Hi all,
I've been playing around with NCS Expert on my R53 Mini Cooper S this weekend, so far so good.
I tryied some functions, some did work, some didn't. At the end of the day, I got out of the car, and now for some unknown reason the remote lock/unlock doesn't work anymore!
I tought I messed up something with NCS Expert, so I loaded the default VO values of my car (there are tons of guides for this "back to stock" flash).
This worked (settings reverted to stock) but still the keyfob doesn't work!
I checked with ISTA-d and DISv44 the Car/Key Memory and the key is still there, in the first slot, exactly where I coded it some weeks ago); other slots are empty, that's ok.
I don't really know what to do, the dealer is quite far from my location and I can't do such a trip because of my job.
Below is the NCS Expert config, wich is the stock (seem so, it has been generated by NCS with an empty file) of my car, so it can be checked by some of you that are way smarter than me.
Big thanks to anybody that will try to help me!
Code:FH_FAHRERTUER_TIPP_AUF aktiv FH_BEIFAHRERTUER_TIPP_AUF aktiv DWA nicht_aktiv SCHAERFEN/ENTSCHAERFEN schloss_und_fernbedienung PANIK_MODUS nicht_aktiv FUNK_INNENRAUMSCHUTZ aktiv QUIT_AKUST_SCHAERF nicht_aktiv QUIT_AKUST_ENTSCH nicht_aktiv QUIT_OPT_ENTSCH aktiv QUIT_OPT_SCHAERF nicht_aktiv NEIGUNGSGEBER aktiv ALARM_AKUSTISCH aktiv BEDIENSTELLE_BFT nicht_aktiv FH_ABSCHALTKRITERIUM wert_03 FH_NACH_TUERE_AUF nicht_aktiv FUNKTION_CABRIO nicht_aktiv EINKLEMMSCH_REVERSIEREN nicht_aktiv ALARM_AKUSTISCH_LANG nicht_aktiv IB_BEI_KL.R_AUS aktiv_mit_kl.58 KALTUEBERWACHUNG_NSL nicht_aktiv KALTUEBERWACHUNG_NSW aktiv SCHEINWERFERREINIGUNG nicht_aktiv CC_BREMSLICHT aktiv ALARM_OPT_ABBLENDLICHT nicht_aktiv ALARM_OPT_FERNLICHT nicht_aktiv ALARM_OPT_WARNBLINKER aktiv LEUCHTWEITENREG_AUTOM nicht_aktiv VERRIEGELN_AUT_AB_X_KM/H aktiv WISCHERINTERVALL wert_01 ZV_SELEKTIV nicht_aktiv CLT_AKTIV_IM_CRASH_MODE nicht_aktiv CODIERUNG_ERFOLGT_1 codierung_erfolgt ENTSICHERN_CENTERLOCK nicht_aktiv INNENLICHT_AN_MEHRFACH_ZV aktiv KOMFORTSCHLIESSUNG_FB nicht_aktiv STANDRUECKSCHALTUNG aktiv VERRIEGELN_XKM/H_SENDER_1 aktiv VERRIEGELN_XKM/H_SENDER_2 aktiv VERRIEGELN_XKM/H_SENDER_3 aktiv VERRIEGELN_XKM/H_SENDER_4 aktiv VERZUG_PANIK_MODUS_0.2_S wert_01 VERRIEGELN_AUT_NACH_2_MIN aktiv VERRIEGELUNGSSCHWELLE 16_km/h ABFRAGEZEIT_AHM wert_01 ABSCHALTUNG_UNTERSPG wert_01 ENTPRELLZAHL_FEHLERERK wert_01 KALTUEBERWACHUNG_AL aktiv KALTUEBERWACHUNG_FL aktiv ABSTAND_HOLD_NORMAL_MODE wert_01 HALB/VOLLSCHRITT vollschritt HYSTERESE_STARTBEDINGUNG wert_02 KALTUEBERWACHUNG_BLK_HI nicht_aktiv KALTUEBERWACHUNG_BLK_VO nicht_aktiv SCHRITTABSTAND_GRENZE wert_01 SCHRITTABSTAND_STARTPHASE kennlinie_01 TEMPERATUR_GRENZE grad_-20 ABS_MIN_STELLUNG_2 wert_01 GED_FL_ALS_DRL nicht_aktiv HEIMLEUCHTEN wert_02 SCHRITTE_STELLUNG_0 wert_01 wert_02 SCHRITTE_STELLUNG_1 wert_03 wert_06 SCHRITTE_STELLUNG_2 wert_06 TAGFAHRLICHT_ECE nicht_aktiv U_POTI_STELLUNG_0 wert_01 U_POTI_STELLUNG_1 wert_01 U_POTI_STELLUNG_2 wert_01 BLS_PRUEFEN nicht_aktiv ABSENKUNG_10_KM/H wert_02 ABTASTRATE_DYN wert_01 ABTASTRATE_TREND wert_01 ABWEICHUNG_TREND wert_01 ANHEBUNG_175_KM/H wert_02 ANZAHL_QUICK_RUNDEN wert_01 AUSWERT_GRADIENT aktiv AUSWERT_PROP_ABWEICHUNG aktiv DAUER_DYN_NACHFUEHRUNG wert_01 DEF_LWR_SENSOR_HI wert_01 DIFFERENZ_MSP_DYN_STAT wert_01 EPSILON_DELTA_A wert_02 EPSILON_DELTA_AV wert_02 GRADIENT_SCHLECHTWEG nicht_aktiv HOEHENWEG wert_01 KALTUEBERWACHUNG_KZL aktiv KENNLINIE_LWR_SENSOR_HI wert_02 KENNLINIE_LWR_SENSOR_VO wert_01 LEUCHTWEITENREG_DYNAM nicht_aktiv LEUCHTWEITENREGELUNG aktiv LWR_NEIGUNG_KONSTANTE wert_02 LWR_VORZEICHEN wert_01 M_TELEGRAM nicht_aktiv MIN_STEIGUNG_VZ_WECHSEL wert_01 MINDESTANZAHL_VZ_WECHSEL wert_01 MITTELUNGSINTERV_DYN wert_01 MITTELUNGSINTERV_TREND wert_01 MITTELUNGSINTERV_VZ_WECHS wert_01 NACHLAUF_SCHLECHTWEG wert_01 OFFSET_LWR wert_02 PWM_ANSTEUERUNG_KZL wert_01 REFERENZL_MODE_TEIL1 wert_01 REFERENZL_MODE_TEIL2 wert_01 REFERENZL_SCHRITTABSTAND wert_01 REFERENZL_SCHRITTANZAHL wert_01 SAETT_TIMER_SCHLECHTWEG aktiv SCHW_GRAD_BESCHLEUNIGUNG wert_01 wert_02 SCHW_GRAD_BREMSEN wert_01 wert_02 SCHW_GRADIENT_SCHLECHTWEG wert_01 SCHW_PROP_ABWEICHUNG wert_01 wert_02 SCHW_TREND wert_01 SP_MOTOR_BEWERTEN aktiv SP_MOTOR_F_EINTRAG aktiv SP_MOTOR_STOP aktiv TREIBER_BEWERTEN aktiv TREIBER_F_EINTRAG aktiv VMAX_BESCHLEUNIGUNG wert_01 VMAX_BREMSEN wert_01 VMIN_BESCHLEUNIGUNG wert_01 VMIN_BREMSEN wert_01 WARMUEBERWACHUNG_KZL aktiv ZEIT_KALT_PULSE wert_01 ZEIT_KALT_PULSE_QUICK wert_01 ZEIT_KALT_RUNDEN wert_01 ZYKLUS_KALT_RUNDEN_QUICK wert_01 AC_AUTO aktiv AC_BASIC nicht_aktiv AUXILIARY_LAMP_ENABLE nicht_aktiv BOOT_RELEASE_ENABLE aktiv CLUTCH_OFF wert_01 CLUTCH_ON wert_01 DAYLIGHT_RUN_POWER wert_01 DEFAULT_EXT_AMBIENT_TEMP nicht_aktiv DIPPED_BEAM_NAS nicht_aktiv ENTRIEGELN_B_MOTOR_STOP aktiv FOG_DISABLE_WITH_TRAILER aktiv FRONT_FOG_NAS nicht_aktiv HALTEN_FB_OEFFNEN_TASTE ohne_funktion HFS nicht_aktiv HFS_HIGH_TEMP_TIME wert_01 HFS_LOW_TEMP_TIME wert_01 HR_HIGH_BAT_THRESHOLD wert_01 HRW_HIGH_TEMP_TIME wert_01 HRW_LOW_BAT_THRESHOLD wert_01 HRW_LOW_TEMP_TIME wert_01 INDICATE_DURING_HAZARD aktiv KEY_DISARM aktiv KOMFORTOEFFNUNG_SCHLOSS nicht_aktiv MAN_WISCHEN_IM_WASCHPROG aktiv NO_SOFT_ON_OFF nicht_aktiv PARKING_LIGHTS nicht_aktiv POWER_WASH_OFF_TIME wert_01 POWER_WASH_ON_TIME wert_01 REAR_WIPER_CONTINUOUS nicht_aktiv REMOTE_CONTROL aktiv SENSOR_REGEN nicht_aktiv WINDOW_AUTO_UP_DRIVER aktiv WINDOW_AUTO_UP_PASS nicht_aktiv WINDOW_INCH_AUTO aktiv WINDOW_SUNROOF aktiv WIPER_BOOT_INHIBIT nicht_aktiv WIPER_CAM_DELAY wert_01 WIPER_NO_PROG_REAR_WASH nicht_aktiv WIPER_REAR_CAM_DELAY wert_01 WIPER_WASHER_START_TIME wert_01 WISCHER_GESCHW_ABHAENGIG aktiv FRONT_FOG_ENABLE aktiv HEADLAMP_LEVEL_TYPE lwr_intern INERTIA_SW_FITTED nicht_aktiv REAR_FOG_ENABLE aktiv ABSCHALTUNG_VERBRAUCHER aktiv AL_AUS_BEI_KL_50 aktiv ANHAENGERMODUL_PWM_WERT wert_01 ANLAUFSTROMBEGRENZ_MEMO nicht_aktiv ANSTEUERZEIT_MOTOR_HK wert_01 ANSTEUERZEIT_ZV_AGGREGATE plus_0ms ANZAHL_NACHWISCHZYKLEN 4 ANZAHL_SPRITZIMPULSE 2 ANZAHL_WASCHBET_ZUR_SRA 7 AUSSENTEMP_SENSOR aktiv BEDIENSTELLE_FT aktiv BETR_STD_NICHT_LOESCHEN aktiv BETRMODI_DEAKT_KL15_EIN nicht_aktiv BLINKIMPULS_WARNBLK nicht_aktiv BLOCKIERSCHUTZ_AKT_XXS wert_01 BLOCKIERSCHUTZ_HI_AKT_XXS wert_01 CABRIO_FH_VO_ZEIT_AUF 1000ms CABRIO_FH_VO_ZUERST_AUF aktiv CABRIO_FH_VO_ZUERST_ZU nicht_aktiv CENT_LOCK_MGL_VO_TUER_AUF nicht_aktiv CODIERUNG_ERFOLGT_0 codierung_erfolgt CODIERUNG_ERFOLGT_4 codierung_erfolgt CODIERUNG_ERFOLGT_5 codierung_erfolgt CODIERUNG_ERFOLGT_6 codierung_erfolgt CODIERUNG_ERFOLGT_7 codierung_erfolgt DIFFERENZ_ANLAUF_BLOCK wert_01 DRITTE_TASTE_SENDER wert_01 DWA_HEKKLEPPENKONTAKT aktiv EINKLEMMSCH_VORNE nicht_aktiv EINSTEIGHILFE nicht_aktiv EINSTIEG_FH_ZU_VER_SPERRE nicht_aktiv EKS_GEDRUECKT/OFFEN wert_01 EKS_OFFEN/UNTERBRECHUNG wert_01 EKS_REVERSIERZEIT_ZUS wert_01 ENTR_HKL_MGL_WENN_VER nicht_aktiv FE_MODE_JEDOCH_MIT_FB nicht_aktiv FERNBEDIENUNG_1 zv_selektiv FERNBEDIENUNG_2 nicht_aktiv FERNBEDIENUNG_3 nicht_aktiv FERNBEDIENUNG_4 nicht_aktiv FH_ABSCHALTEN_BLOCK_AUF wert_01 FH_ABSCHALTEN_BLOCK_ZU wert_01 FH_ANHEBEN_TRANSPORTMODE aktiv FH_BLOCKABSCHALT_TUER_AUF wert_01 FH_HINTEN_TIPP_AUF aktiv FH_HINTEN_TIPP_ZU nicht_aktiv FH_INIT_TRANSPORTMODE nicht_aktiv FH_SPEICHERN_TRANSPORTMOD aktiv FH_TIMEOUT 8sec FL_AUS_BEI_KL_50 aktiv FRISCHLUFT_PARKPOSTITION aktiv FZV_TIMEOUT wert_02 HFS_ON_TIME_LOW_VOLTAGE wert_01 HKL_SPERREN_BEI_ZS nicht_aktiv HRW_NUR_BEI_GESCHL_VERDEK nicht_aktiv HRW_ON_TIME_LOW_VOLTAGE wert_01 HUB_VERZOEGERUNG_FH_VORN 0ms IB_AUS_NACH_X_SEKUNDEN 20s IB_BEI_KL.R_AUS_OHNE_58G ohne_bedingung IB_EIN_16MIN_WENN_STANDLI nicht_aktiv IB_EIN_BEI_HKK/HSK aktiv IB_EIN_N_KL_58G_MAX_1MIN zwei_minuten IB_EIN_SCHLOSS_ENTRIEGELN aktiv KALTUEBERW_AUS_BEI_KL_50 aktiv KALTUEBERWACHUNG_BL nicht_aktiv KALTUEBERWACHUNG_BL_MI nicht_aktiv KALTUEBERWACHUNG_SL_H aktiv KALTUEBERWACHUNG_SL_V_I aktiv KALTUEBERWACHUNG_ZSW nicht_aktiv KEIN_HECKWISCHER mit_heckwischer KOMFOEFFNEN_SPERRE_KEY_IN aktiv KOMFORTOEFFNEN_FB_O_FH_HI nicht_aktiv KOMFORTOEFFNEN_FB_O_SHD nicht_aktiv KOMFORTOEFFNUNG_CLT nicht_aktiv KOMFORTSCHLIE_FB_O_FH_HI nicht_aktiv KOMFORTSCHLIE_FB_OHNE_SHD nicht_aktiv KOMFORTSCHLIESUNG_SCHLOSS aktiv KRB_WIE_VA/HKK_STATT_IB nicht_aktiv LAENDERVARIANTE_ECE aktiv LAENDERVARIANTE_US nicht_aktiv MAUT_N_ABBRECH_N_TUER_AUF nicht_aktiv MIN_PWM_TASTVERHAELTNIS wert_01 MIT_AHM aktiv MIT_MFL nicht_aktiv MIT_OPT_ALARM aktiv MIT_WISCHER_SERVICEPOS nicht_aktiv N_VER_B_ERN_GESCHW_SCHWEL nicht_aktiv NSW_AUS_BEI_KL_50 aktiv OFFENE_FENSTER nicht_aktiv OHNE_HRW nicht_aktiv OHNE_INRS_BESTAETIGUNG ohne_bestaetigung OHNE_SCHEIBENABSENKUNG mit_absenkung POTISTELLUNG_IN_77H wert_01 PWM_ANSTEUERUNG_AL wert_03 PWM_ANSTEUERUNG_BL wert_01 PWM_ANSTEUERUNG_BLK_HI wert_01 PWM_ANSTEUERUNG_BLK_VORN wert_01 PWM_ANSTEUERUNG_FERNLICHT wert_01 PWM_ANSTEUERUNG_IL wert_01 PWM_ANSTEUERUNG_NSL wert_01 PWM_ANSTEUERUNG_SL_H wert_01 PWM_ANSTEUERUNG_SL_V_I wert_01 PWM_ANSTEUERUNG_VA wert_01 QUIT_AKUST_SCHAERF_KLAPPE nicht_aktiv QUIT_OPT_ANZAHL_ENTSICHRN 2 QUIT_OPT_ANZAHL_SICHERN 1 QUIT_OPT_SCHAERF_KLAPPE aktiv QUITIMP_SICHERN/ENTSICHER aktiv ROVER_FZV_STATT_BMW bmw_fzv SCHEIBE_ABSENKZEIT wert_01 SCHEIBENABSENK_OHNE_EKS ohne_eks SCHWELLE_GEBLAESESENSOR wert_01 SCHWELLE_MERHK_KS wert_01 SCHWELLE_MERHK_OL wert_01 SENSOR_REGEN_N_STUFE2 stufe_2 TAUSCH_AUSGANG_NSL_NSW nicht_aktiv TRA_MODE_JEDOCH_MIT_FB nicht_aktiv UEBERSPGSABSCHALTUN_AL/FL aktiv UMLUFT_PARKPOSTITION nicht_aktiv VA1/VA2_AUS_NACH_X_MIN 16_min VERL_ALARMZEI_WAEHR_ALARM nicht_aktiv VERZ_FRWISCHER_N_WASCHANF wert_01 VERZ_HKWISCHER_N_WASCHANF wert_01 VERZOEGERUNG_S56A_D_AUS wert_01 VERZOEGERUNG_SHD_KOE sofort VERZOEGERUNG_SHD_KS sofort WARMUEBERWACHUNG_AL aktiv WARMUEBERWACHUNG_BL aktiv WARMUEBERWACHUNG_BL_MI aktiv WARMUEBERWACHUNG_BLK_HI aktiv WARMUEBERWACHUNG_BLK_VO aktiv WARMUEBERWACHUNG_FL aktiv WARMUEBERWACHUNG_NSL aktiv WARMUEBERWACHUNG_NSW aktiv WARMUEBERWACHUNG_SL_H aktiv WARMUEBERWACHUNG_SL_V_I aktiv WARMUEBERWACHUNG_ZSW nicht_aktiv WE_MODE_JEDOCH_MIT_FB nicht_aktiv WISCHER_RUECK_GESCHW wert_01 WISCHER_VOLLEND_KLR_AUS keine_vollendung WISCHERINTERVALL_HECK wert_01 XENON_TEST nicht_aktiv XENON_TIME wert_01 XENON_TIMEOUT wert_01 ZEIT_TUER/SCHLIESSZEIT wert_01 ZEIT_WASCH_M/O_HKWISCHER wert_01 ZSW_AUS_BEI_KL_50 aktiv KS_ABSCHALTUNG_AL nicht_aktiv KS_ABSCHALTUNG_BL aktiv KS_ABSCHALTUNG_BL_MI nicht_aktiv KS_ABSCHALTUNG_BLK_HI aktiv KS_ABSCHALTUNG_BLK_VO aktiv KS_ABSCHALTUNG_FL nicht_aktiv KS_ABSCHALTUNG_IB aktiv KS_ABSCHALTUNG_KRB nicht_aktiv KS_ABSCHALTUNG_KZL nicht_aktiv KS_ABSCHALTUNG_NSL aktiv KS_ABSCHALTUNG_NSW nicht_aktiv KS_ABSCHALTUNG_SL_H nicht_aktiv KS_ABSCHALTUNG_SL_I nicht_aktiv KS_ABSCHALTUNG_VA aktiv KS_ABSCHALTUNG_ZSW nicht_aktiv ALARM_MUW_SENSOR nicht_aktiv CABRIO_FH_KOMP_AUF_MIT_FB nicht_aktiv CABRIO_FH_NICHT_ZU_MIT_FB nicht_aktiv KALTUEBERWACHUNG_BL_MI_2 nicht_aktiv KALTUEBERWACHUNG_IB2 nicht_aktiv LWR_POS2 wert_03 LWR_POSR wert_03 MIT_AUSSTIEGSLEUCHTE nicht_aktiv MIT_NSL_RECHTS nicht_aktiv PWM_ANSTEUERUNG_IB2 wert_01 WARM_WITH_OL_BTS716 nicht_aktiv WARMUEBERWACHUNG_IB2 nicht_aktiv ZENTRAL_FH_SCHALTER nicht_aktiv ZENTRAL_FH_SCHALTER_VERZ wert_02 BLS_POLL_TIME wert_02 ZENTRAL_FH_SCHALTER_MAUT nicht_aktiv FLC_FAILSAFE nicht_aktiv FLC_OHNE_RLS nicht_aktiv MIT_FLC nicht_aktiv MIT_FLC_SCHALTER nicht_aktiv MIT_WWA aktiv WWA_MOTOR_AN_ZEITZELLE wert_01 WWA_MOTOR_AUS_ZEITZELLE wert_01 WWA_SENSOR_ABTASTUNG wert_02 ANLIEFERKODIERUNG nicht_aktiv KALTUEB_AUS_BEI_SCG aktiv KOMFORT_OEFFNEN_VERZ wert_01 wert_02 KOMFORT_SCHLIESSEN_VERZ wert_01 MAUT_NUR_BEI_MOTOR_AN nicht_aktiv TILT_SIRENE aktiv TM_ENTR_HECKKLAPPE aktiv WWA_LED_KL15_DAUER wert_01 WWA_LED_MOT_DAUER wert_01 WWA_LED_TAKT_AUS wert_01 WWA_LED_TAKT_EIN wert_01 WWA_LED_TRIG_DAUER nicht_aktiv WWA_LED_WASCH_DAUER wert_01 TM_FOLLOW_ME_HOME nicht_aktiv TM_POSLIGHT nicht_aktiv AUTOM_ER_KEY_OFF nicht_aktiv EXT_BEREICH_KURZHUB wert_01 KURZHUB_KOMPL_ABSENKZEIT aktiv MAXWERT_FH_POS_HB wert_01 MAXWERT_FH_POS_LB wert_01
SOLVED:
Turns out I had to "reflash" the modules with NCS Expert with v38 daten in Expertmode, thus setting BC1 back to stock. After that, the sync trick worked (4 times ingnition, etc.).
The issue was caused by bad daten (probably?).
Hi all,
UPDATE:FH_FAHRERTUER_TIPP_AUF aktiv
aktiv
DWA
nicht_aktiv
PANIK_MODUS
nicht_aktiv
aktiv
QUIT_AKUST_SCHAERF
nicht_aktiv
QUIT_AKUST_ENTSCH
nicht_aktiv
QUIT_OPT_ENTSCH
aktiv
QUIT_OPT_SCHAERF
nicht_aktiv
NEIGUNGSGEBER
aktiv
ALARM_AKUSTISCH
aktiv
BEDIENSTELLE_BFT
nicht_aktiv
wert_03
FH_NACH_TUERE_AUF
nicht_aktiv
FUNKTION_CABRIO
nicht_aktiv
nicht_aktiv
nicht_aktiv
IB_BEI_KL.R_AUS
aktiv_mit_kl.58
nicht_aktiv
aktiv
nicht_aktiv
CC_BREMSLICHT
aktiv
nicht_aktiv
ALARM_OPT_FERNLICHT
nicht_aktiv
aktiv
nicht_aktiv
aktiv
WISCHERINTERVALL
wert_01
ZV_SELEKTIV
nicht_aktiv
nicht_aktiv
CODIERUNG_ERFOLGT_1
codierung_erfolgt
nicht_aktiv
aktiv
nicht_aktiv
STANDRUECKSCHALTUNG
aktiv
aktiv
aktiv
aktiv
aktiv
wert_01
aktiv
16_km/h
ABFRAGEZEIT_AHM
wert_01
wert_01
wert_01
KALTUEBERWACHUNG_AL
aktiv
KALTUEBERWACHUNG_FL
aktiv
wert_01
HALB/VOLLSCHRITT
vollschritt
wert_02
nicht_aktiv
nicht_aktiv
wert_01
kennlinie_01
TEMPERATUR_GRENZE
grad_-20
ABS_MIN_STELLUNG_2
wert_01
GED_FL_ALS_DRL
nicht_aktiv
HEIMLEUCHTEN
wert_02
SCHRITTE_STELLUNG_0
wert_01
wert_02
SCHRITTE_STELLUNG_1
wert_03
wert_06
SCHRITTE_STELLUNG_2
wert_06
TAGFAHRLICHT_ECE
nicht_aktiv
U_POTI_STELLUNG_0
wert_01
U_POTI_STELLUNG_1
wert_01
U_POTI_STELLUNG_2
wert_01
BLS_PRUEFEN
nicht_aktiv
ABSENKUNG_10_KM/H
wert_02
ABTASTRATE_DYN
wert_01
ABTASTRATE_TREND
wert_01
ABWEICHUNG_TREND
wert_01
ANHEBUNG_175_KM/H
wert_02
ANZAHL_QUICK_RUNDEN
wert_01
AUSWERT_GRADIENT
aktiv
aktiv
wert_01
DEF_LWR_SENSOR_HI
wert_01
wert_01
EPSILON_DELTA_A
wert_02
EPSILON_DELTA_AV
wert_02
nicht_aktiv
HOEHENWEG
wert_01
aktiv
wert_02
wert_01
nicht_aktiv
aktiv
wert_02
LWR_VORZEICHEN
wert_01
M_TELEGRAM
nicht_aktiv
wert_01
wert_01
wert_01
wert_01
wert_01
wert_01
OFFSET_LWR
wert_02
PWM_ANSTEUERUNG_KZL
wert_01
wert_01
wert_01
wert_01
wert_01
aktiv
wert_01
wert_02
SCHW_GRAD_BREMSEN
wert_01
wert_02
wert_01
wert_01
wert_02
SCHW_TREND
wert_01
SP_MOTOR_BEWERTEN
aktiv
SP_MOTOR_F_EINTRAG
aktiv
SP_MOTOR_STOP
aktiv
TREIBER_BEWERTEN
aktiv
TREIBER_F_EINTRAG
aktiv
VMAX_BESCHLEUNIGUNG
wert_01
VMAX_BREMSEN
wert_01
VMIN_BESCHLEUNIGUNG
wert_01
VMIN_BREMSEN
wert_01
aktiv
ZEIT_KALT_PULSE
wert_01
wert_01
ZEIT_KALT_RUNDEN
wert_01
wert_01
AC_AUTO
aktiv
AC_BASIC
nicht_aktiv
nicht_aktiv
BOOT_RELEASE_ENABLE
aktiv
CLUTCH_OFF
wert_01
CLUTCH_ON
wert_01
DAYLIGHT_RUN_POWER
wert_01
nicht_aktiv
DIPPED_BEAM_NAS
nicht_aktiv
aktiv
aktiv
FRONT_FOG_NAS
nicht_aktiv
ohne_funktion
HFS
nicht_aktiv
HFS_HIGH_TEMP_TIME
wert_01
HFS_LOW_TEMP_TIME
wert_01
wert_01
HRW_HIGH_TEMP_TIME
wert_01
wert_01
HRW_LOW_TEMP_TIME
wert_01
aktiv
KEY_DISARM
aktiv
nicht_aktiv
aktiv
NO_SOFT_ON_OFF
nicht_aktiv
PARKING_LIGHTS
nicht_aktiv
POWER_WASH_OFF_TIME
wert_01
POWER_WASH_ON_TIME
wert_01
nicht_aktiv
REMOTE_CONTROL
aktiv
SENSOR_REGEN
nicht_aktiv
aktiv
WINDOW_AUTO_UP_PASS
nicht_aktiv
WINDOW_INCH_AUTO
aktiv
WINDOW_SUNROOF
aktiv
WIPER_BOOT_INHIBIT
nicht_aktiv
WIPER_CAM_DELAY
wert_01
nicht_aktiv
wert_01
wert_01
aktiv
FRONT_FOG_ENABLE
aktiv
HEADLAMP_LEVEL_TYPE
lwr_intern
INERTIA_SW_FITTED
nicht_aktiv
REAR_FOG_ENABLE
aktiv
aktiv
AL_AUS_BEI_KL_50
aktiv
wert_01
nicht_aktiv
wert_01
plus_0ms
4
2
7
AUSSENTEMP_SENSOR
aktiv
BEDIENSTELLE_FT
aktiv
aktiv
nicht_aktiv
BLINKIMPULS_WARNBLK
nicht_aktiv
wert_01
wert_01
1000ms
aktiv
nicht_aktiv
nicht_aktiv
CODIERUNG_ERFOLGT_0
codierung_erfolgt
CODIERUNG_ERFOLGT_4
codierung_erfolgt
CODIERUNG_ERFOLGT_5
codierung_erfolgt
CODIERUNG_ERFOLGT_6
codierung_erfolgt
CODIERUNG_ERFOLGT_7
codierung_erfolgt
wert_01
DRITTE_TASTE_SENDER
wert_01
aktiv
EINKLEMMSCH_VORNE
nicht_aktiv
EINSTEIGHILFE
nicht_aktiv
nicht_aktiv
EKS_GEDRUECKT/OFFEN
wert_01
wert_01
wert_01
nicht_aktiv
nicht_aktiv
FERNBEDIENUNG_1
zv_selektiv
FERNBEDIENUNG_2
nicht_aktiv
FERNBEDIENUNG_3
nicht_aktiv
FERNBEDIENUNG_4
nicht_aktiv
wert_01
wert_01
aktiv
wert_01
FH_HINTEN_TIPP_AUF
aktiv
FH_HINTEN_TIPP_ZU
nicht_aktiv
nicht_aktiv
aktiv
FH_TIMEOUT
8sec
FL_AUS_BEI_KL_50
aktiv
aktiv
FZV_TIMEOUT
wert_02
wert_01
HKL_SPERREN_BEI_ZS
nicht_aktiv
nicht_aktiv
wert_01
0ms
20s
ohne_bedingung
nicht_aktiv
IB_EIN_BEI_HKK/HSK
aktiv
zwei_minuten
aktiv
aktiv
KALTUEBERWACHUNG_BL
nicht_aktiv
nicht_aktiv
aktiv
aktiv
nicht_aktiv
KEIN_HECKWISCHER
mit_heckwischer
aktiv
nicht_aktiv
nicht_aktiv
KOMFORTOEFFNUNG_CLT
nicht_aktiv
nicht_aktiv
nicht_aktiv
aktiv
nicht_aktiv
LAENDERVARIANTE_ECE
aktiv
LAENDERVARIANTE_US
nicht_aktiv
nicht_aktiv
wert_01
MIT_AHM
aktiv
MIT_MFL
nicht_aktiv
MIT_OPT_ALARM
aktiv
nicht_aktiv
nicht_aktiv
NSW_AUS_BEI_KL_50
aktiv
OFFENE_FENSTER
nicht_aktiv
OHNE_HRW
nicht_aktiv
ohne_bestaetigung
mit_absenkung
POTISTELLUNG_IN_77H
wert_01
PWM_ANSTEUERUNG_AL
wert_03
PWM_ANSTEUERUNG_BL
wert_01
wert_01
wert_01
wert_01
PWM_ANSTEUERUNG_IL
wert_01
PWM_ANSTEUERUNG_NSL
wert_01
wert_01
wert_01
PWM_ANSTEUERUNG_VA
wert_01
nicht_aktiv
2
aktiv
aktiv
ROVER_FZV_STATT_BMW
bmw_fzv
SCHEIBE_ABSENKZEIT
wert_01
ohne_eks
wert_01
SCHWELLE_MERHK_KS
wert_01
SCHWELLE_MERHK_OL
wert_01
stufe_2
nicht_aktiv
nicht_aktiv
aktiv
nicht_aktiv
16_min
nicht_aktiv
wert_01
wert_01
wert_01
sofort
VERZOEGERUNG_SHD_KS
sofort
WARMUEBERWACHUNG_AL
aktiv
WARMUEBERWACHUNG_BL
aktiv
aktiv
aktiv
aktiv
WARMUEBERWACHUNG_FL
aktiv
aktiv
aktiv
aktiv
aktiv
nicht_aktiv
nicht_aktiv
wert_01
keine_vollendung
wert_01
XENON_TEST
nicht_aktiv
XENON_TIME
wert_01
XENON_TIMEOUT
wert_01
wert_01
wert_01
ZSW_AUS_BEI_KL_50
aktiv
KS_ABSCHALTUNG_AL
nicht_aktiv
KS_ABSCHALTUNG_BL
aktiv
nicht_aktiv
aktiv
aktiv
KS_ABSCHALTUNG_FL
nicht_aktiv
KS_ABSCHALTUNG_IB
aktiv
KS_ABSCHALTUNG_KRB
nicht_aktiv
KS_ABSCHALTUNG_KZL
nicht_aktiv
KS_ABSCHALTUNG_NSL
aktiv
KS_ABSCHALTUNG_NSW
nicht_aktiv
KS_ABSCHALTUNG_SL_H
nicht_aktiv
KS_ABSCHALTUNG_SL_I
nicht_aktiv
KS_ABSCHALTUNG_VA
aktiv
KS_ABSCHALTUNG_ZSW
nicht_aktiv
ALARM_MUW_SENSOR
nicht_aktiv
nicht_aktiv
nicht_aktiv
nicht_aktiv
nicht_aktiv
LWR_POS2
wert_03
LWR_POSR
wert_03
nicht_aktiv
MIT_NSL_RECHTS
nicht_aktiv
PWM_ANSTEUERUNG_IB2
wert_01
WARM_WITH_OL_BTS716
nicht_aktiv
nicht_aktiv
ZENTRAL_FH_SCHALTER
nicht_aktiv
wert_02
BLS_POLL_TIME
wert_02
nicht_aktiv
FLC_FAILSAFE
nicht_aktiv
FLC_OHNE_RLS
nicht_aktiv
MIT_FLC
nicht_aktiv
MIT_FLC_SCHALTER
nicht_aktiv
MIT_WWA
aktiv
wert_01
wert_01
wert_02
ANLIEFERKODIERUNG
nicht_aktiv
KALTUEB_AUS_BEI_SCG
aktiv
wert_01
wert_02
wert_01
nicht_aktiv
TILT_SIRENE
aktiv
TM_ENTR_HECKKLAPPE
aktiv
WWA_LED_KL15_DAUER
wert_01
WWA_LED_MOT_DAUER
wert_01
WWA_LED_TAKT_AUS
wert_01
WWA_LED_TAKT_EIN
wert_01
WWA_LED_TRIG_DAUER
nicht_aktiv
WWA_LED_WASCH_DAUER
wert_01
TM_FOLLOW_ME_HOME
nicht_aktiv
TM_POSLIGHT
nicht_aktiv
AUTOM_ER_KEY_OFF
nicht_aktiv
EXT_BEREICH_KURZHUB
wert_01
aktiv
MAXWERT_FH_POS_HB
wert_01
MAXWERT_FH_POS_LB
wert_01
I tried this too, both with DIS and ISTA-d:
- overwrite the 1 key
- delete the 1 key and recode it again
- code the key in another position (2 and 3, none worked)
Right now I coded it back to the first position, as it was. I know that the "matching" codes are correct because it used to work until the NCS Expert mess.
I guess it has something to do with the "comfort opening" or something like that.
Aren't them supposed to reset when I default the settings with and empty FSW_PSW.MAN file?
