Results 1 to 4 of 4
Thread: OBD Flash Tune From Active Autowerke **No ECU REMOVAL REQUIRED**
    Jan 2017
    Las Vegas
    Talking OBD Flash Tune From Active Autowerke **No ECU REMOVAL REQUIRED**
    Can be done from home with the use of the Simon Cable.
    You still have the option to send your ECU to Active direct if you do not wish to purchase the Simon Cable.
    Active Autowerke offers unparalleled performance software. Through careful remapping of the factory BMW DME tables, various elements such as ignition timing, fuel delivery, and part throttles are reworked to create performance gains.
    The Active Autowerke upgraded software is designed to operate with gasoline that has an average octane rating with full emissions to create a clean burning combustion with good AFR’s all within factory specifications.
    Available Options:
    • Cold start delete
    • Stage 1 or Stage 2 maps for 91-93 octane
    • Off Road Only Downpipe Map
    • Burble Option
    • Tuner flag removal
    • OBD Flashing Option
    Performance Specs:
    • Up to 80hp gains : Rear wheel HP measured on the dyno
    Attention Florida Customers: If you are local to Active Autowerke (9940 SW 168th Terrace, Miami, FL 33157), there is no need to purchase the Simon Cable. All you need to do is purchase the map from Extreme Power House and drive down to AA for a free install.
    This is an OBD flash tune, no need to remove the ECU
    Dyno from a customer.
    Car mods: Catless Downpipe
    Note: Car is using stock intercooler. Temps were going over 180 degrees on high RPM which caused the ECU to cut power.
    A car with a quality aftermarket intercooler will make even more power on high RPM.
    Same customer, same day same car with Active A piggy.
    Im posting this A8 dyno to showcase the power delivery difference between the Active flash and their piggy.
    F30 335 Stock (With Downpipe) vs Active Autowerke OBD Flash Stage 2 +65whp / +109wtq
    (notice how important a quality FMIC is to this car. it loses a lot of power after 5500 RPM)
    F30 328 Stock vs Active Autowerke stage 1 +24 whp / +68 wtq
    Jan 2017
    Las Vegas
    Jan 2017
    Las Vegas
    328 stock vs stage 2 (flash + Wagner Downpipe)
    Jan 2017
    Las Vegas
  1. Replies: 26
    Last Post: 06-25-2013, 11:55 AM
  2. Replies: 0
    Last Post: 08-07-2003, 02:41 PM
  3. Pics from Active Autowerks Meet and Dyno day
    By Breyton E36 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 05-08-2001, 10:51 PM
  4. Some pictures from Active Autowerke Open House...
    By Kevlar in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 05-07-2001, 06:20 PM
  5. Pics from Active Autowerks meet and dyno day
    Last Post: 05-07-2001, 10:56 AM
