I have a '92 735i, and the rear tires are wearing badly on the inside. On hard acceleration the rear end squats, the camber change reduces the contact patch, and traction goes out the window. Would a stiffer rear spring help?
I hope you do not have a bent rear axle carrier, maybe you remember that we had 3 cases here in our wrenching group with B12 750 https://www.bimmerforums.com/forum/s...ight=rear+axle
especially as you have the powerful (non-BMW) engine installed.
Also check for the pics from Erwin on Bimmerboard of his bent rear axle, easy to find, use the search there on the E32 forum with erwin as search name, reduce search to pictures only.
I hope that's not the case, I'll look as you suggested. Thank you
Here the pics from erwin, bent trailing arm
http://www.bimmerboard.com/forums/posts/528188/
http://www.bimmerboard.com/forums/posts/528223
http://www.bimmerboard.com/forums/posts/528193
