Results 1 to 3 of 3
Thread: Replacement / spare keys e60 / e63 / e90
    so. cal
    e60
    if your in the los angeles area and needing a replacement key, i can now make you a spare or make a key even if you lost all your keys. As of now I can make e60 , e63 and e90 , working on getting for older models and minis.
    i can also make you a nice F series style flip key to replace your diamond style. this key has ALL functions of regular remote, the 4th button DOES work, it sounds the alarm, and if you have pathway lightning coding, it will turn your lights on for the set amount of time on your idrive menu (if you get a key from me i will code this for you). the remote has excellent signal and im able to lock my car from it being parked across the street and im inside my home. it is VERY sturdy,and well built. it is NOT like those old flip keys that are flimsy and requires you to cut open your old key.
    the keys i make are programed to your cas unit, and given its own slot, NOT A CLONE. i will also cut your key with a top of the line key cutting machine that cuts by code, and not by copying your current key. your key will be made the same way the dealer would at fraction of the cost and wait (have it done in 30 minutes)
    LIVE OUT OF STATE? i can still make you a key, but will require you to ship me your cas unit (easy to remove, 15 minutes). i HIGHLY recommend overnight shipping and i ship overnight as well, so downtime will be minimal as your car will not start with this module out. i typically can ship the unit back out same day i receive them, so 3 days total has been the average youll be out (long as it doesnt fall on a sunday where mail is not delivered)
    ORIGINAL DIAMOND STYLE - $100
    F SERIES STYLE FLIP - $125
    PUSH TO START KEY - $100
    prices do not include shipping, CAS module fits inside usps express flate rate envelope that cost $21.86.
    MESSAGE ME OR EMAIL ME ROSKINCDAVID GMAIL COM or txt four-two-four 222-9851
    [ 310 StormTrooper | Lumma | H&R | OEM 166 ]
    Dec 2010
    Westport, CT
    2003 M5, E93 335i/6
    These are great prices. Are you re-coding used keys or new ones?
    -Chris
    so. cal
    e60
    Quote Originally Posted by mxchris727 View Post
    I Use Brand new keys.
    Also getting keys for 7 Series e65, Minis coopers. And older e-series 98-2005, I will be able to offer the f series flip keys for those as well.
  1. E63,E64 M5/M6 6-speed drivetrain & LSD, trailing arms E60 E63 E92 E90 M3
    By jeuprx8 in forum Drivetrain & Transmission Parts
    Last Post: 02-09-2013, 10:04 AM
  2. E63,E64 E60 E63 E64 E90 E90 8.8-inch iDrive Nav display
    By jeuprx8 in forum Car Audio & Electronics
    Last Post: 02-09-2013, 09:29 AM
  3. FS: Brand new DIAGNOSTIC SCANNER E60 E63 E65 E87 E90
    By bumer325 in forum Engines, Performance Parts & Software
    Last Post: 07-07-2012, 05:03 PM
  4. Z4 Replacement (spare) Key
    By bocash3 in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 08-12-2008, 03:43 PM
  5. Replacement key set for E90
    By badger007 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 01-11-2008, 02:40 PM
