Results 1 to 21 of 21
Thread: Is the Automatic Transmission the culprit?
    Feb 2014
    Squamish, BC, Canada
    1997 BMW Z3 Roadster
    I have two '97 1.9 roadsters. The one I have had for a few years is an automatic, R/H drive, from Japan. I bought the second one a couple of months ago in New York and drove it to British Columbia by way of Texas and San Diego, a distance of about 5500 miles. Most of the distance was freeway driving, avg 70-75 mph in fifth gear. I got about 30 mpg (US gallon). Of course, the automatic one is in kilometers, but after conversion, the gas mileage I get is about 20 mpg. In a quest for better gas mileage I have replaced the plugs, ignition wires, and distributor, (with little or no effect) The transmission is a GM. Is this a normal spread when comparing gas mileage between std. and auto transmissions?
    The Future ain't what it used to be.
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E39/2 E46
    My old 318ti with the same powertrain did 25, and I was not kind to that hateful car. I would dig deeper. Did the TCC work?
    Boiling Springs, PA
    '02 Z3 3.0i/'10 Cooper S
    Not a normal spread from anything I've ever read.
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    Quote Originally Posted by WWPierre View Post
    I have two '97 1.9 roadsters... an automatic... bought the second one a couple of months ago in New York and drove it to British Columbia... about 5500 miles... freeway driving, avg 70-75 mph in fifth gear. I got about 30 mpg... the automatic one... is about 20 mpg... Is this a normal spread when comparing gas mileage between std. and auto transmissions?
    I could be a normal spread from a road trip in the heat, to stop and go driving with stops for errands, in the Canadian winter.
    My 1.9 manual gets 30 mpg on my short trips, but that falls to 24 mpg in winter suburban pleasure drives. If I was to use the Z3 for the kind of daily winter driving my Subaru gets, I would not be surprised at 20 mpg.
    BMW MOA 696, BMW CCA 1405
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    Not sure about 1.9s, but manual and automatic 2.8s have a different diff ratios, causing automatic to use more gas (~10% on average) even in straight line.
    Dec 2007
    Great Dismal Swamp
    Overall top ratio:
    Auto = 3.21
    Man = 3.45
    Find a different scapegoat.
    /.randy
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    Overall top ratio:
    Auto = 3.21
    Man = 3.45
    Where did you got those numbers? Diff ratios:
    1.9 auto = 4.44
    1.9 manual = 3.45
    2.8 auto = 4.10
    2.8 manual = 3.15
    Dec 2007
    Great Dismal Swamp
    Not diff ratio, OVERALL ratio. Diff X Trans ratios is what matters.
    4.44 X 0.723 = 3.21
    3.45 X 1.00 - 3.45
    The automatic is geared taller.
    /.randy
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    Which means on freeway driving 1.9 automatic should theoretically get even more mpg than manual...
    Oct 2012
    Louisville, KY
    It seems that for any car, the automatic version is always geared taller, makes fewer rpms per mph, and gets better mileage.
    My 2006 Scion xB manual may be an extreme example:
    Manual -- Combined Final Drive (5th gear) = 3.514 making 4090 RPM @ 80 MPH.
    Automatic -- Combined Final Drive (4th gear) = 2.910 making 3410 RPM @ 80 MPH
    At any speed, the automatic RPM in 4th gear was 17% less (680 rpm) than the manual in 5th gear.
    Dec 2007
    Great Dismal Swamp
    If all that mattered was ratios, then yes, most automatics would win. But there are many more factors involved. Weight. Efficiency ( auto has power sucking hydraulics). And then there is that thing doing its job so well, converting torque into heat. The torque converter alone is a major killer of mileage, and why a properly functioning TCC system is important.
    Quote Originally Posted by Vintage42 View Post
    Up until somewhat recently, autos got worse mpg than manuals, not betrer. As Randy mentioned RPM is not all that matters, the torque converter sucks up power sapping mpg away. Looking at fuelly, manual scion xb's have higher mpg on average. This should be the same for the z3, I would expect a manual to get better mpg, but only by 1-3mpg max.
    Jun 2016
    Odessa, TX
    2000 BMW Z3 2.8 Roadster
    Back when I was looking at newer cars, the manuals always had a better mpg rating. Toyota tends to lag behind... basically everyone in terms of improving efficiency etc, so they should still be a relatively good example of automatics getting worse mileage than manuals without having to dig particularly deep. Usually they do weigh more and the torque converter loses a lot of energy to heat via friction (I think my material said friction from the fluid being directed around its paths), as Randy has noted already. Modern autos are significantly better, but the 4L30E is basically a TH180 with an extra section tacked on... And the TH180 was developed in '69 or something, which makes it slightly more modern than my parents.
    Oct 2012
    Louisville, KY
    Quote Originally Posted by BimmerBreaker View Post
    Up until somewhat recently, autos got worse mpg than manuals, not betrer... .
    We are comparing highway miles to overall miles. I was using a specific example of cruising in top gear in a 2006 xB, where a 680 rpm difference gave the automatic better mileage.
    I agree that for mileage, automatics are now as good or better than manuals.
    For instance, in 2015 the manual xB was rated at the same overall mileage as the automatic = 22/28 for both:
    https://g.co/kgs/j6ibUf
    In 2017 the BMW 320i is rated essentially the same for both:
    Automatic = 23/35/28
    Manual = 23/35/27
    https://www.fueleconomy.gov/feg/bymo...3_Series.shtml
    For the 2017 Mazda6, the automatic is better:
    Automatic = 27/35/30
    Manual = 24/34/28
    https://www.fueleconomy.gov/feg/bymo..._Mazda_6.shtml
    And for the 2017 Honda Accord, the difference is dramatic:
    https://www.fueleconomy.gov/feg/bymo...a_Accord.shtml
    As I said in #10 think that for any car these days, the automatic is rated the same if not better than the manual. Especially the Hwy rating where the gearing of the automatic or CVT is taller.
    Dec 2007
    Great Dismal Swamp
    You are mixing many technologies and transmission types into the broad band of "automatic". For instance Honda has never made a true automatic, only hydraulically shifted manuals. DCTs are now popular and commonly called an automatic. Computer shifted manual.
    Bottom line is the 4L30 is a classic GM design from the 60s with a bit of early 80s grafted in. It will NOT ever be an efficient unit. But the OPs mileage is still sub par, even accounting for the lump.
    Jun 2016
    Odessa, TX
    On that note, totally change the fluid. Might help delay the development of issues like solenoids sticking.
    When you drive across the country, you sample gas qualities that might vary pretty decently. Plus changes in elevation and ambient temperature.
    In New Mexico, I could get 30+ mpg uphill with passengers and the a/c blasting; in the same car, flat terrain, no passengers or a/c, I was getting 20-24 mpg in TX. That may be part of the issue.
    Have you made a list of factors that change fuel mixtures? You can do that and go down the list and check components for wear and faulty operation.
    Nov 2005
    Finland
    Z3 Coupe individual
    Oct 2012
    Louisville, KY
    That is the old automatics. The 4-speed auto in my 2008 Subaru could be the worst.
    The 8-speed automatics in the new BMWs etc are better in every measurable respect than manuals, except pleasure.
    Oct 2012
    Louisville, KY
    You are mixing many technologies and transmission types into the broad band of "automatic"... Honda has never made a true automatic, only hydraulically shifted manuals...
    I was just saying that nowadays automatics get as good or better mileage than manuals.
    The lady across the street has a 2015 Accord automatic and I don't know if it was hydraulically shifted, but it does shift by itself.
    Jun 2016
    Odessa, TX
    The new autos are simply amazing improvements. We're doing incredible things these days.
    Unfortunately, the 4L30E was basically ready for retirement before it was even implemented. That's how I feel, anyway.
    Burlington/Freehold NJ
    Z3, 528i, M5, X5, Jetta
    I know what you mean. I have the 4L30E in my 528i. Luckily in a larger car like that it does a pretty good job. Overall combined City/Highway for me is 24.1 MPG.
    1999 528i - Titanium Silver over Silverstone/Black Leather, Sport
    2000 Z3 2.3 -Topaz Blue over Sand Beige, Sport
    2003 M5 - Imola Red over Imola Red/Black, Sport
    2004 X5 4.8is - Estoril Blue/Black
  1. is the 528e automatic transmission the same from 1981-1988??
    By picture this in forum 1982 - 1988 (E28)
    Last Post: 01-03-2011, 12:49 AM
  2. How strong is the automatic transmission?
    By SC 325ic in forum 1983 - 1991 (E30)
    Last Post: 04-22-2008, 09:00 PM
  3. Automatic transmission:the cost of fluid change?
    By russoturristo in forum 1996 - 2003 (E39)
    Last Post: 02-26-2008, 03:33 PM
  4. Replies: 2
    Last Post: 12-03-2006, 04:19 PM
  5. Is there automatic in the 2003 M3's?
    By Bailey in forum 2001 - 2006 M3 (E46)
    Last Post: 01-02-2003, 05:15 PM
