Hello. I have a weird problem with my '95 325. When I turn on a turn signal (either one), the four-way flashers go on. Sometimes intermittently, the correct signal will flash a few cycles, then the four-ways will go, then back to one signal for a few. This is very annoying, I expect that I am confusing others on the road with my erratic signaling.
Thoughts? Thank you!!
Not sure but It may have to do with the crash relay.
crash alarm relay probably https://www.bimmerforums.com/forum/s...ht=crash+alarm
OK, I found the Crash Alarm Relay and disconnected it. The problem still manifests (both signals flash when either turn signal is activated); the four-ways do not operate with this relay removed (probably stating the obvious). I am wondering if it is the Turn Signal Flasher Relay, but for the life of me, I cannot find it (even in the Bentley Service Manual), it seems this manual is pretty silent on the turn signal system. It sounds like the turn signal relay is in the steering column, but I cannot figure how to get the caver(s) off, I will keep looking... Thank you for the help.
Country,
Here is the diagram you are looking for (just a quick Google ). I recently had some weird issues with my '98 328i's blinkers as well and changing the turn signal relay resolved the issue. I took the old relay out, smacked it around a bit and it worked briefly before failing again. New relay works flawlessly.
https://www.justanswer.com/uploads/L...03755_dist.jpg
http://forums.pelicanparts.com/101-p...-location.html
The cheapest place I found the flasher from was RM Euro. Someone correct me if I'm wrong but I *think* Wehrle is an OEM?
http://www.rmeuropean.com/Products/6...G206-V214.aspx
Thank you. I finally found the correct wiring diagram in the Bentley manual and noticed that the turn signal relay is the same one used for the four way flashers. I will look at getting a new flasher relay. Thank you again!
I was having a really odd problem with my turn signals going haywire. My flashers were working, and no bulbs appeared to be compromised, but when I turned my blinker on, flashers would trigger sometimes and overall it was really odd. I replaced the front turn signal bulbs and everything went back to normal. Just a thought!
This sounds similar to my issue. I would use the right turn signal once, and after that it would stop working entirely. Left turn signal would work a few times and then sometimes it would stop as well. I could take the relay out, tap it with a screwdriver a few times, it would work for maybe 15 minutes and then have the same issue. In my case bulbs were not the issue but they definitely can be if they are not making a good connection.
I'll have to look at the wiring again but IIRC the hazards work by triggering both the left and right 'sides' of the relay at the same time. The turn signal relay has two smaller relays on a circuit board inside of it for each side of the turn signal circuit.
I remember people posting that there were cracked solder points in the relay, so they may be repairable.
Well, got the new Hazard Relay from Pelican Parts. Installed this morning and, voilą, the turn signals now work. Piece of cake. Thank you all for the advice.
Right turn signals work but flash fast. All the headlights work too. Drivers side parking light on and high beam only...nothing with turn signal on. Checked bulbs no change. Hazard button gets me nothing. Flasher relay?
