Hello because of that
Wiper linkage repair sets Can you also check me here and reach me via PM.
https://www.bimmerforums.com/forum/s...8#post29928808
There you can see pictures .
greetings
Update. I did get set of bushings from AirStrike. Today I finally got to taking all this apart. Linkage assembly wasn't bad at all. Large bushings were like new (driver side), smaller ones had some wear but nothing like in pictures in this topic. Good news that there was no corrosion, all came apart nicely.
I had to machine some basic rods to press out and press in bushings. I have press but it can be done with bolts/etc, there is not much force required. However, because of sizes - will be hard to find proper size bushes..
Now everything feels tight, didn't finish assembly yet, need to get some plastic clips and lost one metal clip that holds fan cover. Whole disassembly is kind of pita, wonder if I should replace fan while I'm there..
Speaking of bushes themselves - they fit perfectly. Large ones is not the same as originals (taller) which seems better because of bigger surface area. But it really doesn't matter because large ones hardly wore out. Smaller ones (passenger) is perfect fit.
I revised the pictures above again
