This thread is to share the results of using the Steed Speed TS manifold with various turbos.
As data is contributed, I will update this post. I am also interested to include results of other manifold/turbo combinations for comparison.
Criteria
- 4th Gear Pull from approximately 2000 RPM up
- List Engine Size
- List Camshaft Duration (Intake/Exhaust)
- List fuel used (Octane + Meth?)
- List Manifold
- List Turbo model and turbine housing details
- List Exhaust Size
- List Road (On level ground) or Dyno pull
- # RPM @ 5.0 PSI
- # RPM @ 10.0 PSI
- # RPM @ 15.0 PSI
- # RPM @ 19.0 PSI
- # RPM @ 20.0 PSI
- # RPM @ 25.0 PSI
- # RPM @ 30.0 PSI
Nice thread, maybe add.....
*Cams *fuel type
As that can change things drastically.
S52
Steed TS
6466 T4 1.0 divided.
264/256 cams
93+meth
I don't have the smaller boost logs , have to wait till spring. But,
20 psi at 3400
25 psi at 3700 (24.7psi)
Sent from my E6782 using Tapatalk
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Does this manifold have equal length runners (x3) per each scroll? It sure doesn't look like it.
5psi by 3200
10psi by 3600
15psi by 3700
19psi by 3900
25psi by 4150
30psi by 4400rpm
(Edited, need to upload a log from the computer)
Pte6870 1.15 ar
3.2l 87mm s52 9:1
276/272 cams
4" inlet, 3.5" exhaust, 3" charge
E85 id2k Stock ecu
manifold:
1989 535i - sold
1999 M3 Tiag/Dove - sold
Pei, changing a few things this winter. Basically had a bad vanos for the last two years. New clutch in the works. Ill send you some nice 20khz logs next warm.
1989 535i - sold
1989 535i - sold
This info is way outdated. Merc only ran the log manifold for one season/2014 and has currently been running the equal lengths for the last 2-3 seasons. To also think there is anything similar between the 2 design goals of the engines is a stretch. Merc originally chose the log manifold due to space constraints....ie maximizing rear end aero while knowingly sacrificing some HP. Also, this does nothing to answer my question.
Here's the "log" manifold on the W08.
And the "new" "log" manifold on the SF70H
Why do both of these look equal length? It's because they are.
Mine is a 3.5" exhaust BTW sorry.
1996 332IS
Built 3.2
Hey Guys! I'll add the data we have from one of our 32 psi peak boost dyno runs with the 9180 EFR turbo and the largest 1.45 housing BW offers using the Steed TS mani. Dyno is also attached.
4th Gear Pull from approximately 2000 RPM up on level ground
- List Engine Size 3.2L
- List Camshaft Duration (Intake/Exhaust) Elgin reground S52 cams...
- List fuel used (Octane + Meth?) MS109 + 50/50 Meth
- List Manifold New CES Steedspeed TS manifold
- List Turbo model and turbine housing details Borg Warner EFR 9180 with 1.45 AR exhaust housing
- List Exhaust Size 3.5" Exhaust
- # RPM @ 5.0 PSI 2816 rpm
- # RPM @ 10.0 PSI 3267 rpm
- # RPM @ 15.0 PSI 3485 rpm
- # RPM @ 19.0 PSI 3694 rpm
- # RPM @ 20.0 PSI 3743 rpm
- # RPM @ 25.0 PSI 3971 rpm
- # RPM @ 30.0 PSI 4252 rpm
Pei, Add that and graph them. We need graphss.
1989 535i - sold
And this is the data with the exact same setup as the 9180 except with the 8374 EFR turbo and the 1.05 ar exhaust housing.... along with the attached dyno comparison of the 8374 vs 9180...
- 4th Gear Pull from approximately 2000 RPM up on level ground
- # RPM @ 5.0 PSI 2228 rpm
- # RPM @ 10.0 PSI 2777 rpm
- # RPM @ 15.0 PSI 2947 rpm
- # RPM @ 19.0 PSI 3141 rpm
- # RPM @ 20.0 PSI 3223 rpm
- # RPM @ 25.0 PSI 3631 rpm
- # RPM @ 30.0 PSI N/A
- List Engine Size- 2.86
- List Camshaft Duration (Intake/Exhaust)- S50
- List fuel used (Octane + Meth?) E85
- List Manifold- 666 Bottom Mount
- List Turbo model and turbine housing details- 6766 ball bearing T4 .96
- List Exhaust Size- 3.5"
- # RPM @ 5.0 PSI- 4000
- # RPM @ 10.0 PSI- 4270
- # RPM @ 15.0 PSI- 4376
- # RPM @ 20.0 PSI- 4473
- # RPM @ 25.0 PSI- 4643
- # RPM @ 28.3 PSI- 4900
- # RPM @ 30 PSI- Out of injector
- List Camshaft Duration (Intake/Exhaust)- S52
- List fuel used (Octane + Meth?)- E85
- List Manifold- Technique Tuning
- List Turbo model and turbine housing details- 6262 journal bearing T3.82
- List Exhaust Size- 3"
- # RPM @ 5.0 PSI- 3238
- # RPM @ 10.0 PSI- 3479
- # RPM @ 15.0 PSI- 3687
- # RPM @ 19.0 PSI- 3875
- # RPM @ 20.0 PSI- 4000
- # RPM @ 23.0 PSI- 4373
- # RPM @ 30.0 PSI no more fuel as well
Also this is fine and good, but might be worth considering some back of the napkin engineering to correct for power/torque.
Thanks John
Updated.
Thanks Kevin
Data added...I'm going to wait for a little bit before updating the list/graph.
You could also add whether logged data is on the street or dyno. Many say response is better on the street than on a Dynojet. This is why I recommended a standardized test that anyone could do — like a 4th year pull from 2000 rpm on a level road and observe 10 psi, 15 psi and 20 psi if you go that high. Knowing the wastegate setting is also important, since the person wastegated to 15 will get to 15 slower than the person gated to 20 will get to 15.
Maybe in the note's add the forum members names to the data. As if this thread takes off like it should, there will be multiple of same setups.
1996 332IS
Built 3.2
-3.2
-S52 cams
-E98
-Open T4 Otisfold
-GT4094r 1.06
-4" exhaust
-Dynojet
-18 psi spring lol
-5psi @ 3200
-10psi @ 3700
-15psi @ 3900
-19psi @ 4100
-20psi @ 4150
-25psi @ 4400
-30psi @ 4800
Don't do 4th gear pulls anymore, in 1:1 5th
-3.2
-264/256 schricks
-E98
-Open T4 Otisfold
-EFR9180 1.45
-4" exhaust (different downpipe and intake)
-Dynojet
-18 psi spring lol
-5psi @ 2900
-10psi @ 3480
-15psi @ 3750
-19psi @ 3850
-20psi @ 3880
-25psi @ 4200
-30psi @ 4800
And here is the data we have of 2 E36 stock motor lower compression NEW TS Steed builds we did here at the shop. Both are 93 octane pump gas tuned, but one is an S50 motor with a GT35R and our straight through flow 3" exhaust system, and the other is an S52 with a GTX35R and our Chambered exhaust system which helped regulate boost creep to a minimum. The straight through 3" exhaust system did not want to regulate below 12-13 psi on a 7 psi spring with the OBD1 GT35R customer car, but when we swapped to the chambered muffler design on the S52 GTX35R customer car, we were able to regulate to 9 psi on a 7psi spring with almost identical boost curve and little to no flow loss up top at these power levels.
OBD1 S50 Motor Turbosmart 45mm WG 7 psi spring
- List Engine Size 3.0
- List Camshaft Duration (Intake/Exhaust) OEM S50
- List fuel used (Octane + Meth?) 93 octane only
- List Manifold New Steed TS
- List Turbo model and turbine housing details GT35R 1.06 T4 divided
- List Exhaust Size 3" straight through
- List Road (On level ground) or Dyno pull Dynojet Dyno
- # RPM @ 5.0 PSI 2734 rpm
- # RPM @ 10.0 PSI 3231 rpm
- # RPM @ 15.0 PSI 3724 rpm
- # RPM @ 19.0 PSI
- # RPM @ 20.0 PSI N/A
- # RPM @ 25.0 PSI
- # RPM @ 30.0 PSI
OBD2 S52 Motor with M50 intake manifold Tial 44mm WG 7 psi spring
- List Camshaft Duration (Intake/Exhaust) OEM S52
- List Turbo model and turbine housing details GTX35R 1.06 T4 divided
- List Exhaust Size 3" chambered muffler design
- # RPM @ 5.0 PSI 2743 rpm
- # RPM @ 10.0 PSI 3304 rpm
- # RPM @ 15.0 PSI 4144 rpm
- # RPM @ 19.0 PSI
- # RPM @ 25.0 PSI
- # RPM @ 30.0 PSI
Updated with new data from TheJuggernaut and jgcm3
Thanks guys!
