I've been collecting parts and need to clear some space in the garage. I can provide more details via PM and I'll be adding information as I have a little bit more time to add it. I'm a reasonable guy so make me an offer on multiple parts. The transmissions I would prefer not to ship.
All the parts are used, around 10k on the turbo manifold and wastegate, less on most other things, transmissions are 100k+, prices don't include shipping, open to offers.
3" stainless steel exhaust from center magnaflow muffler to rear. No rear muffler since I'm reusing it with the new parts.
3" vband and clamp. This would help someone if they want to fabricate a downpipe and install a rear muffler. It routes from the middle of car and tight to subframe. May have clearance issues with the rear sway bar depending on length of rear muffler and where you put the middle hanger at. $100
Shallow angle T3/T4 Oil drain I welded it up to gravity drain off a TT manifold, may work with others but will also depend on fitting in the oil pan $50.00
M52 Oil Pan with drain fitting welded on $150.00
M50 Oil filter housing $50.00
Bimmerworld Diff Bushings installed, with cover, $100.00
front delrin bushing drilled for 14mm bolt
Rogue Engineering Short shifter in carrier, delrin carrier bushings, selector rod $125.00
RC 750cc Fuel injectors $100.00
Factory S52 motor mounts, good shape and no annoying poly vibrations $50
Aeromotive Stealth 340 PUMP SOLD
Siemens Deka 80 lb fuel injectors (these are still installed in the vehicle) SOLD
6262 Journal Bearing Turbo T3 .82 housing SOLD
Tial 38 wastegate SOLD
ZF310 SOLD
ZF320 SOLD
ARP M50 Head studs SOLD
Clutchmasters FX400 /AASCO Lightweight Flywheel(7k miles) SOLD
5 speed sport shift knob SOLD
Twin disc 7.25" clutch quartermasters (3k miles) SOLD
button flywheel
automatic flex plate
tilton TOB
Technique Tuning Manifold/ downpipe/ SOLD
Wow pm'd about a bunch of stuff
Pictures sent
PM'd
Updated, turbo is off and ready for a new and loving home.
Manifold should be off by the end of the week!
If you still have the pump I may be interested tommorw
Sent from my SM-G935V using Tapatalk
Updated first post to reflect current availability.
More stuff gone, get it while it's hot.
Is the mani bottom-mount? Got any pics? I might be interested in the mani and DP.
"You don't win silver....you lose gold."
Yes it's a bottom mount. I should be able to scrounge up pictures of it going together and get them to you tomorrow. Shoot me a pm
Still have the turbo? Sending PM
96 328is turbo. Built 3.2, 6266, RSI Manifold
I know somebody wants a 62mm turbo and manifold!
Any pictures of the manifold and is it top mount or bottom mount.
Bottom mount.
Sorry about the picture mix up! Check your PMs
PM'd
Updated first post. Help me pay for my new turbo setup!
More parts gone. Still have a turbo and a wastegate waiting for a happy home.
More stuff gone, more stuff added!
Do you know how many miles are on the injectors? any pictures of them by chance?
I do not have an exact mileage. Looking at my notes it should be less than 10k and more than 2k. Sorry I don't have a more accurate mileage than that.
Essentially I put them in the car with the first PCM I had and maxed their flow rate out with a stealth 340 pump. The car drove a little bit but was limited operation because of an oil leak. I built an engine and the car sat before running again about a year later. They came out when I swapped to a different PCM basically the next year after the built engine was installed.
Shoot me a PM with an email and I'll get you some pictures.
Added exhaust.
Can you text me about the exhaust 5035078967
1997 BMW ///M3 - Estoril Sedan 5MT - M-Rain Interior (1 of 1)
2001 BMW ///M3 - Laguna Seca Blue 6MT
YouTube: (///Motorsport Throttle) https://www.youtube.com/channel/UCUM...pYSmibzy5YmUvQ
