Results 1 to 4 of 4
Thread: ABS Module question
    Sep 2008
    Sandy, Oregon
    2002 330Ci, 1995 325is
    ABS Module question
    I have a 2002 330Ci with the ABS module under the Brake unit. Has anyone been able to replace the module on one of these without unhooking the brake lines? Can it even be done?
    San Francisco, CA
    e46 330 Touring, e53 m54
    Its impossible to replace DSC ABS module without removing break lines, its not like other BMW where it could be unbolted. On e46 its 1 unit that has to be taken out together.
    Sep 2008
    Sandy, Oregon
    Thanks. That's what I was afraid of.
    Jun 2014
    baku, azerbaijan
    2001 bmw e46 320i
    You can unbolt 2 bolts 1 on the pump and 1 on the side of it and the pump will come out whih holds electronic part of module. And you don't have to bleed the brakes again as you have not removed the part where fluid is.
    I've done it on my car. The bolts are in very unconfortable place but can be done, so good luck with that
  1. Bosch 5.7 ABS module questions
    By mpo in forum 1996 - 2003 (E39)
    Last Post: 11-25-2014, 08:43 PM
  2. ABS module question
    By dvae74123 in forum 1996 - 2003 (E39)
    Last Post: 08-01-2012, 10:28 PM
  3. ABS Module question
    By tavo80816 in forum 1995 - 2001 (E38)
    Last Post: 01-20-2011, 03:41 AM
  4. Quick Question - ABS Module
    By espguitarist in forum 1991 - 1999 (E36)
    Last Post: 08-14-2009, 11:23 PM
  5. ABS Control Module Question
    By MPowerRumbero in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-18-2006, 11:00 PM
