Page 5 of 32 FirstFirst 12345678910111213141530 ... LastLast
Results 101 to 125 of 799
Thread: 2018 what did you do to your e38 today?
  1. #101
    Oulu, Finland
    See my sig
    Oil filter housing gasket, new oil+filter, fuel filter, oil pressure sensor replaced.
    All messy.
    And washed the car.
    Current rides: E65 730dA '04, F10 520dA '11, E34 520iA '91
    Old rides: E46 316Ti, E53 X5, E38 728iA, E39 528iA, E46 318i Touring, E38 730dA, E36 316i, E36 328iA Cabrio, E38 728i, E38 750i, E36/3 320i, E36 318i, E39 530dA Touring, E38 740i, E39 528iA, E34 525iA, E32 750iL, E32 730iL, E34/2 525TDS,
    E34 525i, E28 518i, E34 535i, E34/2 525iA, E30/5 325i, E34 535i, E28 520i https://www.instagram.com/zener__/
  2. #102
    Mar 2004
    Tyler, Tx
    '01 740i Sp, '07 335i
    Franko - how do you charge the battery on the new keys now?
    http://i293.photobucket.com/albums/mm71/krallopian/darthSigTest2_zpsn6zkw5id.jpg[/URL][URL="http://www.facebook.com/pages/DFW7-Dallas-Fort-Worth-BMW-7-Series-Club/300942239566"]DFW7 on Facebook/URL]
    "The Last Great e38" 2001 i Sport - Born'd on date 1/01 Cosmos/Grey - 32.8K miles - 2 1/2 " Custom Exhaust, Center “X”over , Modified OEM rear bumper, M5 style trunk spoiler, M6 OEM wheels, M3 Steering wheel with working paddle shift & CF trim, Bi-Xenon upgrade, 13mm Rear sway bar added, SS brake lines and bronze bushings, Cross drilled rotors and painted calipers, Akebono pads, Zionsville aluminum radiator & exp. tank with electric fan, Sprint Booster, BluTooth conversion, MKIV Nav., Custom wood cupholder, DUDMD Tune, Orien V2.5 LED Angel Eyes, Evans waterless. Recently added grey faced //M5 Cluster - all gauges functioning. Changed the grey carpet to black and topped off with GG Bailey front/rear mats[/SIZE]
  3. #103
    IL
    2000 740i sport
    Quote Originally Posted by TxDarth View Post
    They do not need to charge because they are easily replaced un like the original Dymond keys that can't even be opened without cutting them open which is why they are rechargeable in the ignition
    Sent from my SM-N910T3 using Tapatalk
  4. #104
    May 2015
    Australia
    4/'98 E38 735iL
    Hi guys,
    I ordered my BC extreme lows last week, fingers crossed they arrive this week. One question about the SLS delete...
    Why doesn't anyone just loop the m10x1 line connectors [the yellow paint marked connectors in the pic]? Unscrew, bend and screw them into each other. Clean and tidy, with all the parts already fitted on the car. The fittings are male on each end, with a female-female joiner in the middle, so everything is there to loop both ends of the car.
    Am I missing something?
  5. #105
    Jul 2016
    San Diego
    1998 E38 750iL
    Quote Originally Posted by jazigk View Post
    Hi guys,
    It may be a bit tight to make those bends on the original lines and you run the risk of cracking them. Instead of that I used an additional piece of brake line with the connectors already on it which you can usually find in stock at NAPA. You use it in place of the janky zip tied rubber hose.
  6. #106
    NYC
    99 IL/13 SXT/04 Audi A4
    easy just open up the diamond keys and change the batteries, its easy you can open the key up with your finger nails.
    El Cid 1999 IL
    DUDMD Tune/DINAN CAI/19 in Style 95 Rims/Bilstein's Shocks/Eibach Lowering Springs/OEM Folding Mirrors/Custom Cupholder/Custom Wood Sunshade/Sport Steering Wheel/Euro Center Console/Leather Shifter/Rearview Camera /Luke Custom 10 in Sub Box/Cross Drilled Rotors/Rear view Camera/BMW OEM Monitors/BMW E38 Picnic Tables/Vanity Headrests/OEM Roof Rack/Strut Bar/Dinan MAF and Dinan Throttle Body and Dinan tunning /BM53 Radio upgrade /Custom Innovadrive NXG39 modify and Alpine ILX-W650 touch screen radio.
  7. #107
    NYC
    Open up the key to show TxDarth how easy it's to open up and change the battery.
    El Cid 1999 IL
  8. #108
    Mar 2004
    Tyler, Tx
    Quote Originally Posted by franco90 View Post
    You must have some strong fingernails - my diamond key was a bitch to open even with a Dremel...
  9. #109
    Sep 2014
    Chicago, Il / Denver, Co
    '01 DINAN7 '03 M5
    It’s aftermarket key shell, it’s not glued
    Instagram.com/nordmanmg
    Your current situation is not your final destination
  10. #110
    Mar 2004
    Tyler, Tx
    Quote Originally Posted by NordmanMg View Post
    Ah so........ said the blind man as he picked up his hammer and saw.......
  11. #111
    Carmel in.
    95 740i, 92 ACSchnitzer
    Finishing up a set of 18's style 5's for the 740.
    Lets get the party started before it's my bedtime.
  12. #112
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    Quote Originally Posted by gaspump View Post
    Nice! Polishing the lips and stuff? Looks great! I polished the style 42's for my 530 several years back. Lot of work!
    Those 18" style 5's will look awesome on your car. Where'd you grab those?
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
  13. #113
    Carmel in.
    Thanks. They came with the car at sale, but had seen better days. Lots of sanding, buffing, lots of elbow grease put into these things. I've polished these as much as I will, they are what they are, but they do look nice.
  14. #114
    Rutland, Vermont
    Yeah they get really nasty.
    https://www.bimmerforums.com/forum/s...ject-Completed
  15. #115
    Apr 2017
    Hampton va
    95 740i, 89 735i,
    Quote Originally Posted by oldroller View Post
    If at all possible you should remove the broken bolt from the hub. The forces from the serpentine belts are considerable.
    When you consider that BMW balances even the little power steering pump pulley, smooth harmonics make these cars
    what they are, the Ultimate in driving experience.
    But we all do what we have to in a pinch... The good thing is the broken bolt in the hub is 'unloaded', and could possibly be walked out
    if not too corroded or damaged, leaving the threaded hole ready for a new fastener. Worst case scenario would be using a left handed
    drill bit to 'bite' into the bolt and back it out. Working slowly and carefully, obviously. Good luck!
    What would be the best way to get it out?
  16. #116
    Jan 2017
    North Carolina coast
    2001 740iL Prod 4/2000
    this or similar, drill bolt center and remove with extractor bit...carefully.
    https://www.amazon.com/Irwin-HANSON-...+extractor+kit
  17. #117
    Apr 2017
    Hampton va
    95 740i, 89 735i,
    I went and bought all the stuff to drill it out and took everything apart. Harmonic balancer and all come to find out it wasn't even broke to far I ended up just using grip pliers20180218_143700_HDR.jpg20180218_143700_HDR.jpg20180218_143700_HDR.jpg20180218_143700_HDR.jpg20180218_143700_HDR.jpg
  18. #118
    NJ
    01 740i
    Owned the car for 1 week and already dealing with an interior water leak. Looks like the windshield was replaced and set incorrectly. Onto the drains.
    Edit: all drains were clogged and 1 of the sunroof drains was disconnected. Floor was covered in 2 inches of water. She is finally dry!
  19. #119
    Sep 2014
    '01 DINAN7 '03 M5
    Quote Originally Posted by ibumpers View Post
    good, glad it ended up well
  20. #120
    Mar 2012
    Queensland, Australia
    1995 730iL (M60B30)
    Quote Originally Posted by MMMMM5 View Post
    Ouch, sorry that happened to you. Did you pull up the carpets? You need to be certain the fuse link box under the carpet isn't still full of water and just waiting to rust into oblivion;
    https://www.bimmerforums.com/forum/s...nder-pass-seat
  21. #121
    NJ
    01 740i
    Quote Originally Posted by Sobek View Post
    Pulling the carpet and seats was the last step. Fortunately it did not look anything like that, I buffed the fuses and applied some oil.
  22. #122
    Oulu, Finland
    See my sig
    Damn, I've seen myself looking E65 730d now a days... Wouldn't mind upgrading daily driver. But then... I wouldn't wanna sell the E38.
  23. #123
    Feb 2018
    Knoxville, TN
    1995 BMW 740il
    New here - just got my first E38 a few weeks ago. The previous owners didn't ... give her the love she deserves.
    Wish I had the money/time to do it all right away, but I'm constrained to weekends that aren't pouring.
    Replaced the air intake hose today. Was cracked and taped in place.
    Still not running quite smooth as I'd like but the grommet on the idle regulating valve seemed a little loose/old so maybe that's next.
  24. #124
    Houston
    2001 740il
    Does a e60 steering wheel fit in our cars, going to junkyard this week and there is a e60.
  25. #125
    Mar 2018
    Louisville, NE, USA
    1998 BMW 740iL (5/97)
    Have been making a punch list of all I need to do to my new (to me) 98...Hopefully as soon as the weather starts warming up, I will be able to cross things off instead of adding to it...it is mostly small stuff from years of neglect.
  1. 2017 what did you do to your e38 today?
    By Jamos in forum 1995 - 2001 (E38)
    Last Post: 01-03-2018, 12:14 AM
  2. 2016 what did you do to your e38 today?
    By 1badturboe38 in forum 1995 - 2001 (E38)
    Last Post: 01-01-2017, 07:03 PM
  3. 2015 What did you do to your E38 today?
    By Mayorchuck in forum 1995 - 2001 (E38)
    Last Post: 01-06-2016, 03:36 PM
  4. 2014 What did you do to your E38 today?
    Last Post: 01-01-2015, 03:13 PM
  5. What did you do to your E38 today???
    By kooljess in forum 1995 - 2001 (E38)
    Last Post: 01-30-2014, 12:28 AM
