I just replace my cracked expansion tank and went through the process of filling bleeding filling bleeding and then took the car around the block.
With the engine at normal operating temperature the coolant light is coming back on. I checked the level in the expansion tank and it was fine.
The tank came with a new sensor already installed. What are the chances that that is bad? Is there a way to test it without pulling it?
Thanks in advance.
Check in the morning on a cold engine, fill to proper level-repeat for 2-3 mornings, all air pockets should be removed by then.
"It's not how you race your car, it's how you stand by your car, you better learn that".
Edited version
The level sensor can be pulled without loosing any coolant. You could just swap in the new one and see if the lamp stays off.
Also double check, triple check the bleeding, as there could still be air trapped in the system.
Darin
Current:
05 325it Electric Red(438)/Gray(N6TT) ZCW, ZSP 5sp Manual Back set cover, trunk mat, Euro Infra-Rot front windshield, and mud flaps! Mr. Wagon (Original Owner)
05 M3 Imolarot II(405)/Gray(N5TT) ZCW, ZPP 6sp Manual C.F. Lip, CSL diffuser, Euro Infra-Rot front windshield and a trunkliner! Mr. Go_Fast (Stored for the Winter, 2nd Owner)
Past:
95 318is Montreal Blue Met (297)/Beige(K1SN) A Hooptie! (10th Owner; That is what happens when it gets passed around by Soldiers!)
84 M535i gray market Burgandy Rot Met/Black Leather Lowered by Intrax on bilies, poly everywhere, B&B cat back system, K&N, and a hitch! Da Beast - Still running w/375k+! (2nd Owner)
91 316i euro Tizianrot/Gray cloth - E-36 w/M-40 motor, such a beater, but great on gas! Best was 38 MPG (2nd Owner)
79 525 euro Green/Green RIP
M-Flight Member
What brand are the new twnkbsbd the sensor?
Tank is Behr.
I popped the cap off this morning and the fluid level was showing full. Started the car up and let it run for a bit and the light came back on.
There is only the one bleed screw at the expansion tank correct? I cracked it and filled slowly until the fluid was coming out. Will attempt the entire bleed again tonight before I attempt to squeeze my hand down to swap out the sender.
Behr is the OE supplier to BMW for that part IIRC. Try this: After coming home from a drive, open the bleeder screw and see if any air comes out. Normally there will be a little, and then you will see some coolant. I have to do this a couple of times with the heater on MAX, and when the thermostat opens up, it gets rid of the rest.
Darin
Current:
Past:
M-Flight Member
Humm, since you have only coolant coming out, and have normal heat, I would swap the sensor.
Darin
Current:
Past:
M-Flight Member
Yes, It seems the clue was obvious in your first post,
"The tank came with a new sensor already installed."
Was this a BMW genuine OE or OEM expansion tank?
Edited version
Darin
Current:
Past:
M-Flight Member
Thanks for exposing my obvious oversight!
OP check for a dry and clean connection at the tank, as well as the wiring for breaks.
I would also check if the movement of the red stick in the tank was smooth,
and not sticking. Test it by having someone push the bobber down,
while you check the dash light operation.(on a cold engine)
Edited version
Btw, the coolant level sensor is at the bottom of the tank,
why would you "attempt to squeeze my hand down to swap out the sender"?
Just access it from the bottom.
Edited version
Replaced the sender that came worn the tank with the original and tested all good.
