Stops when accelerate or take off the gas ,intermittent
have scanned the car and no codes 4.4 auto
Seems like the auto trans cant decide First or second and bangs between them but not sure has anyone else had this issue and what was the cause?
Hi,
My 03 4.4 198K miles does the same...
If it feels like clutch chatter between 1st and 2nd at low rpm's in D not S or using the manual shift mode.
Check the oil pan for silver slivers as there is a thrust bearing that goes according to CTSC the local ZF dealer.
GG
Im not sure what they would be talking about there is no clutch so no thrust bearing, there is a torque converter and a solenoid valve that locks the torque converter for more efficiency this can give trouble also there is a wiring loom in the transmission that can have intermittent fault, Also due the life time fluids they clog up the cooling system which can lead to overheating so even after a transmission service it will cook the new fuild and lead trouble Still doing research will get to the bottom of it
Here are possible causes for it - https://www.eeuroparts.com/blog/7208...ses-solutions/
Nice one thanks
