Results 1 to 19 of 19
Thread: ABS module coding
    Sep 2008
    Sandy, Oregon
    2002 330Ci, 1995 325is
    ABS module coding
    Does anyone know a shop that can recode a ABS module for a 2002 330Ci in the Portland Oregon area? Someone besides the stealership.
    Jun 2005
    Dirty MFin Jersey
    M3 Buildup
    any semi competent shop can do this in 2018. No really special tool necessary at this point just ask around your area.
    Buy my native installed ISIS ISTA-D/ISTA-P bmw diagnostic laptop. More Info Here!
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Sep 2008
    Sandy, Oregon
    I have. There is only one shop listed anywhere near where I live and they won't do it.
    Quote Originally Posted by MarcoZandrini View Post
    Sep 2008
    Sandy, Oregon
    I've been calling BMW shops in the area and I haven't found one yet that will do it. That's why I posted this. I was hoping that someone in Oregon that has had it done was visiting this site.
    Quote Originally Posted by Driiven View Post
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters 2L & 3L
    Check out post 8 in the below link. You may be able to do it yourself.
    http://forum.e46fanatics.com/showthr...ram+abs+module
    2000 2.0L Z3 Roadster, Mora Red, Individual, Originally from UK, daily drive.
    2000 3.0L Z3 Roadster, Siena Red, BMW Development car, Originally from Germany, Garage Queen
    2000 323i E46
    Sep 2008
    Sandy, Oregon
    I don't have a Bosch module, I have an Ate. This may be why Module Master said that this module was unrepairable. Doe these posts also apply to Ate modules?
    Quote Originally Posted by Muzz258 View Post
    Jan 2015
    Timaru, New Zealand
    There is a file attached to Post 8 in that link that covers how to code any ABS unit.
    2000 323i E46
    Sep 2008
    Sandy, Oregon
    He thought it would work. He didn't say he had done it. That's a really important distinction. I'll still try it though I hate to have to buy a windows machine.
    Jun 2005
    Dirty MFin Jersey
    M3 Buildup
    If you need to buddy get a windows machine of any type a cheap inpa cable and teamviewer I will install everything and code your module to make sure it works for you just pm me
    Jan 2016
    Ca
    2001 525it
    The independents probably would do it because they didn't install the part just call the dealer how much do they want
    Sep 2008
    Sandy, Oregon
    Thanks for the offer, but I'm in Portland Oregon and not Portland Maine. It would be a long drive.
    Jun 2005
    Dirty MFin Jersey
    M3 Buildup
    i can do this remotely for you over the internet buddy...
    Sep 2008
    Sandy, Oregon
    How?
    Jun 2005
    Dirty MFin Jersey
    M3 Buildup
    all you need is a laptop running windows and teamviewer... I can remote in to your system, setup software, you plug in to vehicle and I can do what needs doing simple really
    Sep 2008
    Sandy, Oregon
    I'll send you a PM when I find an old Windows laptop.
    Sep 2008
    Sandy, Oregon
    Just wanted to post that I found a place in Portland who recoded the replacement junkyard module for $130. It has worked perfectly since the replacement. Although I was told here that modules are rarely the problem it sure was in this case. If you get the trifecta don't neglect to check the module with a proper scanner. Don't give up if you still have the dreaded lights.
    Apr 2009
    Vancouver Isl, BC, Canada
    2004 330ci
    Quote Originally Posted by curry View Post
    The ABS modules do fail somewhat often. The internal seals fail and the brake fluid ruins the electronics. Otherwise module failures in general are rare though.
    Current:
    - 07 328CI
    - 07 335i
    - 98 M3 Eurospec
    Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci
    Sep 2008
    Sandy, Oregon
    I realize that. The reason I posted this was both at this site as well as at E46 fanatics posters wrote that I should ignore the module being the problem even though I had posted the codes that indicated it was. I know they were probably trying to be helpful, but they could lead people looking here for help to ignore a real possibility. I want to assure people that this repair was one that could help solve the problem and to not ignore a possible solution.
    Quote Originally Posted by legoman67 View Post
  1. DIS abs module coding w error "CAN-Time-Out ASC"
    By akilo in forum Diagnostic Software
    Last Post: 04-29-2015, 07:44 AM
  2. Need local ABS module coding
    By Trasportador in forum Georgia sponsored by Harrison Motorsports
    Last Post: 04-09-2014, 06:55 PM
  3. 2006 750Li ABS Module Coding
    By purplecty in forum Diagnostic Software
    Last Post: 08-02-2013, 10:09 AM
  4. HELP! abs module codes read fuses blown?? where to go from here!?
    By uNcLeWiGGLy in forum 1996 - 2003 (E39)
    Last Post: 04-01-2009, 01:08 PM
  5. A SoCal Place to get a ABS Module Coded!? Indy? Decent not raping $ Dealer?
    By LBMotoring in forum California sponsored by Avus Autosport
    Last Post: 12-11-2008, 10:05 PM
