci. The rear main seal on early M54 engines tends to seap oil after ~100k miles. I added a quart of Mobil 1 10W50 high mileage oil to the 6 quarts of Mobil 1 0W40. The minor clutch shuddering stopped almost completely.
    Departed? Yeah, I now drive a 2018 M240i. He’s a beast.
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    Thank you @Dworthy for the information. I understand the sentiment in which is has been provided. It will be added to the information I use to decide on oil change intervals and procedures.
  1. Any advise on using Motorkote oil Additive in 06 M3
    By Viper33 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-21-2015, 08:31 PM
  2. Lucas Oil Additives
    By Rusty 904 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-03-2004, 06:18 PM
  3. Lifter tick/ oil additive question
    By Caspuh in forum 1992 - 1999 M3 (E36)
    Last Post: 09-13-2002, 02:00 PM
  4. fuel injector cleaner/oil additives
    By stoneweed1 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 09-07-2002, 03:39 PM
  5. Oil Additives
    By straight6music in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-05-2002, 07:50 AM
