My Z3 has a 2.0 6 cyl engine how difficult would it be to put a 3.0 in its place or a 2.8 , is the gearbox the same ? diff and axles?
You have a M52TUB20 duel VANOS engine now. It would be easier to fit a duel VANOS M52TUB28 engine at they use the same DME (engine computer). You would need to get the DME reprogrammed for the 2.8 engine. Not a big problem as there are standard programs available, just need to find someone who can do it for you. Note that there are two types of 2.8 L engine around. The M52B28 which is single VANOS and the M52TUB28 which is duel VANOS, get the right engine.
The M54B30 (3.0 L) engine uses a different DME that is more integrated into the car's systems. This makes it a harder transplant.
Running the M54B30 on your existing DME can be done, but needs a custom tune. Its hard enough to find someone to do a standard reprogram let alone someone to do a custom tune.
Both engines will bolt up to your transmission. You will have a small case diff in your car. Both the transmission and diff are rated for lower torque levels than the 2.8 L engine. To ensure that you have a long term reliable car, you may need to consider changing them to higher rated units. A medium case diff with associated axles (half shafts) would be needed.
I understand that the car modification laws are getting tight in Oz, best you check out what you are allowed to do and what needs certification.
1999 2.8L Z3 Roadster,
2000 3.0L Z3 Roadster,
Thanks for that very helpful.
*Can custom tune MS42 to run M54B30.
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
A lot of effort to add 800cc
Ever thought of just buying a larger capacity and selling the 2.0
Pretty easy to swap in a V10 S85 from what I've heard. It's basically plug and play
PRICE CUT on ALL FABRICS
Abel is a wizard. His powers should be respected and perhaps even feared.
But seriously, if I ever end up doing an M54B30 swap, he'll be the person I consult.
