Results 1 to 2 of 2
Thread: OBD Flash Tune From Active Autowerke **No ECU REMOVAL REQUIRED**
    Jan 2017
    Las Vegas
    Talking OBD Flash Tune From Active Autowerke **No ECU REMOVAL REQUIRED**
    Can be done from home with the use of the Simon Cable
    You still have the option to send your ECU to Active direct if you do not wish to purchase the Simon Cable.
    Active Autowerke offers unparalleled performance software. Through careful remapping of
    the factory BMW DME tables, various elements such as ignition timing, fuel delivery, and part throttles are reworked to create performance gains. The Active Autowerke upgraded software is designed to operate with gasoline that has an average octane rating with full emissions to create a clean burning combustion with good AFR’s all within factory specifications.
    Key Features:
    • Up to 120whp Horspower gains throughout RPM range
    • Higher torque over factory settings through RPM range
    • Recallibrated settings for a smoother and more responsive part throttle transition
    • Recallibrated settings for a smoother and more responsive power delivery
    • Modified Vanos camshaft remapping
    • Available "Burble" Maps
    • Free tech support and assistance
    • Top speed limiter removal
    • Multiple maps available
    Available Options:
    • Cold start delete
    • Stage 1 or Stage 2 maps for 91-93 octane
    • Off Road Only Downpipe Map
    • Burble Option
    • Tuner flag removal
    Performance Specs:
    • Up to 120hp gains : Rear wheel HP measured on the dyno
    Nov 2018
    Farmington Hills, MI
    1997 BMW Z3
    I want to use the DME out of an E39 and put it in a z3. Will this software allow me to wipe the dme and flash a tune for a z3? Will it allow me to synch the dme to a different EWS and key?
    Sent from my SM-G965U using Tapatalk
  1. Replies: 7
    Last Post: 03-13-2018, 03:00 PM
  2. OBD Flash Tune From Active Autowerke **No ECU REMOVAL REQUIRED**
    By mike@XPH in forum 2012-2019 (F30, F32, F33, F34, F36)
    Last Post: 03-12-2018, 12:57 PM
  3. Replies: 26
    Last Post: 06-25-2013, 11:55 AM
  4. Replies: 0
    Last Post: 08-07-2003, 02:41 PM
  5. Pics from Active Autowerks Meet and Dyno day
    By Breyton E36 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 05-08-2001, 10:51 PM
