Results 1 to 9 of 9
Thread: E46 cant unlock car with remote
    Jan 2018
    Sweden
    E46 320 2004
    Hello everyone im from Sweden so if my english isn’t very good thats why.
    Anyways. I have a problem with my remote key doesn’t work with my e46 320 2004. It works good if I unlock it with my key in the door and all doors unlock. I have tried initializating my key and changed battery without succses. I have mesured with a multimeter on the cables that goes from the antenna amplifyer (the thing under the rear spoiler). And I get a indication every time I press the key. So it isnt my key or the antenna that is bad. What could be the problem?
    Oct 2007
    Northern Virginia
    2020 Mercedes S560
    When this happened to me I had to have the key re-programmed at the dealer.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Are you having any other electrical or electronic issues with the car? Cold temperatures are very hard on batteries. Google “BMW E46 hidden OBC functions.” Test #9 will show you the voltage as seen by the engine computer (DME in NMWeze).
    If all else is fine I suggest you check the electrical connections at the antenna amplifier. It’s located in the driver’s side “C” pillar.
    Also check fuses 49, 52 and 60. They’re for the locking system.
    Jan 2018
    Sweden
    E46 320 2004
    No other electrical problems. Forgot to say that it is a touring. Do you know where the antenna amplifier is located on the wagon?
    Jan 2018
    Sweden
    E46 320 2004
    Does antone know where the wires from the antenna goes?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The antenna amp is in the roof liner. It’s item #2 in the link.
    http://www.realoem.com/bmw/enUS/show...diagId=65_0637
    Jan 2018
    Sweden
    E46 320 2004
    Ah okey, what is number 5 then cause it says antenna amp too?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    I think #5 is the AM/FM amp. It seems the touring has different amps than the other 3-series bodies.
    Jan 2018
    Sweden
    E46 320 2004
    Aha okey that is probably it. Going to check the wireing today thanks
  1. alarms sound when unlocking car w remote.
    By themanharts in forum 1996 - 2003 (E39)
    Last Post: 01-30-2011, 03:11 PM
  2. Cant unlock car!
    By soundeyes100 in forum 1995 - 2001 (E38)
    Last Post: 05-17-2010, 09:42 AM
  3. Alarm goes off after unlocking car with keyless remote
    By ArnZ in forum 1988 - 1996 (E34)
    Last Post: 05-25-2009, 08:46 PM
  4. How to arm/disarm car with Remote Only? Help?
    By Esteves in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 01-07-2006, 02:12 PM
  5. Replies: 16
    Last Post: 12-14-2001, 03:21 PM
