Results 1 to 2 of 2
Thread: 1999 328i misfire
    May 2017
    Cordelia,ca
    88 528e
    1999 328i misfire
    So I've been working this 328i that's been a pain . The codes that I'm getting are p1188 and p1189,
    Fuel trim bank 1 & fuel trim bank 2 fuel exceeded
    Misfire cylinders. 3,5,6.
    I've already changed coil packs & spark plugs & fuel injectors.
    I've checked the cab hoses for cracks, nothing there. I've did a comparison test all cylinders are good.
    I have two questions.
    1. When I unplug the maf sensor is the engine suppose to stop running, because the sensor is good. When I unplug mine the engine still runs, and it's kinda hard to tell Whether or not tge sensor is affecting because its misfiring.
    2. There's a exhaust leak from the gaskets , and kinda of think the o2 sensors are bad because t he code came once or twice .
    Where should I start before I just start throwing parts at it . And we all know those German parts can get expensive.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Unplugging the MAF forces the engine computer (DME) into the open loop mode. The DME uses an overly rich fuel/air mix in this mode. This is the same mode whether DME uses when a cold engine is started. The DME does this to get the cats up to temperature quickly. Also, unplugging the MAF masks vacuum leaks.
    Musfires can be caused sed by a myriad of issues. You need to check the fuel pressure. It needs to be at least 50psi. Item #18 in the link is the cap to the test valve.
    http://www.realoem.com/bmw/enUS/show...diagId=13_0644
    plrase stop throwing parts at the problem. Doing so wastes money, doesn’t fix the problem and it angers the BMW goddesses.
  1. 1999 328is For Sale
    By T. Fish in forum BMW Cars For Sale / Wanted (Panjo)
    Last Post: 02-19-2003, 05:10 PM
  2. 1999 328is FOR SALE
    By T. Fish in forum BMW Parts For Sale (Panjo) sponsored by Bavarian Auto Recycling
    Last Post: 12-06-2002, 12:02 AM
  3. FS or Trade: 1999 328is...
    By George in forum BMW Parts For Sale (Panjo) sponsored by Bavarian Auto Recycling
    Last Post: 05-07-2002, 03:29 PM
  4. 1999 328i forsale! gooddeal!
    By JRush000 in forum BMW Parts For Sale (Panjo) sponsored by Bavarian Auto Recycling
    Last Post: 09-14-2001, 05:54 PM
  5. 1999 328is MTechnic for sale.......
    By mt3ch in forum BMW Parts For Sale (Panjo) sponsored by Bavarian Auto Recycling
    Last Post: 09-07-2001, 06:36 PM
