Results 1 to 7 of 7
Thread: 328 front sway bar end link setup?
    Apr 2002
    Broomfield, Colorado
    Folks - those of you that have abandoned the M3 style sway bar links (attached to the shock) in favor of the 328 mounts (attached to the control arm)...
    ...what end links are you using?
    Surely not stock?
    Thanks in advance,
    --Bill
    2002 BMW M Roaster.
    1998 BMW 328is SCCA E Production road racer.
    Nov 2014
    Atlanta
    1996 BMW M3/2/5
    I bought the AKG solid/spherical endlinks.
    Mar 2013
    So~Cal
    2003 E46 M3 / E30 Vert
    Curious, why would one spring for the 328i style over M? I have a 328i that i am going to be running endlinks to attach the sway to my new shock body, like the M.
    Apr 2002
    Just testing. I (personally) don't like how the end links rotate with the M3 shock mounts. Yes I know it's a proven setup.
    If you want the same bar stiffness, you'll need a much stiffer bar mounted to the control arms, than the shock mounts. A good example is the H&R bar for the M3 (PN 70910) is softer than the 328 bar (PN 70824). The 328 bar is shorter (and you can see it in the height of the major bend in front of the steering rack.
    You can find multiple threads on the subject. Not saying one is better, I just am stockpiling a bunch of bars and mounts to try.
    Quote Originally Posted by mindspin311 View Post
    Thank you.
    2002 BMW M Roaster.
    Jul 2012
    Orlando, FL, USA
    1993 BMW 325i
    I run both setups on my non-m with tck da. I've had no problem with the same stock ones on a dedicated track car run on r comps for years. I think I bought meyles, could double check if needed.
    MINIz guy's Avatar
    MINIz guy is offline #buttstuff2k14 BMW CCA Member
    Bear, DE
    rolls coal
    I use Bimmerworld endlinks on my 328i with a Hotchkis front bar.
    Va
    I just bought some heim joints at the needed lengths from online, and made my own.
    Back into a BMW, this time a track rat....and it won't be BMW powered and no, not a V8 either!
    Couldn't help myself, boosted e36 m52 street car in progress also!
  1. WTB - front sway bar end links for e36 328
    By CdnR328i in forum BMW Parts Wanted
    Last Post: 04-03-2006, 12:03 PM
  2. wtb: stock M3 front sway bar end links
    By ///Mr. Three in forum BMW Parts Wanted
    Last Post: 11-12-2004, 10:26 PM
  3. WTB: M3 front sway bar end links
    By Nimble in forum BMW Parts Wanted
    Last Post: 05-23-2004, 03:10 PM
  4. FS: New M3 Front Sway Bar End Links
    By binh in forum BMW Parts For Sale
    Last Post: 10-30-2003, 10:56 AM
  5. WTB: E36 M3 Front Sway Bar- End Links
    By Alpine003 in forum BMW Parts Wanted
    Last Post: 09-16-2003, 11:03 PM
