Results 1 to 7 of 7
Thread: Trunk not unlocked when doors are unlocked.
    May 2010
    Bellevue WA
    2003 BMW 325Xi Sports
    Problem
    Earlier when I unlock the doors using the remote , I was able to open the trunk using the latch above the license plate. For past few days, I am not sure what changed but trunk does not get unlocked when I unlock the doors. I have to specifically press the 'trunk' open button on remote to unlock/open my trunk.
    - Is there a specific setting to enable trunk to be unlocked whenever I unlock the doors.?
    - Is there a manual switch/latch that driver can use to unlock the trunk sitting in driver's position.
    My car : 2003 325xi AWD.
    Gana
    Mar 2015
    west chicago il
    01 E46 330i 5sp man spor
    Maybe the trunk lock cylinder is in the valet position. That will disable the trunk switch on the trunk lid and the one on the drivers kick panel. If that's not the problem, check for broken wires in the harness from the trunk lid to the body.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    May 2010
    Bellevue WA
    Quote Originally Posted by randy72877 View Post
    Where can I find this trunk lock cylinder and the valet and non valet position? I do not have the original manual and don't know even if that shows this lock cylinder
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The lock is located to the right of the license plate. I believe the lock is in valet position when the key hole is horizontal.
    Jan 2016
    Ca
    2001 525it
    or your lock actuator died in the trunk
    Sep 2008
    Sandy, Oregon
    2002 330Ci, 1995 325is
    Additional information
    One thing that happened with my 330 was that when using the remote all locks operated sporadically. This was after replacing the passenger door actuator. Reading here I saw people having problems like mine and solving them by putting their remote on top of their electric toothbrush charger. It uses the same induction charging as our remotes. I put it on the charger over night about once a week and have never experienced a remote problem since. I don't drive much and apparently I wasn't driving enough to charge up the remote. It sounded crazy, but what the hell. What did I have to lose? It seems to have worked.
    I have a Phillips sonic care.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The cause could be a problem with the general module 5 (GM5). It has relays for the locks and other electrical systems. Google “bmwgm5.”
  1. Replies: 0
    Last Post: 03-06-2016, 05:49 PM
  2. Dome light not turning of when doors are closed
    By sse34 in forum 1988 - 1996 (E34)
    Last Post: 05-07-2011, 11:57 AM
  3. Windows do not drop when door is open..... Need help guys.
    By RJ's325ITS in forum 1991 - 1999 (E36)
    Last Post: 04-21-2008, 12:57 AM
  4. Anyone have issues with windows not retracting when door opens?
    By s_ribs in forum MINI (Cooper & Cooper S)
    Last Post: 03-25-2007, 04:00 PM
  5. Rattling windows when doors are closed
    By MC007 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 10-01-2003, 01:57 PM
