Results 1 to 2 of 2
Thread: E36 PSS9 ride height inquiry
    Dec 2015
    Yakima, Washington
    1998 BMW 328is
    Hi all, I had some questions regarding ride heights and clearance issues. My 98 328is is currently on Bilstein sports (b8s) with H&R sport springs in the front and oem springs in the rear. I have a square set of D-Force LTW5s in 17x8.5 et40 wrapped in 245/40r17s. I don't plan on lowering the car much lower than it is now, but I really want to reduce the wheel gap. The car has lost some weight and it sits higher than before. I have a 2 finger gap front and rear and would like to cut that down to about 1/2"-3/4" with the PSS9s.
    My main concern is having my front tires rubbing on the coilover. Since I don't plan on dropping the car very low, will I run into that problem? I really don't want to run a spacer in the front because I feel like the tire will come into contact with my fender. I would also like to stick to a 245/40r17 so dropping down a tire size isn't ideal.
    The other question I have is about the ride height in the rear? Whats the maximum height I would be able to achieve in the rear? Can I get it to where there is a 1/2" gap between the tire and the fender?
    I'd appreciate any help you guys can offer. Thanks!
    Aug 2011
    Charleston, SC
    2000 M5, 2018 Macan Turb
    I have same setup, 17x8.5 fit on front with 245-40-17 without spacers with my PSS9’s. I keep ride height all the way up on the fronts. 17x9 wheels generally need spacers.
    PCA HPDE Instructor
    current:
    2004 M3 convert 6sp man - low mileage beauty!
    past:
    1995 BMW M3 3.2
    2004 M3 convert SMG
    2003 BMW 540i6 Alpine White M sport (I want her back!)
  1. E36 Rear Ride Height vs. Toe
    By mikeo in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 12-23-2009, 11:52 AM
  2. Style 5's on E36 - Stock ride height
    By lithium726 in forum 1991 - 1999 (E36)
    Last Post: 03-07-2008, 05:08 PM
  3. Bilstein PSS9 Ride Height
    By buuhh99 in forum 1991 - 1999 (E36)
    Last Post: 02-07-2007, 08:28 PM
  4. Lowering US E36 M3 to European E36 M3 ride height?
    By 325i Vert in forum 1992 - 1999 M3 (E36)
    Last Post: 06-24-2006, 09:45 AM
  5. PIC REQUEST: 18" rims on stock E36 M3 ride height
    By littleblue in forum BMW Rides & Events
    Last Post: 01-20-2004, 04:14 PM
