The choice of OEM size 195/65/14 tires is extremely limited. I see lots of post about this but do not see anyone say go to the 195/70/14 size. There are a lot of choices in this tire size. Also if this tire is a larger diameter tire, it may offset the over speed reading on many e30 speedometers, like my 325ic automatic which is 5+ % high. Why wouldn't this be a good tire to select?
Too tall. Also, in that size they are likely to be tires made for less performance oriented cars with floppy sidewalls. What about 205/60?
The difference between 65 or 70 series sidewall is about 5 mm, it s not that much, your ride could be a little more soft with the taller side wall
70 will be 3% bigger and accordingly the sky shouldnt fall down, though i will pray for you
Thanks for your prayers and comments. Since by the time, I buy new tires, there will be no 195/65/14 or very, very limited, I'll have to switch to a different size. 185's are too small. Since car is a convertible and not interested in max performance, I see really not much difference in 195/70 vs 195/65, I'll go with the 70's. A pretty good selection of some better tires and also will lessen the speedometer error.
I just had to replace my 10 year old 195/65/14 Michelins (which still had a ton of tread but dry rotting), and encountered same problem with selection in that size. My 318 is stock height and used for cruising. Got some 195/70/14 Falkens put on this morning and they fit just fine. Thought I would share. Cheers.
'92 318i Cabrio- Alpine White
We are about to install Falken ZIEX 195/70/14 on our 325e; I'll try to remember to post a report afterward.
Jeff
1984 320i Baur TC2 5-Speed Opalgrün (Jeff's)
1987 325e Sedan A/T Zinnoberrot (Dawn's)
1984 633 CSi 5-speed Bronzit (Ours . . . if she says so)
Where do you get them installed? Please post a review of your Falkens when you get a chance. Thank you.
kick,
I get them installed and balanced at the local tire store from which I buy them; never had a problem.
Jeff
These have my curiosity. 195/65r14
https://www.tirerack.com/tires/tires...RatingsReviews
Anyone have any experience with Vredesteins?
not those in particular but i have bought the weird brand names ands had no problems. they still have to pass whatever requirement to be used on the roads so I figure they are ok enough. all the odd brand sets i got from discount tire online and had them shipped to me, or from tire rack or national tire and battery
No e30s again.
