Bavarian Soundwerks
Results 1 to 7 of 7
Thread: Navigation screen
    Jan 2018
    Bandon, OR
    2000 740i Sport,
    Navigation screen
    When I climb in the vehicle and switch the key to the #2 position, sometimes the Navigation/Menu screen comes on and sometimes it dosen't.
    Also noticed that when the screen is off and you drive the vehicle, the radio will play for a few minutes and shut off. I can manually turn the radio off when this happens and then turn it back on and it will play for a short time and then do the same thing.
    If I am correct, the Navigation screen and Radio are controlled by the computer in the battery compartment?
    Any input would be appreciated.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The electronix for the nav and audio system are in the left side of the trunk. The head unit is basically a man-machine interface.
    Is the car having any other electronic or electrical issues? How old is the battery?
    Jan 2018
    Bandon, OR
    2000 740i Sport,
    Marco,
    Thank you for your response.
    Can't get the date off the battery but it appears to be fairly new.
    No other electronic/electrical issues that I can detect at this time.
    One thing I will note, after reading some in the owners manual, it talks about interior and exterior door handle ilumination. I have no ilumination of door handles but not sure if my model has that option.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    I doubt that the door handle illumination ymis related to your nav issues. The battery could be the root cause as how a battery looks isn’t an indication of its condition. I’d have it tested to see if it’s ok. Also, pull the left side trunk liner and inspect the electronix. Make sure all connectors are tight.
    Jan 2018
    Bandon, OR
    2000 740i Sport,
    Thanks Marco,
    I will pull that trunk liner as you suggest and have a look.
    I will also check to see if fuse is gone for door handle ilumination. If so, dead giveaway for a short in the system.
    Back to the battery, everything appears to function propery with the exception of the periodic issue with nav screen.
    I would think there would be cranking issues if there was a problem with the battery. Vehicle cranks and starts just fine.
    Jan 2018
    Bandon, OR
    2000 740i Sport,
    Hey Marco,
    Thought you might enjoy this.
    As it turns out, my vehicle has the outside door handle ilumination feature and it works just fine!
    Really helps when one reads through the owner's manual and learns how to operate things correctly. Duh!
    It's those kind of experiences that are humbling.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Yeah, these cars are overly complex. The techs need a PhD in electronic engineering to properly troubleshoot issues in new BMWs. /s
  1. “wide” navigation screen
    By 2001IL in forum 1995 - 2001 (E38)
    Last Post: 01-31-2007, 06:39 PM
  2. FS - E39 Navigation screen
    By tivic in forum BMW Parts For Sale
    Last Post: 04-06-2004, 10:54 AM
  3. Navigation screen removal to install Aux-In
    By PB_M3 in forum 1999 - 2006 (E46)
    Last Post: 12-11-2003, 10:29 PM
  4. Navigation screen removal to install Aux-In
    By PB_M3 in forum 2001 - 2006 M3 (E46)
    Last Post: 12-11-2003, 08:54 PM
  5. question on in-dash navigation screen
    By HyperHoHo in forum 2001 - 2006 M3 (E46)
    Last Post: 05-28-2003, 01:55 PM
