Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 10 of 10
Thread: Rear wheel change
    Jan 2018
    Bandon, OR
    2000 740i Sport,
    Rear wheel change
    On my 2000 740i sport, it has the 18" x 8" M37 wheels on all four corners.
    I am considering changing out the rears to the 18" x 9.5" wheels.
    My question at this point is if there is any advantage / disadvantage to doing so?
    I notice currently that rears don't stick out as far as fronts do.
    Any one out there done this to date?
    Any input would be appreciated.
    What are the specs? If BMW thought a staggered geometry for the wheels would be better, they would have done it as they do on many. My 01 X5 had staggered 20s that looked and handled great.
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    Using Tapatalk
    Aug 2013
    1999 BMW M3 Coupe
    If they fit and you're only driving it on the street, no it won't really change anything in a meaningful way.
    The sport package for that car is supposed to have a staggered setup with 235/50 front and 255/45 rear tire, which I assume is what you have now. Just going to a 9.5 inch rear wheel with the same tire in the rear will make it a little more flush, but you can also do the same thing with wheel spacers for much less $ if you just need to kick your wheels out closer to the fender. The main reason to run wider wheels is so you can run wider tires, in your case wider than a 255 in the rear. On the street there probably isn't a ton of reason to do this since all you'd do is reduce gas mileage.
    Check out some quality wheel spacers from somewhere like Apex. Something like a 12mm spacer is probably all you need, but you can measure. You'll also need to get new lugs or install wheel studs if you do get spacers since they'll need to be longer.
    Jan 2018
    Bandon, OR
    2000 740i Sport,
    This particular car has same size wheels and tires on all four corners. The wheels are 18" x 8 " and tires are 235/50-18. It is not currently a staggered pattern. The owners manual for the vehicle shows the 18" x 9.5" wheel listed in the Tire and Wheel specs.
    If I decide to change out the rears, other than changing tires, is there any thing else I would need to do to make the change.
    I also find it curious that BMW selected a shorter tire for the 9.5" wheel.
    2.25 mm, about 1/10th of an inch. I think they make it right somehow
    Using Tapatalk
    Jan 2018
    Bandon, OR
    2000 740i Sport,
    Thanks dano,
    Do you own a E38?
    Quote Originally Posted by 1stbeamer View Post
    Thanks dano,
    Do you own a E38?
    I've only had 5 and 3 series
    Using Tapatalk
    Jan 2018
    Bandon, OR
    2000 740i Sport,
    I find this car to be most amazing. The performance is substanial especially for how heavy the car is.
    I also just purchased 2 of the 18" x 9.5" wheels off of ebay. Remanufactured oem BMW and a decent price.
    Aug 2013
    1999 BMW M3 Coupe
    Just make sure your total wheel height including tire is close to the original (this can change a bit if you go to a wider tire or thicker/thinner tire). And obviously, make sure the wheel offset is close enough to your current wheels that it will fit and not rub on your fender.
    Jan 2018
    Bandon, OR
    2000 740i Sport,
    Thanks for your response Tostito Bandito.
    As I had mentioned in a previous post, the owner's manual specs the 9.5" wheel.
    The vehicle currenty has Cooper 235/50-18 Zeon RS3 A tires with overall dia. of 27.28"
    I will purchase cooper 255/45-18 Zeon RS3 A tires for the rear which has overall dia. of 27.09"
    I don't anticipate any problems but will pay close attention to all clearances with new wheels and tires.
  1. how long to change a rear wheel bearing on a 94 318 is
    By gerry99 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-29-2008, 10:06 PM
  2. e36 rear wheel bearing change tools
    By mlytle in forum Middle Atlantic - US
    Last Post: 11-13-2007, 12:51 AM
  3. Changed the rear wheel bearing on my 328
    By srj in forum 1991 - 1999 (E36)
    Last Post: 05-09-2007, 02:31 PM
  4. How much to change rear wheel bearings
    By cpltk2 in forum 1983 - 1991 (E30)
    Last Post: 04-05-2006, 09:21 PM
  5. Changing E39 rear wheel bearings?
    By jmig in forum 1988 - 1996 (E34)
    Last Post: 04-30-2005, 10:48 AM
