Results 1 to 9 of 9
Thread: Brake system replacement on 2003 325xi
    May 2010
    Bellevue WA
    2003 BMW 325Xi Sports
    LeSchwab tire folks checked and recommended me to replace brake pads/rotors/calipers on front wheels.
    Estimation is about 500$.
    Does this sounds good ? normal ?
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    Why the calipers? Are they seized? OEM supplier rotors and pads (ATE, Pagid, or Jurid) can be bought for around $200 shipped from a few online sources.
    Jan 2016
    Ca
    2001 525it
    Don't let les schwab touch your car there going to put on crappy brake parts on it. I have been involved with BMW's for years and we rarely replace calipers
    Sep 2008
    Sandy, Oregon
    2002 330Ci, 1995 325is
    Les Schwab is competent to put tires on a car maybe. For anything else do it yourself or find someone to do it for you. It's a very easy job. Like others have written, it's unlikely you need new calipers. They are very easy to rebuild, and it's a cheap fix.
    Quote Originally Posted by Gana325xi2003 View Post
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Find a reputable indie shop that specializes in bimmers. Try www.bimrs.org. Also, check the website for the puget sound chapter if the BMWCCA.
    Mar 2014
    AL
    X5
    Or just buy parts online and have them installed by a reputable shop.
    May 2010
    Bellevue WA
    Thanks for all the responses.
    I am thinking of getting it done using a separate labor with my own parts. Local autozone has the required parts by Duralasts brand. Good enough ? or do I have to go for more better ?
    Bellevue, WA
    335d, 328xd (had 330xi)
    Many shops won't install outside parts. Not enough money in it for them. If you can find one, good.
    May 2010
    Bellevue WA
    Quote Originally Posted by MarcoZandrini View Post
    Found an Indy shop in my zipcode 98007 using bimrs.org. The Indy shop is giving a rough estimate of 1000$
  1. Battery replacement on 2003 325xi
    By Gana325xi2003 in forum 1999 - 2006 (E46)
    Last Post: 01-07-2018, 11:36 PM
  2. M5 Brake System Retrofit on a 525i Highlights
    By stilljester in forum 1996 - 2003 (E39)
    Last Post: 10-29-2015, 09:08 PM
  3. thrust (control) arm bushing replacement on 2003 530 question
    By jasper7821 in forum 1996 - 2003 (E39)
    Last Post: 08-15-2009, 12:59 PM
  4. Replies: 10
    Last Post: 08-14-2009, 03:03 AM
  5. $1000 off on 2003 325xi
    By balajc in forum 1999 - 2006 (E46)
    Last Post: 07-24-2003, 09:21 AM
