Results 1 to 2 of 2
Thread: Remote key no longer working after flash with NCS Expert (Mini Cooper S R53)
    Jan 2018
    Italy
    Mini R53
    Hi all,
    I've been playing around with NCS Expert on my R53 Mini Cooper S this weekend, so far so good.
    I tryied some functions, some did work, some didn't. At the end of the day, I got out of the car, and now for some unknown reason the remote lock/unlock doesn't work anymore!
    I tought I messed up something with NCS Expert, so I loaded the default VO values of my car (there are tons of guides for this "back to stock" flash).
    This worked (settings reverted to stock) but still the keyfob doesn't work!
    I checked with ISTA-d and DISv44 the Car/Key Memory and the key is still there, in the first slot, exactly where I coded it some weeks ago); other slots are empty, that's ok.
    I don't really know what to do, the dealer is quite far from my location and I can't do such a trip because of my job.
    Below is the NCS Expert config, wich is the stock (seem so, it has been generated by NCS with an empty file) of my car, so it can be checked by some of you that are way smarter than me.
    Big thanks to anybody that will try to help me!
    Code:
    FH_FAHRERTUER_TIPP_AUF	aktiv
    FH_BEIFAHRERTUER_TIPP_AUF
    aktiv
    DWA
    nicht_aktiv
    SCHAERFEN/ENTSCHAERFEN
    schloss_und_fernbedienung
    PANIK_MODUS
    nicht_aktiv
    FUNK_INNENRAUMSCHUTZ
    aktiv
    QUIT_AKUST_SCHAERF
    nicht_aktiv
    QUIT_AKUST_ENTSCH
    nicht_aktiv
    QUIT_OPT_ENTSCH
    aktiv
    QUIT_OPT_SCHAERF
    nicht_aktiv
    NEIGUNGSGEBER
    aktiv
    ALARM_AKUSTISCH
    aktiv
    BEDIENSTELLE_BFT
    nicht_aktiv
    FH_ABSCHALTKRITERIUM
    wert_03
    FH_NACH_TUERE_AUF
    nicht_aktiv
    FUNKTION_CABRIO
    nicht_aktiv
    EINKLEMMSCH_REVERSIEREN
    nicht_aktiv
    ALARM_AKUSTISCH_LANG
    nicht_aktiv
    IB_BEI_KL.R_AUS
    aktiv_mit_kl.58
    KALTUEBERWACHUNG_NSL
    nicht_aktiv
    KALTUEBERWACHUNG_NSW
    aktiv
    SCHEINWERFERREINIGUNG
    nicht_aktiv
    CC_BREMSLICHT
    aktiv
    ALARM_OPT_ABBLENDLICHT
    nicht_aktiv
    ALARM_OPT_FERNLICHT
    nicht_aktiv
    ALARM_OPT_WARNBLINKER
    aktiv
    LEUCHTWEITENREG_AUTOM
    nicht_aktiv
    VERRIEGELN_AUT_AB_X_KM/H
    aktiv
    WISCHERINTERVALL
    wert_01
    ZV_SELEKTIV
    nicht_aktiv
    CLT_AKTIV_IM_CRASH_MODE
    nicht_aktiv
    CODIERUNG_ERFOLGT_1
    codierung_erfolgt
    ENTSICHERN_CENTERLOCK
    nicht_aktiv
    INNENLICHT_AN_MEHRFACH_ZV
    aktiv
    KOMFORTSCHLIESSUNG_FB
    nicht_aktiv
    STANDRUECKSCHALTUNG
    aktiv
    VERRIEGELN_XKM/H_SENDER_1
    aktiv
    VERRIEGELN_XKM/H_SENDER_2
    aktiv
    VERRIEGELN_XKM/H_SENDER_3
    aktiv
    VERRIEGELN_XKM/H_SENDER_4
    aktiv
    VERZUG_PANIK_MODUS_0.2_S
    wert_01
    VERRIEGELN_AUT_NACH_2_MIN
    aktiv
    VERRIEGELUNGSSCHWELLE
    16_km/h
    ABFRAGEZEIT_AHM
    wert_01
    ABSCHALTUNG_UNTERSPG
    wert_01
    ENTPRELLZAHL_FEHLERERK
    wert_01
    KALTUEBERWACHUNG_AL
    aktiv
    KALTUEBERWACHUNG_FL
    aktiv
    ABSTAND_HOLD_NORMAL_MODE
    wert_01
    HALB/VOLLSCHRITT
    vollschritt
    HYSTERESE_STARTBEDINGUNG
    wert_02
    KALTUEBERWACHUNG_BLK_HI
    nicht_aktiv
    KALTUEBERWACHUNG_BLK_VO
    nicht_aktiv
    SCHRITTABSTAND_GRENZE
    wert_01
    SCHRITTABSTAND_STARTPHASE
    kennlinie_01
    TEMPERATUR_GRENZE
    grad_-20
    ABS_MIN_STELLUNG_2
    wert_01
    GED_FL_ALS_DRL
    nicht_aktiv
    HEIMLEUCHTEN
    wert_02
    SCHRITTE_STELLUNG_0
    wert_01
    wert_02
    SCHRITTE_STELLUNG_1
    wert_03
    wert_06
    SCHRITTE_STELLUNG_2
    wert_06
    TAGFAHRLICHT_ECE
    nicht_aktiv
    U_POTI_STELLUNG_0
    wert_01
    U_POTI_STELLUNG_1
    wert_01
    U_POTI_STELLUNG_2
    wert_01
    BLS_PRUEFEN
    nicht_aktiv
    ABSENKUNG_10_KM/H
    wert_02
    ABTASTRATE_DYN
    wert_01
    ABTASTRATE_TREND
    wert_01
    ABWEICHUNG_TREND
    wert_01
    ANHEBUNG_175_KM/H
    wert_02
    ANZAHL_QUICK_RUNDEN
    wert_01
    AUSWERT_GRADIENT
    aktiv
    AUSWERT_PROP_ABWEICHUNG
    aktiv
    DAUER_DYN_NACHFUEHRUNG
    wert_01
    DEF_LWR_SENSOR_HI
    wert_01
    DIFFERENZ_MSP_DYN_STAT
    wert_01
    EPSILON_DELTA_A
    wert_02
    EPSILON_DELTA_AV
    wert_02
    GRADIENT_SCHLECHTWEG
    nicht_aktiv
    HOEHENWEG
    wert_01
    KALTUEBERWACHUNG_KZL
    aktiv
    KENNLINIE_LWR_SENSOR_HI
    wert_02
    KENNLINIE_LWR_SENSOR_VO
    wert_01
    LEUCHTWEITENREG_DYNAM
    nicht_aktiv
    LEUCHTWEITENREGELUNG
    aktiv
    LWR_NEIGUNG_KONSTANTE
    wert_02
    LWR_VORZEICHEN
    wert_01
    M_TELEGRAM
    nicht_aktiv
    MIN_STEIGUNG_VZ_WECHSEL
    wert_01
    MINDESTANZAHL_VZ_WECHSEL
    wert_01
    MITTELUNGSINTERV_DYN
    wert_01
    MITTELUNGSINTERV_TREND
    wert_01
    MITTELUNGSINTERV_VZ_WECHS
    wert_01
    NACHLAUF_SCHLECHTWEG
    wert_01
    OFFSET_LWR
    wert_02
    PWM_ANSTEUERUNG_KZL
    wert_01
    REFERENZL_MODE_TEIL1
    wert_01
    REFERENZL_MODE_TEIL2
    wert_01
    REFERENZL_SCHRITTABSTAND
    wert_01
    REFERENZL_SCHRITTANZAHL
    wert_01
    SAETT_TIMER_SCHLECHTWEG
    aktiv
    SCHW_GRAD_BESCHLEUNIGUNG
    wert_01
    wert_02
    SCHW_GRAD_BREMSEN
    wert_01
    wert_02
    SCHW_GRADIENT_SCHLECHTWEG
    wert_01
    SCHW_PROP_ABWEICHUNG
    wert_01
    wert_02
    SCHW_TREND
    wert_01
    SP_MOTOR_BEWERTEN
    aktiv
    SP_MOTOR_F_EINTRAG
    aktiv
    SP_MOTOR_STOP
    aktiv
    TREIBER_BEWERTEN
    aktiv
    TREIBER_F_EINTRAG
    aktiv
    VMAX_BESCHLEUNIGUNG
    wert_01
    VMAX_BREMSEN
    wert_01
    VMIN_BESCHLEUNIGUNG
    wert_01
    VMIN_BREMSEN
    wert_01
    WARMUEBERWACHUNG_KZL
    aktiv
    ZEIT_KALT_PULSE
    wert_01
    ZEIT_KALT_PULSE_QUICK
    wert_01
    ZEIT_KALT_RUNDEN
    wert_01
    ZYKLUS_KALT_RUNDEN_QUICK
    wert_01
    AC_AUTO
    aktiv
    AC_BASIC
    nicht_aktiv
    AUXILIARY_LAMP_ENABLE
    nicht_aktiv
    BOOT_RELEASE_ENABLE
    aktiv
    CLUTCH_OFF
    wert_01
    CLUTCH_ON
    wert_01
    DAYLIGHT_RUN_POWER
    wert_01
    DEFAULT_EXT_AMBIENT_TEMP
    nicht_aktiv
    DIPPED_BEAM_NAS
    nicht_aktiv
    ENTRIEGELN_B_MOTOR_STOP
    aktiv
    FOG_DISABLE_WITH_TRAILER
    aktiv
    FRONT_FOG_NAS
    nicht_aktiv
    HALTEN_FB_OEFFNEN_TASTE
    ohne_funktion
    HFS
    nicht_aktiv
    HFS_HIGH_TEMP_TIME
    wert_01
    HFS_LOW_TEMP_TIME
    wert_01
    HR_HIGH_BAT_THRESHOLD
    wert_01
    HRW_HIGH_TEMP_TIME
    wert_01
    HRW_LOW_BAT_THRESHOLD
    wert_01
    HRW_LOW_TEMP_TIME
    wert_01
    INDICATE_DURING_HAZARD
    aktiv
    KEY_DISARM
    aktiv
    KOMFORTOEFFNUNG_SCHLOSS
    nicht_aktiv
    MAN_WISCHEN_IM_WASCHPROG
    aktiv
    NO_SOFT_ON_OFF
    nicht_aktiv
    PARKING_LIGHTS
    nicht_aktiv
    POWER_WASH_OFF_TIME
    wert_01
    POWER_WASH_ON_TIME
    wert_01
    REAR_WIPER_CONTINUOUS
    nicht_aktiv
    REMOTE_CONTROL
    aktiv
    SENSOR_REGEN
    nicht_aktiv
    WINDOW_AUTO_UP_DRIVER
    aktiv
    WINDOW_AUTO_UP_PASS
    nicht_aktiv
    WINDOW_INCH_AUTO
    aktiv
    WINDOW_SUNROOF
    aktiv
    WIPER_BOOT_INHIBIT
    nicht_aktiv
    WIPER_CAM_DELAY
    wert_01
    WIPER_NO_PROG_REAR_WASH
    nicht_aktiv
    WIPER_REAR_CAM_DELAY
    wert_01
    WIPER_WASHER_START_TIME
    wert_01
    WISCHER_GESCHW_ABHAENGIG
    aktiv
    FRONT_FOG_ENABLE
    aktiv
    HEADLAMP_LEVEL_TYPE
    lwr_intern
    INERTIA_SW_FITTED
    nicht_aktiv
    REAR_FOG_ENABLE
    aktiv
    ABSCHALTUNG_VERBRAUCHER
    aktiv
    AL_AUS_BEI_KL_50
    aktiv
    ANHAENGERMODUL_PWM_WERT
    wert_01
    ANLAUFSTROMBEGRENZ_MEMO
    nicht_aktiv
    ANSTEUERZEIT_MOTOR_HK
    wert_01
    ANSTEUERZEIT_ZV_AGGREGATE
    plus_0ms
    ANZAHL_NACHWISCHZYKLEN
    4
    ANZAHL_SPRITZIMPULSE
    2
    ANZAHL_WASCHBET_ZUR_SRA
    7
    AUSSENTEMP_SENSOR
    aktiv
    BEDIENSTELLE_FT
    aktiv
    BETR_STD_NICHT_LOESCHEN
    aktiv
    BETRMODI_DEAKT_KL15_EIN
    nicht_aktiv
    BLINKIMPULS_WARNBLK
    nicht_aktiv
    BLOCKIERSCHUTZ_AKT_XXS
    wert_01
    BLOCKIERSCHUTZ_HI_AKT_XXS
    wert_01
    CABRIO_FH_VO_ZEIT_AUF
    1000ms
    CABRIO_FH_VO_ZUERST_AUF
    aktiv
    CABRIO_FH_VO_ZUERST_ZU
    nicht_aktiv
    CENT_LOCK_MGL_VO_TUER_AUF
    nicht_aktiv
    CODIERUNG_ERFOLGT_0
    codierung_erfolgt
    CODIERUNG_ERFOLGT_4
    codierung_erfolgt
    CODIERUNG_ERFOLGT_5
    codierung_erfolgt
    CODIERUNG_ERFOLGT_6
    codierung_erfolgt
    CODIERUNG_ERFOLGT_7
    codierung_erfolgt
    DIFFERENZ_ANLAUF_BLOCK
    wert_01
    DRITTE_TASTE_SENDER
    wert_01
    DWA_HEKKLEPPENKONTAKT
    aktiv
    EINKLEMMSCH_VORNE
    nicht_aktiv
    EINSTEIGHILFE
    nicht_aktiv
    EINSTIEG_FH_ZU_VER_SPERRE
    nicht_aktiv
    EKS_GEDRUECKT/OFFEN
    wert_01
    EKS_OFFEN/UNTERBRECHUNG
    wert_01
    EKS_REVERSIERZEIT_ZUS
    wert_01
    ENTR_HKL_MGL_WENN_VER
    nicht_aktiv
    FE_MODE_JEDOCH_MIT_FB
    nicht_aktiv
    FERNBEDIENUNG_1
    zv_selektiv
    FERNBEDIENUNG_2
    nicht_aktiv
    FERNBEDIENUNG_3
    nicht_aktiv
    FERNBEDIENUNG_4
    nicht_aktiv
    FH_ABSCHALTEN_BLOCK_AUF
    wert_01
    FH_ABSCHALTEN_BLOCK_ZU
    wert_01
    FH_ANHEBEN_TRANSPORTMODE
    aktiv
    FH_BLOCKABSCHALT_TUER_AUF
    wert_01
    FH_HINTEN_TIPP_AUF
    aktiv
    FH_HINTEN_TIPP_ZU
    nicht_aktiv
    FH_INIT_TRANSPORTMODE
    nicht_aktiv
    FH_SPEICHERN_TRANSPORTMOD
    aktiv
    FH_TIMEOUT
    8sec
    FL_AUS_BEI_KL_50
    aktiv
    FRISCHLUFT_PARKPOSTITION
    aktiv
    FZV_TIMEOUT
    wert_02
    HFS_ON_TIME_LOW_VOLTAGE
    wert_01
    HKL_SPERREN_BEI_ZS
    nicht_aktiv
    HRW_NUR_BEI_GESCHL_VERDEK
    nicht_aktiv
    HRW_ON_TIME_LOW_VOLTAGE
    wert_01
    HUB_VERZOEGERUNG_FH_VORN
    0ms
    IB_AUS_NACH_X_SEKUNDEN
    20s
    IB_BEI_KL.R_AUS_OHNE_58G
    ohne_bedingung
    IB_EIN_16MIN_WENN_STANDLI
    nicht_aktiv
    IB_EIN_BEI_HKK/HSK
    aktiv
    IB_EIN_N_KL_58G_MAX_1MIN
    zwei_minuten
    IB_EIN_SCHLOSS_ENTRIEGELN
    aktiv
    KALTUEBERW_AUS_BEI_KL_50
    aktiv
    KALTUEBERWACHUNG_BL
    nicht_aktiv
    KALTUEBERWACHUNG_BL_MI
    nicht_aktiv
    KALTUEBERWACHUNG_SL_H
    aktiv
    KALTUEBERWACHUNG_SL_V_I
    aktiv
    KALTUEBERWACHUNG_ZSW
    nicht_aktiv
    KEIN_HECKWISCHER
    mit_heckwischer
    KOMFOEFFNEN_SPERRE_KEY_IN
    aktiv
    KOMFORTOEFFNEN_FB_O_FH_HI
    nicht_aktiv
    KOMFORTOEFFNEN_FB_O_SHD
    nicht_aktiv
    KOMFORTOEFFNUNG_CLT
    nicht_aktiv
    KOMFORTSCHLIE_FB_O_FH_HI
    nicht_aktiv
    KOMFORTSCHLIE_FB_OHNE_SHD
    nicht_aktiv
    KOMFORTSCHLIESUNG_SCHLOSS
    aktiv
    KRB_WIE_VA/HKK_STATT_IB
    nicht_aktiv
    LAENDERVARIANTE_ECE
    aktiv
    LAENDERVARIANTE_US
    nicht_aktiv
    MAUT_N_ABBRECH_N_TUER_AUF
    nicht_aktiv
    MIN_PWM_TASTVERHAELTNIS
    wert_01
    MIT_AHM
    aktiv
    MIT_MFL
    nicht_aktiv
    MIT_OPT_ALARM
    aktiv
    MIT_WISCHER_SERVICEPOS
    nicht_aktiv
    N_VER_B_ERN_GESCHW_SCHWEL
    nicht_aktiv
    NSW_AUS_BEI_KL_50
    aktiv
    OFFENE_FENSTER
    nicht_aktiv
    OHNE_HRW
    nicht_aktiv
    OHNE_INRS_BESTAETIGUNG
    ohne_bestaetigung
    OHNE_SCHEIBENABSENKUNG
    mit_absenkung
    POTISTELLUNG_IN_77H
    wert_01
    PWM_ANSTEUERUNG_AL
    wert_03
    PWM_ANSTEUERUNG_BL
    wert_01
    PWM_ANSTEUERUNG_BLK_HI
    wert_01
    PWM_ANSTEUERUNG_BLK_VORN
    wert_01
    PWM_ANSTEUERUNG_FERNLICHT
    wert_01
    PWM_ANSTEUERUNG_IL
    wert_01
    PWM_ANSTEUERUNG_NSL
    wert_01
    PWM_ANSTEUERUNG_SL_H
    wert_01
    PWM_ANSTEUERUNG_SL_V_I
    wert_01
    PWM_ANSTEUERUNG_VA
    wert_01
    QUIT_AKUST_SCHAERF_KLAPPE
    nicht_aktiv
    QUIT_OPT_ANZAHL_ENTSICHRN
    2
    QUIT_OPT_ANZAHL_SICHERN
    QUIT_OPT_SCHAERF_KLAPPE
    aktiv
    QUITIMP_SICHERN/ENTSICHER
    aktiv
    ROVER_FZV_STATT_BMW
    bmw_fzv
    SCHEIBE_ABSENKZEIT
    wert_01
    SCHEIBENABSENK_OHNE_EKS
    ohne_eks
    SCHWELLE_GEBLAESESENSOR
    wert_01
    SCHWELLE_MERHK_KS
    wert_01
    SCHWELLE_MERHK_OL
    wert_01
    SENSOR_REGEN_N_STUFE2
    stufe_2
    TAUSCH_AUSGANG_NSL_NSW
    nicht_aktiv
    TRA_MODE_JEDOCH_MIT_FB
    nicht_aktiv
    UEBERSPGSABSCHALTUN_AL/FL
    aktiv
    UMLUFT_PARKPOSTITION
    nicht_aktiv
    VA1/VA2_AUS_NACH_X_MIN
    16_min
    VERL_ALARMZEI_WAEHR_ALARM
    nicht_aktiv
    VERZ_FRWISCHER_N_WASCHANF
    wert_01
    VERZ_HKWISCHER_N_WASCHANF
    wert_01
    VERZOEGERUNG_S56A_D_AUS
    wert_01
    VERZOEGERUNG_SHD_KOE
    sofort
    VERZOEGERUNG_SHD_KS
    sofort
    WARMUEBERWACHUNG_AL
    aktiv
    WARMUEBERWACHUNG_BL
    aktiv
    WARMUEBERWACHUNG_BL_MI
    aktiv
    WARMUEBERWACHUNG_BLK_HI
    aktiv
    WARMUEBERWACHUNG_BLK_VO
    aktiv
    WARMUEBERWACHUNG_FL
    aktiv
    WARMUEBERWACHUNG_NSL
    aktiv
    WARMUEBERWACHUNG_NSW
    aktiv
    WARMUEBERWACHUNG_SL_H
    aktiv
    WARMUEBERWACHUNG_SL_V_I
    aktiv
    WARMUEBERWACHUNG_ZSW
    nicht_aktiv
    WE_MODE_JEDOCH_MIT_FB
    nicht_aktiv
    WISCHER_RUECK_GESCHW
    wert_01
    WISCHER_VOLLEND_KLR_AUS
    keine_vollendung
    WISCHERINTERVALL_HECK
    wert_01
    XENON_TEST
    nicht_aktiv
    XENON_TIME
    wert_01
    XENON_TIMEOUT
    wert_01
    ZEIT_TUER/SCHLIESSZEIT
    wert_01
    ZEIT_WASCH_M/O_HKWISCHER
    wert_01
    ZSW_AUS_BEI_KL_50
    aktiv
    KS_ABSCHALTUNG_AL
    nicht_aktiv
    KS_ABSCHALTUNG_BL
    aktiv
    KS_ABSCHALTUNG_BL_MI
    nicht_aktiv
    KS_ABSCHALTUNG_BLK_HI
    aktiv
    KS_ABSCHALTUNG_BLK_VO
    aktiv
    KS_ABSCHALTUNG_FL
    nicht_aktiv
    KS_ABSCHALTUNG_IB
    aktiv
    KS_ABSCHALTUNG_KRB
    nicht_aktiv
    KS_ABSCHALTUNG_KZL
    nicht_aktiv
    KS_ABSCHALTUNG_NSL
    aktiv
    KS_ABSCHALTUNG_NSW
    nicht_aktiv
    KS_ABSCHALTUNG_SL_H
    nicht_aktiv
    KS_ABSCHALTUNG_SL_I
    nicht_aktiv
    KS_ABSCHALTUNG_VA
    aktiv
    KS_ABSCHALTUNG_ZSW
    nicht_aktiv
    ALARM_MUW_SENSOR
    nicht_aktiv
    CABRIO_FH_KOMP_AUF_MIT_FB
    nicht_aktiv
    CABRIO_FH_NICHT_ZU_MIT_FB
    nicht_aktiv
    KALTUEBERWACHUNG_BL_MI_2
    nicht_aktiv
    KALTUEBERWACHUNG_IB2
    nicht_aktiv
    LWR_POS2
    wert_03
    LWR_POSR
    wert_03
    MIT_AUSSTIEGSLEUCHTE
    nicht_aktiv
    MIT_NSL_RECHTS
    nicht_aktiv
    PWM_ANSTEUERUNG_IB2
    wert_01
    WARM_WITH_OL_BTS716
    nicht_aktiv
    WARMUEBERWACHUNG_IB2
    nicht_aktiv
    ZENTRAL_FH_SCHALTER
    nicht_aktiv
    ZENTRAL_FH_SCHALTER_VERZ
    wert_02
    BLS_POLL_TIME
    wert_02
    ZENTRAL_FH_SCHALTER_MAUT
    nicht_aktiv
    FLC_FAILSAFE
    nicht_aktiv
    FLC_OHNE_RLS
    nicht_aktiv
    MIT_FLC
    nicht_aktiv
    MIT_FLC_SCHALTER
    nicht_aktiv
    MIT_WWA
    aktiv
    WWA_MOTOR_AN_ZEITZELLE
    wert_01
    WWA_MOTOR_AUS_ZEITZELLE
    wert_01
    WWA_SENSOR_ABTASTUNG
    wert_02
    ANLIEFERKODIERUNG
    nicht_aktiv
    KALTUEB_AUS_BEI_SCG
    aktiv
    KOMFORT_OEFFNEN_VERZ
    wert_01
    wert_02
    KOMFORT_SCHLIESSEN_VERZ
    wert_01
    MAUT_NUR_BEI_MOTOR_AN
    nicht_aktiv
    TILT_SIRENE
    aktiv
    TM_ENTR_HECKKLAPPE
    aktiv
    WWA_LED_KL15_DAUER
    wert_01
    WWA_LED_MOT_DAUER
    wert_01
    WWA_LED_TAKT_AUS
    wert_01
    WWA_LED_TAKT_EIN
    wert_01
    WWA_LED_TRIG_DAUER
    nicht_aktiv
    WWA_LED_WASCH_DAUER
    wert_01
    TM_FOLLOW_ME_HOME
    nicht_aktiv
    TM_POSLIGHT
    nicht_aktiv
    AUTOM_ER_KEY_OFF
    nicht_aktiv
    EXT_BEREICH_KURZHUB
    wert_01
    KURZHUB_KOMPL_ABSENKZEIT
    aktiv
    MAXWERT_FH_POS_HB
    wert_01
    MAXWERT_FH_POS_LB
    wert_01
    Jan 2018
    Italy
    Mini R53
    SOLVED:
    Turns out I had to "reflash" the modules with NCS Expert with v38 daten in Expertmode, thus setting BC1 back to stock. After that, the sync trick worked (4 times ingnition, etc.).
    The issue was caused by bad daten (probably?).
    Hi all,
    aktiv
    DWA
    nicht_aktiv
    PANIK_MODUS
    nicht_aktiv
    aktiv
    QUIT_AKUST_SCHAERF
    nicht_aktiv
    QUIT_AKUST_ENTSCH
    nicht_aktiv
    QUIT_OPT_ENTSCH
    aktiv
    QUIT_OPT_SCHAERF
    nicht_aktiv
    NEIGUNGSGEBER
    aktiv
    ALARM_AKUSTISCH
    aktiv
    BEDIENSTELLE_BFT
    nicht_aktiv
    wert_03
    FH_NACH_TUERE_AUF
    nicht_aktiv
    FUNKTION_CABRIO
    nicht_aktiv
    nicht_aktiv
    nicht_aktiv
    IB_BEI_KL.R_AUS
    aktiv_mit_kl.58
    nicht_aktiv
    aktiv
    nicht_aktiv
    CC_BREMSLICHT
    aktiv
    nicht_aktiv
    ALARM_OPT_FERNLICHT
    nicht_aktiv
    aktiv
    nicht_aktiv
    aktiv
    WISCHERINTERVALL
    wert_01
    ZV_SELEKTIV
    nicht_aktiv
    nicht_aktiv
    CODIERUNG_ERFOLGT_1
    codierung_erfolgt
    nicht_aktiv
    aktiv
    nicht_aktiv
    STANDRUECKSCHALTUNG
    aktiv
    aktiv
    aktiv
    aktiv
    aktiv
    wert_01
    aktiv
    16_km/h
    ABFRAGEZEIT_AHM
    wert_01
    wert_01
    wert_01
    KALTUEBERWACHUNG_AL
    aktiv
    KALTUEBERWACHUNG_FL
    aktiv
    wert_01
    HALB/VOLLSCHRITT
    vollschritt
    wert_02
    nicht_aktiv
    nicht_aktiv
    wert_01
    kennlinie_01
    TEMPERATUR_GRENZE
    grad_-20
    ABS_MIN_STELLUNG_2
    wert_01
    GED_FL_ALS_DRL
    nicht_aktiv
    HEIMLEUCHTEN
    wert_02
    SCHRITTE_STELLUNG_0
    wert_01
    wert_02
    SCHRITTE_STELLUNG_1
    wert_03
    wert_06
    SCHRITTE_STELLUNG_2
    wert_06
    TAGFAHRLICHT_ECE
    nicht_aktiv
    U_POTI_STELLUNG_0
    wert_01
    U_POTI_STELLUNG_1
    wert_01
    U_POTI_STELLUNG_2
    wert_01
    BLS_PRUEFEN
    nicht_aktiv
    ABSENKUNG_10_KM/H
    wert_02
    ABTASTRATE_DYN
    wert_01
    ABTASTRATE_TREND
    wert_01
    ABWEICHUNG_TREND
    wert_01
    ANHEBUNG_175_KM/H
    wert_02
    ANZAHL_QUICK_RUNDEN
    wert_01
    AUSWERT_GRADIENT
    aktiv
    aktiv
    wert_01
    DEF_LWR_SENSOR_HI
    wert_01
    wert_01
    EPSILON_DELTA_A
    wert_02
    EPSILON_DELTA_AV
    wert_02
    nicht_aktiv
    HOEHENWEG
    wert_01
    aktiv
    wert_02
    wert_01
    nicht_aktiv
    aktiv
    wert_02
    LWR_VORZEICHEN
    wert_01
    M_TELEGRAM
    nicht_aktiv
    wert_01
    wert_01
    wert_01
    wert_01
    wert_01
    wert_01
    OFFSET_LWR
    wert_02
    PWM_ANSTEUERUNG_KZL
    wert_01
    wert_01
    wert_01
    wert_01
    wert_01
    aktiv
    wert_01
    wert_02
    SCHW_GRAD_BREMSEN
    wert_01
    wert_02
    wert_01
    wert_01
    wert_02
    SCHW_TREND
    wert_01
    SP_MOTOR_BEWERTEN
    aktiv
    SP_MOTOR_F_EINTRAG
    aktiv
    SP_MOTOR_STOP
    aktiv
    TREIBER_BEWERTEN
    aktiv
    TREIBER_F_EINTRAG
    aktiv
    VMAX_BESCHLEUNIGUNG
    wert_01
    VMAX_BREMSEN
    wert_01
    VMIN_BESCHLEUNIGUNG
    wert_01
    VMIN_BREMSEN
    wert_01
    aktiv
    ZEIT_KALT_PULSE
    wert_01
    wert_01
    ZEIT_KALT_RUNDEN
    wert_01
    wert_01
    AC_AUTO
    aktiv
    AC_BASIC
    nicht_aktiv
    nicht_aktiv
    BOOT_RELEASE_ENABLE
    aktiv
    CLUTCH_OFF
    wert_01
    CLUTCH_ON
    wert_01
    DAYLIGHT_RUN_POWER
    wert_01
    nicht_aktiv
    DIPPED_BEAM_NAS
    nicht_aktiv
    aktiv
    aktiv
    FRONT_FOG_NAS
    nicht_aktiv
    ohne_funktion
    HFS
    nicht_aktiv
    HFS_HIGH_TEMP_TIME
    wert_01
    HFS_LOW_TEMP_TIME
    wert_01
    wert_01
    HRW_HIGH_TEMP_TIME
    wert_01
    wert_01
    HRW_LOW_TEMP_TIME
    wert_01
    aktiv
    KEY_DISARM
    aktiv
    nicht_aktiv
    aktiv
    NO_SOFT_ON_OFF
    nicht_aktiv
    PARKING_LIGHTS
    nicht_aktiv
    POWER_WASH_OFF_TIME
    wert_01
    POWER_WASH_ON_TIME
    wert_01
    nicht_aktiv
    REMOTE_CONTROL
    aktiv
    SENSOR_REGEN
    nicht_aktiv
    aktiv
    WINDOW_AUTO_UP_PASS
    nicht_aktiv
    WINDOW_INCH_AUTO
    aktiv
    WINDOW_SUNROOF
    aktiv
    WIPER_BOOT_INHIBIT
    nicht_aktiv
    WIPER_CAM_DELAY
    wert_01
    nicht_aktiv
    wert_01
    wert_01
    aktiv
    FRONT_FOG_ENABLE
    aktiv
    HEADLAMP_LEVEL_TYPE
    lwr_intern
    INERTIA_SW_FITTED
    nicht_aktiv
    REAR_FOG_ENABLE
    aktiv
    aktiv
    AL_AUS_BEI_KL_50
    aktiv
    wert_01
    nicht_aktiv
    wert_01
    plus_0ms
    4
    2
    7
    AUSSENTEMP_SENSOR
    aktiv
    BEDIENSTELLE_FT
    aktiv
    aktiv
    nicht_aktiv
    BLINKIMPULS_WARNBLK
    nicht_aktiv
    wert_01
    wert_01
    1000ms
    aktiv
    nicht_aktiv
    nicht_aktiv
    CODIERUNG_ERFOLGT_0
    codierung_erfolgt
    CODIERUNG_ERFOLGT_4
    codierung_erfolgt
    CODIERUNG_ERFOLGT_5
    codierung_erfolgt
    CODIERUNG_ERFOLGT_6
    codierung_erfolgt
    CODIERUNG_ERFOLGT_7
    codierung_erfolgt
    wert_01
    DRITTE_TASTE_SENDER
    wert_01
    aktiv
    EINKLEMMSCH_VORNE
    nicht_aktiv
    EINSTEIGHILFE
    nicht_aktiv
    nicht_aktiv
    EKS_GEDRUECKT/OFFEN
    wert_01
    wert_01
    wert_01
    nicht_aktiv
    nicht_aktiv
    FERNBEDIENUNG_1
    zv_selektiv
    FERNBEDIENUNG_2
    nicht_aktiv
    FERNBEDIENUNG_3
    nicht_aktiv
    FERNBEDIENUNG_4
    nicht_aktiv
    wert_01
    wert_01
    aktiv
    wert_01
    FH_HINTEN_TIPP_AUF
    aktiv
    FH_HINTEN_TIPP_ZU
    nicht_aktiv
    nicht_aktiv
    aktiv
    FH_TIMEOUT
    8sec
    FL_AUS_BEI_KL_50
    aktiv
    aktiv
    FZV_TIMEOUT
    wert_02
    wert_01
    HKL_SPERREN_BEI_ZS
    nicht_aktiv
    nicht_aktiv
    wert_01
    0ms
    20s
    ohne_bedingung
    nicht_aktiv
    IB_EIN_BEI_HKK/HSK
    aktiv
    zwei_minuten
    aktiv
    aktiv
    KALTUEBERWACHUNG_BL
    nicht_aktiv
    nicht_aktiv
    aktiv
    aktiv
    nicht_aktiv
    KEIN_HECKWISCHER
    mit_heckwischer
    aktiv
    nicht_aktiv
    nicht_aktiv
    KOMFORTOEFFNUNG_CLT
    nicht_aktiv
    nicht_aktiv
    nicht_aktiv
    aktiv
    nicht_aktiv
    LAENDERVARIANTE_ECE
    aktiv
    LAENDERVARIANTE_US
    nicht_aktiv
    nicht_aktiv
    wert_01
    MIT_AHM
    aktiv
    MIT_MFL
    nicht_aktiv
    MIT_OPT_ALARM
    aktiv
    nicht_aktiv
    nicht_aktiv
    NSW_AUS_BEI_KL_50
    aktiv
    OFFENE_FENSTER
    nicht_aktiv
    OHNE_HRW
    nicht_aktiv
    ohne_bestaetigung
    mit_absenkung
    POTISTELLUNG_IN_77H
    wert_01
    PWM_ANSTEUERUNG_AL
    wert_03
    PWM_ANSTEUERUNG_BL
    wert_01
    wert_01
    wert_01
    wert_01
    PWM_ANSTEUERUNG_IL
    wert_01
    PWM_ANSTEUERUNG_NSL
    wert_01
    wert_01
    wert_01
    PWM_ANSTEUERUNG_VA
    wert_01
    nicht_aktiv
    2
    aktiv
    aktiv
    ROVER_FZV_STATT_BMW
    bmw_fzv
    SCHEIBE_ABSENKZEIT
    wert_01
    ohne_eks
    wert_01
    SCHWELLE_MERHK_KS
    wert_01
    SCHWELLE_MERHK_OL
    wert_01
    stufe_2
    nicht_aktiv
    nicht_aktiv
    aktiv
    nicht_aktiv
    16_min
    nicht_aktiv
    wert_01
    wert_01
    wert_01
    sofort
    VERZOEGERUNG_SHD_KS
    sofort
    WARMUEBERWACHUNG_AL
    aktiv
    WARMUEBERWACHUNG_BL
    aktiv
    aktiv
    aktiv
    aktiv
    WARMUEBERWACHUNG_FL
    aktiv
    aktiv
    aktiv
    aktiv
    aktiv
    nicht_aktiv
    nicht_aktiv
    wert_01
    keine_vollendung
    wert_01
    XENON_TEST
    nicht_aktiv
    XENON_TIME
    wert_01
    XENON_TIMEOUT
    wert_01
    wert_01
    wert_01
    ZSW_AUS_BEI_KL_50
    aktiv
    KS_ABSCHALTUNG_AL
    nicht_aktiv
    KS_ABSCHALTUNG_BL
    aktiv
    nicht_aktiv
    aktiv
    aktiv
    KS_ABSCHALTUNG_FL
    nicht_aktiv
    KS_ABSCHALTUNG_IB
    aktiv
    KS_ABSCHALTUNG_KRB
    nicht_aktiv
    KS_ABSCHALTUNG_KZL
    nicht_aktiv
    KS_ABSCHALTUNG_NSL
    aktiv
    KS_ABSCHALTUNG_NSW
    nicht_aktiv
    KS_ABSCHALTUNG_SL_H
    nicht_aktiv
    KS_ABSCHALTUNG_SL_I
    nicht_aktiv
    KS_ABSCHALTUNG_VA
    aktiv
    KS_ABSCHALTUNG_ZSW
    nicht_aktiv
    ALARM_MUW_SENSOR
    nicht_aktiv
    nicht_aktiv
    nicht_aktiv
    nicht_aktiv
    nicht_aktiv
    LWR_POS2
    wert_03
    LWR_POSR
    wert_03
    nicht_aktiv
    MIT_NSL_RECHTS
    nicht_aktiv
    PWM_ANSTEUERUNG_IB2
    wert_01
    WARM_WITH_OL_BTS716
    nicht_aktiv
    nicht_aktiv
    ZENTRAL_FH_SCHALTER
    nicht_aktiv
    wert_02
    BLS_POLL_TIME
    wert_02
    nicht_aktiv
    FLC_FAILSAFE
    nicht_aktiv
    FLC_OHNE_RLS
    nicht_aktiv
    MIT_FLC
    nicht_aktiv
    MIT_FLC_SCHALTER
    nicht_aktiv
    MIT_WWA
    aktiv
    wert_01
    wert_01
    wert_02
    ANLIEFERKODIERUNG
    nicht_aktiv
    KALTUEB_AUS_BEI_SCG
    aktiv
    wert_01
    wert_02
    wert_01
    nicht_aktiv
    TILT_SIRENE
    aktiv
    TM_ENTR_HECKKLAPPE
    aktiv
    WWA_LED_KL15_DAUER
    wert_01
    WWA_LED_MOT_DAUER
    wert_01
    WWA_LED_TAKT_AUS
    wert_01
    WWA_LED_TAKT_EIN
    wert_01
    WWA_LED_TRIG_DAUER
    nicht_aktiv
    WWA_LED_WASCH_DAUER
    wert_01
    TM_FOLLOW_ME_HOME
    nicht_aktiv
    TM_POSLIGHT
    nicht_aktiv
    AUTOM_ER_KEY_OFF
    nicht_aktiv
    EXT_BEREICH_KURZHUB
    wert_01
    aktiv
    MAXWERT_FH_POS_HB
    wert_01
    MAXWERT_FH_POS_LB
    wert_01
    UPDATE:
    I tried this too, both with DIS and ISTA-d:
    - overwrite the 1 key
    - delete the 1 key and recode it again
    - code the key in another position (2 and 3, none worked)
    Right now I coded it back to the first position, as it was. I know that the "matching" codes are correct because it used to work until the NCS Expert mess.
    I guess it has something to do with the "comfort opening" or something like that.
    Aren't them supposed to reset when I default the settings with and empty FSW_PSW.MAN file?
  1. Replies: 8
    Last Post: 03-20-2012, 01:10 AM
  2. Replies: 2
    Last Post: 01-21-2011, 12:42 AM
  3. BT No Longer Works After Software Update
    By stateinspector in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 01-01-2011, 07:24 PM
  4. blinkers no longer work after hid install
    By reedwilcox in forum 1991 - 1999 (E36)
    Last Post: 08-13-2010, 05:43 PM
  5. Moonroof no longer working after sitting for the winter
    By shadyduk1979 in forum 1975 - 1983 (E21)
    Last Post: 04-06-2008, 04:18 PM
