RM European Auto Parts
Results 1 to 12 of 12
Thread: Pierburg Pump Question
    Jan 2018
    DFW
    Project
    Looking to retrofit a Pierburg CWA 200 or 400 water pump into my street/strip project car. And issue I have come across is that I can't find any dealers have have one in stock to tell me what size in/out hoses they use or what their dimensions are. Is there anybody here that can help me? Much thanks!!!!!
    Steve
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    I don't have the answer and am just curious why you don't use the pump engineered for the engine. What model car and engine is it?
    Welcome to Bimmerforums!
    88M3 AW 43k miles Project FS
    Jan 2018
    DFW
    Project
    Quote Originally Posted by MauiM3Mania View Post
    On-the-block water pumps and supercharger belts have a tendency to have a conflict of space Mezeire makes remote mount water pumps that flow 55 GPM free flow, but the motors are known to burn out within 2 years. I know a pierburg is worst-case good for 30,000 OEM miles and all-around would be better for my situation. Probably last 5-10 years in my case.
    Jan 2002
    Central Pacific
    Turbo it, save up front space.
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by magnethead View Post
    Steve
    With a part # you can discover applications. With applications you'll be able see the hoses that attach to it. Hose dimensions may be given in part's description, if not somebody surely carries hoses and could measure them.
    Try sniffing around at realoem.com
    Jan 2018
    DFW
    Project
    Quote Originally Posted by ross1 View Post
    Problem I have run into is that it seems that PN's keep changing, thanks for that link. I'd like to have actual dimensions of the pump as I'm mounting it directly under the radiator on the core support.
    CWA200:
    11517586924 is now 11517586925 comes up as:
    1' E81   (02/2006 — 12/2011)
    1' E87   (03/2005 — 02/2007)
    1' E87 LCI   (01/2006 — 06/2011)
    1' E88   (11/2006 — 10/2013)
    1' E82   (12/2006 — 10/2013)
    3' E90   (02/2004 — 09/2008)
    3' E90 LCI   (07/2007 — 12/2011)
    3' E91   (02/2004 — 08/2008)
    3' E91 LCI   (07/2007 — 05/2012)
    3' E92   (05/2005 — 02/2010)
    3' E92 LCI   (09/2009 — 06/2013)
    3' E93   (09/2005 — 02/2010)
    3' E93 LCI   (07/2009 — 10/2013)
    5' E60   (07/2004 — 02/2007)
    5' E60 LCI   (11/2005 — 12/2009)
    5' E61   (07/2004 — 02/2007)
    5' E61 LCI   (11/2005 — 05/2010)
    6' E63   (02/2004 — 07/2007)
    6' E63 LCI   (04/2006 — 07/2010)
    6' E64   (03/2004 — 07/2007)
    6' E64 LCI   (04/2006 — 07/2010)
    7' E65   (06/2004 — 07/2008)
    7' E66   (07/2004 — 07/2008)
    X1 E84   (09/2008 — 08/2011)
    X3 E83 LCI   (02/2006 — 08/2010)
    X5 E70   (02/2006 — 03/2010)
    Z4 E85   (10/2004 — 08/2008)
    Z4 E86   (10/2005 — 08/2008)
    Z4 E89   (01/2008 — 08/2011)
    11517586929 comes up as:
    1' E87 LCI   (02/2006 — 06/2011)
    1' E82   (06/2009 — 09/2013)
    3' E90   (02/2007 — 08/2008)
    3' E90 LCI   (03/2008 — 12/2011)
    3' E91   (02/2007 — 08/2008)
    3' E92   (09/2006 — 02/2010)
    3' E92 LCI   (11/2008 — 06/2013)
    3' E93   (10/2005 — 02/2010)
    3' E93 LCI   (09/2009 — 10/2013)
    11517604027 is now 11518635089 and 11517597715:
    1' F20   (07/2010 — 02/2015)
    1' F20 LCI   (05/2014 — 06/2016)
    1' F21   (07/2010 — 02/2015)
    1' F21 LCI   (09/2014 — 06/2016)
    2' F22   (10/2012 — 06/2016)
    2' F23   (04/2014 — 06/2016)
    3' F30   (04/2011 — 07/2015)
    3' F30 LCI   (12/2014 — 09/2017)
    3' F31   (07/2011 — 06/2015)
    3' F34 GT   (07/2012 — 06/2016)
    4' F32   (04/2013 — 02/2016)
    4' F33   (11/2013 — 02/2016)
    4' F36 Gran Coupé   (08/2013 — 12/2016)
    5' F10   (06/2010 — 06/2013)
    5' F10 LCI   (10/2012 — 10/2016)
    5' F11 LCI   (01/2013 — 02/2017)
    X1 E84   (04/2009 — 06/2015)
    X3 F25   (02/2011 — 08/2017)
    X4 F26   (07/2013 — 09/2017)
    Z4 E89   (03/2011 — 08/2016)
    11517596763 is now 11518635090:
    ​1' F20   (04/2011 — 02/2015)1' F20 LCI   (06/2014 — 06/2016)
    1' F21   (12/2011 — 02/2015)
    1' F21 LCI   (06/2014 — 06/2016)
    2' F87 M2   (11/2014 — 06/2017)
    2' F87 M2 LCI   (09/2016 — 09/2017)
    2' F23   (03/2014 — 06/2016)
    3' F31   (08/2011 — 06/2015)
    4' F32   (11/2012 — 06/2016)
    4' F33   (03/2013 — 06/2016)
    4' F36 Gran Coupé   (07/2013 — 06/2016)
    5' F07 GT LCI   (08/2012 — 02/2017)
    5' F10 LCI   (08/2012 — 10/2016)
    5' F11 LCI   (10/2012 — 02/2017)
    6' F06 Gran Coupé LCI   (06/2014 — 09/2017)
    6' F12 LCI   (07/2014 — 09/2017)
    6' F13 LCI   (05/2014 — 09/2017)
    X5 F15   (08/2012 — 09/2017)
    X6 F16   (09/2013 — 09/2017)
    MS BMW Motorsport   ( — )
    On the TinyCWA Website ( https://www.tecomotive.com/en/products/tinycwa.html)
    Pierburg CWA200
    Supply voltage: 8-16 Volt
    Current consumption: max. 16,5A in operation and 0,2mA in standby mode
    Differential pressure: 0.45 bar
    Flow rate: 116l/min @ 0.45bar / 166l/min @ 0.30bar
    Protection: IP67
    Part numbers: Pierburg - 7.02851.20.8 / 7.00294.17.0 // BMW: 11517586924 / 11517586925 / 11517586929
    Pierburg CWA400
    Current consumption: max. 36A in operation and 0,2mA in standby mode
    Differential pressure: 0.85 bar
    Flow rate: 150l/min @ 0.85bar / 220l/min @ 0.55bar
    Protection: IP67
    Part numbers: Pierburg - 7.03665.66.0 / 7.02478.40.0 // BMW: 11517604027 / 11517596763
    Jan 2018
    DFW
    Project
    Are there any members here or sponsoring repair shops that would happen to have a pump handy? If somebody has a failed core, I would love to buy one for mockup purposes.....
    Here is my build thread, currently on page 16 about to be 17: https://dodgeforum.com/forum/2nd-gen...d-process.html
    Jan 2002
    Central Pacific
    A couple things you could do. Edit your forum signature so that it specifies your needs. And/or, post a wanted ad in the appropriate sub-forum of the Classifieds here on Bimmerforums.
    Jan 2018
    DFW
    Project
    I have created a classifieds post.
    Not sure where the signature would help, it's going into a supercharged dodge race truck. I just don't want to pay $600 for a pump to find out it will not plumb in or otherwise physically work for my situation. Hence I am in pursuit of the pump's actual dimensions and what size the hose fittings are. I've contacted several vendors and none of them keep the pumps in stock, they all drop ship.
    Jan 2002
    Central Pacific
    Not sure where the signature would help.....
    I'm glad you took my suggestion of utilizing our Classifieds. A tonload of people come through that area but never really post, so it may appear slow but the area gets a lot of exposure.
    The point in a placing a 'mini-ad' in your signature would expose your needs to every person that sees a forum post of yours in every sub-forum.
    Jan 2018
    DFW
    Project
    I did some hunting, looks like the CWA400 is 40mm in and out. 1-1/2" hose is 38mm, that's alot to ask of a hose to stretch but should be doable without it splitting. Still have yet to find any definite pump dimensions
    Jan 2002
    Central Pacific
    I've heard of people buying an item and if it didn't work out, return it. Not suggesting that you buy something with the intent of making some measurements and returning it......
  1. Pierburg/TI Automotive/Walbro pump question
    By Da Beemers in forum 1996 - 2003 (E39)
    Last Post: 09-21-2017, 03:13 PM
  2. Water pump questions: 98s prone to failure?
    By Sonic A in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-24-2003, 11:57 PM
  3. Upgrading fuel pump questions
    By artemis in forum Forced Induction
    Last Post: 08-16-2002, 08:13 AM
  4. water pump question
    By dmw in forum 1992 - 1999 M3 (E36)
    Last Post: 03-23-2002, 01:21 AM
  5. Water pump question
    By knomad in forum 1991 - 1999 (E36)
    Last Post: 06-17-2001, 02:31 AM
