Results 1 to 7 of 7
Thread: 840 Accelerator pedal sticking--solved
    Feb 2016
    Brooklyn, NY
    1995 840Ci, 2013 X5
    Apparently, this is a common problem and it applies to both 840's and 850's. My symptom was an occasional stubbornness to return to idle--RPM's stayed a little higher than they should have been. I could hook a foot under the gas pedal to return to idle. The culprit turned out not to be a sticky cable or weak spring as I expected, but a failed bushing on the accelerator pedal, allowing the pedal shaft to float away from the recess in which it resides. 850's use the same mounting system, but without the throttle cable.
    There are two number 8 bushings, but the one that failed is not shown. It sits next to spring number 11. It looks like my lead foot pushed on one end of the accelerator shaft, levering out the other end, destroying the bushing and allowing the shaft to float around a little. The system is not particularly well designed--too fragile, with only thin plastic bushings retaining the shaft. I was only able to recover two small pieces of the bushing, which leads me to believe that the bushing was shattered for some time before symptoms arose. If these bushings degrade with age as I suspect, more cars will exhibit this issue. The replacement is part number 35411154172.
    Anyone opening up the footwell for GM repair, brake booster repair, or any other reason should check these bushings. I could have caught this last year when I did my GM repair but there were no symptoms and I didn't know to look.
    Hope this saves someone some time!
    Brett
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Thanks Brett, that's great information!
    My BMW Repair YouTube Channel
    Dec 2013
    San Antonio
    850,76 2002 &530,84 633
    I found those bushings in pieces on my car a couple of months while removing the GM. Thank goodness the parts are still available so I have already replaced them. I did have a bit of trouble getting the darn spring back in place!
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    already replaced them in my E32 750 8 years ago, should last with new bushes another 15 years now.
    In 2010 we did it on 3 cars in our wrenching group http://alpinakozou.web.fc2.com/file/.../20100103.html
    Jun 2013
    Auckland, NZ
    1994 E31 850CSi
    This issue has been previously reported, quite recently, on this forum:
    https://www.bimmerforums.com/forum/s...hlight=bushing
    Current:
    1994 E31 850CSi Sterlingsilber/Anthracite Buffalo
    Previous:
    1987 E28 M5 Delphin
    1986 E23 M745iA Arctic Blue
    1986 E24 635CSi Polaris
    1976 E3 3.0 Si Arctic Blue
    Orlando, FL USA
    Agreed, and thanks to Dragon850's DIY write-up, it was a breeze to repair/replace. Not hard to do, just time consuming. The difference is night and day in terms of pedal feel, engine response and acceleration. No more lags.
    Anyone tackling this job, remember to order a quantity of 2 of the part #8 as listed by the OP. I made a mistake of ordering just one and then had to do a reorder and paid the dumb shipping fee twice.
    Feb 2020
    Gold Coast Australia
    1995 840ci
    I recently did this to my 840ci
    First time I've done anything like this so was a bit worried but was pretty easy. My pedal was a bit sticky every now and then so I ordered the parts. They arent expensive and I was fine them taking their time arriving.
    Three things to take off:
    - leather cover
    - pedal plastic cover
    - an air flow plastic bit (kinda fell out)
    I was indeed correct, one of the bushing was in two pieces.
    All easy to get out. Only thing that had me stumped was the detaching the accelerator cable from the bar. Eventually worked out you just push it through.
    Gave it a clean. New bushings. Greased up and put back in. Putting the accelerator cable back in again very difficult.
    Hope this helps
    Ben
  1. Stick/slip effect in accelerator pedals
    By sudnut in forum 1999 - 2006 (E46)
    Last Post: 04-03-2011, 09:57 AM
  2. Accelerator pedal sticking!
    By peanutpower in forum 1991 - 1999 (E36)
    Last Post: 03-29-2007, 11:04 PM
  3. accelerator pedal
    By 76Dragon in forum 1999 - 2006 (E46)
    Last Post: 06-15-2002, 12:30 AM
  4. Accelerator Pedal Problems
    By 76Dragon in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-21-2002, 08:14 PM
  5. clutch pedal sticks
    By jesd325is in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-23-2002, 09:55 AM
