Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 79
Thread: Another 325is turbo build.
  1. #51
    Virginia
    97' m52 turbo
    It works fine.
    I have a little oil in my charge pipes but if you read about turbo cars, its actually normal as long as its not excessive, puddling heavily or coating your MAF often
    Only thing I would suggest is welding a steel plate to the bottom or top of an X brace to prevent debris from hitting it
    a $10 investment, ill be welding one soon
    and this makes the angle perfect
    https://www.aliexpress.com/item/Turb...812069952.html
  2. #52
    Jan 2018
    Arizona
    93 325is
    I see alot of info on self tuning the dme for m52/s52 but booty for m50 is the process different or is it harder or am i moot looking in the right places I'm moot trying to tune it my self but it is something I want to start learning.
    Sent from my SM-G935V using Tapatalk
  3. #53
    Jan 2018
    Arizona
    93 325is
    Can someone do me a favor and measure from the distance between say the valve cover and shock tower I feel my motor is tilted more than It should be.
  4. #54
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Put a level on your oil pan
  5. #55
    Jan 2018
    Arizona
    93 325is
    I'll try that I'm not sure if I have one that will fit haha
  6. #56
    Jan 2018
    Arizona
    93 325is
    hey everyone have another question ive looked around and from what ive seen the weakest part of the b25tu is the pistons is that correct or not. and what do they normally hold out till?
  7. #57
    Jan 2018
    Arizona
    93 325is
  8. #58
    Jan 2017
    RI
    1994 325is
    Quote Originally Posted by Smurf36 View Post
    I am not an expert in this, but seems like people start to bend rods around 500+ wtq.
    Sent from my SM-G930V using Tapatalk
  9. #59
    Jan 2018
    Arizona
    93 325is
    Did a baseline on the dyno at work seems alright for a stock 209k m50. Car runs great.
  10. #60
    Jan 2018
    Arizona
    93 325is
    Little update on the car still stock piling parts recently picked up a technique tuning manifold and ordered a eBay intercooler. Hoping to have all my parts and the build finished by end of the year
  11. #61
    Dec 2016
    Los Angeles, California
    2002 E46 BMW 325i
    Quote Originally Posted by 328iFun View Post
    It works fine.
    Does that mean I don't need my -10AN oil drain adapter on my turbo? I need the aliexpress fitting instead?
  12. #62
    Dec 2018
    Brunswick Georgia
    Bmw E36, Lincoln LS,
    What's wrong in your opinion with the war chip. Out of curiosity
    Sent from my SAMSUNG-SM-G870A using Tapatalk
  13. #63
    Jan 2018
    Arizona
    93 325is
    ? Mine or whos
  14. #64
    Dec 2018
    Brunswick Georgia
    Asking someguy2800
  15. #65
    Jan 2018
    Arizona
    93 325is
    What's up guys making more headway on my build. Recently developed a leak on my head gasket so I bought a nother motor and I'm putting It together to drop it my car with the turbo. So far I've stripped it down most of the way sending the head off to be checked and decked and hot tanked then will re install. Looking at different head gasket options and weighing the pros and cons and wanted to know the best option for 3-400.
    Sent from my SM-G960U using Tapatalk
  16. #66
    Mar 2019
    Silver Spring, Maryland
    1990 325i
    For cheap insurance you could also throw a new set of rings on the pistons if that's something you're comfortable with, even though its not necessary at that power level.
    https://www.ecstuning.com/b-genuine-...h/11251437077/
    https://boostmonkey.com/cut-ring-hea...p-to-85mm-bore
    https://boostmonkey.com/engine/engin...-head-stud-kit
  17. #67
    Jan 2018
    Arizona
    93 325is
    So update here's the motor I picked up for the swap. Said to have ran prior to being pulled so far I have everything off but the vanos cover head pulling those tonight. And sending the head out tomorrow or Friday.
  18. #68
    Jan 2018
    Arizona
    93 325is
    Got my oil pan cleaned up and tapped to 1/2NPT picking up a fitting on my way home today to use for draining. My turbo came in the mail last night so that was exciting unboxing it.
  19. #69
    Jan 2018
    Arizona
    93 325is
    Going to be looking for an intercooler kit/ intercooler for cheap or a good used one as well as bov and waste gate if any one has some parts for sale let me know! If appreciate It immensely.
  20. #70
    Jan 2018
    Arizona
    93 325is
    Got head off today and everything looks good aside from the timing guides being broke.
  21. #71
    Jan 2018
    Arizona
    93 325is
    Dropped the head off at the machine shop yesterday Will be picking it up later today and will have some sweet pictures for everyone
  22. #72
    Jan 2018
    Arizona
    93 325is
    The head cleaned up good for coming off of an 80 dollar motor. Had them clean in pressure check it and then deck it.
  23. #73
    Jan 2018
    Arizona
    93 325is
    Waiting on my gaskets and new guides then it's time for reassembly. I have a question though, my vanos cover studs were damaged and bent so I removed them and want to replace them my question is do they have to be studs and nuts or would a bolt suffice?
  24. #74
    Jan 2018
    Arizona
    93 325is
    Will be reassembling the head tomorrow when I get some free time.
  25. #75
    Jan 2018
    Arizona
    93 325is
    Little by little getting there got the head assembled and torqued then timed ready for install. Waiting on my gaskets to get here in the next few days.
  1. 325iS Turbo Build, v2!
    By SiGmA in forum Forced Induction
    Last Post: 04-22-2010, 03:52 PM
  2. M50 325i turbo build in progress
    By Scotti86 in forum Forced Induction
    Last Post: 09-05-2008, 08:28 PM
  3. Another E34 Turbo Build
    By Emons34 in forum 1988 - 1996 (E34)
    Last Post: 07-16-2008, 01:28 AM
  4. Started my 1995 325iS turbo build...(pics)
    By 2point5turbo in forum Forced Induction
    Last Post: 06-09-2008, 12:07 PM
  5. E30 325i turbo build help
    By Bullet325 in forum Forced Induction
    Last Post: 12-04-2007, 01:19 AM
