Results 1 to 5 of 5
Thread: Big Deal About Ride Height?
    May 2014
    El Paso, TX
    2001 BMW 330xi
    What is the technical reason that ride height is such a big deal, especially in cars without headlamp adjustment? I put Bilsteins on my E46 and was obviously scolded by the dealer technician that was doing my alignment. He had to adjust every screw he could get to to get it within specs.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Did you change the springs, as that is what really makes the ride height, not the shocks. The AWD cars sit higher than the RWD cars, and you cannot use RWD shock/springs on a AWD car.
    Ride height is determined by the Engineers who designed the car to ensure proper clearance and tire wear.
    Did Eric at BMW of El Paso do your alignment by chance?
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    The added ride height for XI's is meant to make use of additional ground clearance in snowy/difficult terrain. Aftermarket lowering springs on a XI can cause problems in two fashions: 1. Lowered front CV geometry can cause accelerated wear of the axles. 2. Mismatched spring rate and shock valving can make the ride harsh, or erratic. You can use OEM sport/sedan springs with Bilstein B4 or B6 shocks but I wouldn't go much lower.
    Additionally, I've found that the factory camber setting for the front is a bit aggressive and can cause rapid wear on the inside shoulder of the front tires specifically in AWD applications. In my recent alignment I had the cambers backed off by half a degree and the tire wear has stopped without a noticeable difference in cornering feel.
    May 2014
    El Paso, TX
    2001 BMW 330xi
    Your replies make sense, especially about sensitivity to spring height. Since the technician was able to bring it into specs I think I am OK. Oh, the alignment was done in Tulsa, but I am glad to know about the local El Paso tech.
    Thanks again for your input.
    dworthy's Avatar
    Nov 2010
    No problem, I have known Eric for over 20 years and he is a top notch tech. When you go in just as for "Figgy" to do any work you may have, as he owns about a dozen BMW's ranging from a 79 320i Alpina clone to a 2012 228i.
    Darin
    Current:
    Past:
    M-Flight Member
  1. Whats the big deal about service records?
    By Vin Diesel in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-30-2007, 03:38 PM
  2. question about ride height of 2001 540i sport
    By tchase in forum 1996 - 2003 (E39)
    Last Post: 10-03-2006, 10:30 PM
  3. Replies: 28
    Last Post: 07-23-2003, 05:59 PM
  4. What is the big deal about vaders?
    By Glenn 328is in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 01-02-2003, 05:26 PM
