Page 4 of 32 FirstFirst 123456789101112131429 ... LastLast
Results 76 to 100 of 799
Thread: 2018 what did you do to your e38 today?
  1. #76
    Jan 2017
    North Carolina coast
    2001 740iL Prod 4/2000
    If at all possible you should remove the broken bolt from the hub. The forces from the serpentine belts are considerable.
    When you consider that BMW balances even the little power steering pump pulley, smooth harmonics make these cars
    what they are, the Ultimate in driving experience.
    But we all do what we have to in a pinch... The good thing is the broken bolt in the hub is 'unloaded', and could possibly be walked out
    if not too corroded or damaged, leaving the threaded hole ready for a new fastener. Worst case scenario would be using a left handed
    drill bit to 'bite' into the bolt and back it out. Working slowly and carefully, obviously. Good luck!
  2. #77
    Sep 2014
    Chicago, Il / Denver, Co
    '01 DINAN7 '03 M5
    Quote Originally Posted by ibumpers View Post
    Replaced my Harmonic balancer today right before it got dark and was trying to figure out why I couldn't get the last m8×16 hex bolt to go in. Used the light on my phone to find out one of the bolts broke off inside, will I be ok with 7 out of 8?
    I'll put new fan and both belts on tommorow.
    It will give you vibration on crankshaft which is bad thing
    Instagram.com/nordmanmg
    Your current situation is not your final destination
  3. #78
    Apr 2017
    Hampton va
    95 740i, 89 735i,
    Put new fan and both belts on, gage on dash stayed in red. I put coolant in and kept squeezing hose to get air out while car was running, finally it went to blue. Topped off coolant and let run a little over 20 minutes and it stayed in blue. Drove her around the block and she went to red again, someone please help
  4. #79
    IL
    2000 740i sport
    Do you know how to properly bleed the cooling system?
    Sent from my SM-N910T3 using Tapatalk
  5. #80
    Apr 2017
    Hampton va
    95 740i, 89 735i,
    No u tube video
    https://youtu.be/IZoTgfgDUfY
  6. #81
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    No u tube video
    That video is a fail. Draining and filling is outlined here.
    http://www.meeknet.co.uk/E38/E38_Dra...ng_Coolant.pdf
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
  7. #82
    Dec 2017
    Laveen, AZ
    97 325i 98 740i 07 325i
    Today am changing my osv but still waiting on the part to be delivered to me so just on stand by, but it’s 80 plus today in Phoenix
  8. #83
    Apr 2017
    Hampton va
    95 740i, 89 735i,
    Quote Originally Posted by clarkitect View Post
    Thanks and one thing I noticed was that the heat never got hot, usually it pumps hot fast but the whole time it was running and once I pulled off it was still blowing cold
  9. #84
    Aug 2008
    Hesperia, CA
    2001 740 i Sport
    Washed her...no need for tire shine. The desert sand just gravitates right to it...
    Sent from my LGLS676 using Tapatalk
    [/IMG]
  10. #85
    IL
    2000 740i sport
    On a cold engine i just get the front lifted and open the cap and screw and turn heat to 90 and fan on lowest setting to open the valves up and get the aux pump going. Fill coolant up to the brim of the tank opening and allow the bubbles to escape through the open bleeder screw hole. Keep topping it up until there are no more bubbles coming out. Then close cap and screw (do not overtighten it) (unlock the cluster to test 7 - ktmp to watch the temp in digital for precision) start the car and every minute or 2 open the bleeder screw a few times and try to bleed some more bubbles out. Go for a ride and make sure the heat is nice and toasty and the ktmp on cluster does not exceed 110c...
    https://www.bimmerforums.com/forum/s...d.php?t=334021
  11. #86
    Apr 2017
    Hampton va
    95 740i, 89 735i,
    Quote Originally Posted by purplecty View Post
    Went outside this morning to find out I have a leak somewhere, coolant super low. Have to find out where it's coming from was hoping it would be a easy fix like thermostat or something
  12. #87
    NYC
    99 IL/13 SXT/04 Audi A4
    El Cid 1999 IL
    DUDMD Tune/DINAN CAI/19 in Style 95 Rims/Bilstein's Shocks/Eibach Lowering Springs/OEM Folding Mirrors/Custom Cupholder/Custom Wood Sunshade/Sport Steering Wheel/Euro Center Console/Leather Shifter/Rearview Camera /Luke Custom 10 in Sub Box/Cross Drilled Rotors/Rear view Camera/BMW OEM Monitors/BMW E38 Picnic Tables/Vanity Headrests/OEM Roof Rack/Strut Bar/Dinan MAF and Dinan Throttle Body and Dinan tunning /BM53 Radio upgrade /Custom Innovadrive NXG39 modify and Alpine ILX-W650 touch screen radio.
  13. #88
    Sep 2014
    '01 DINAN7 '03 M5
    Finally got some spacers and put my wheels on
  14. #89
    Rutland, Vermont
    Quote Originally Posted by NordmanMg View Post
    Looks freaking awesome Nordman. What size wheels/spacers? I know you posted the sizes before but I forget.
  15. #90
    Sep 2014
    '01 DINAN7 '03 M5
    19x9.5 Et31 +12mm spacer 265/40/19
    19x10.5 Et19 no spacer 295/35/19
  16. #91
    Jul 2016
    San Diego
    1998 E38 750iL
    Ugghhhh that's some good meat.
  17. #92
    CT
    E38
    Beautiful. Sunken in wheels are a terrible look on these cars, even with the M Parallels. I run 15mm front 20mm rear on mine when wider tires too, and it looks like a different car
    E38 M Sport 6 Speed MANUAL
  18. #93
    Oulu, Finland
    See my sig
    Quote Originally Posted by franco90 View Post
    How did you made this upgrade?
    Current rides: E65 730dA '04, F10 520dA '11, E34 520iA '91
    Old rides: E46 316Ti, E53 X5, E38 728iA, E39 528iA, E46 318i Touring, E38 730dA, E36 316i, E36 328iA Cabrio, E38 728i, E38 750i, E36/3 320i, E36 318i, E39 530dA Touring, E38 740i, E39 528iA, E34 525iA, E32 750iL, E32 730iL, E34/2 525TDS,
    E34 525i, E28 518i, E34 535i, E34/2 525iA, E30/5 325i, E34 535i, E28 520i https://www.instagram.com/zener__/
  19. #94
    Rutland, Vermont
    Quote Originally Posted by zener View Post
    Very complex process
    https://www.amazon.com/Silicone-Prot...+red+key+cover
  20. #95
    NYC
    Lol not this but nice try
    My son got me the cover so I rock it.
    I when from old key to new diamond key
    And it was not that hard to do I shipped them out and a couple days later I got my new diamond keys.
    El Cid 1999 IL
  21. #96
    May 2010
    NRW, Germany
    E32 730i V8, E38 735i V8
  22. #97
    May 2010
    NRW, Germany
  23. #98
    Feb 2012
    NSW, Australia
    2010 BMW F10 528i
    Nice work! I would like to replace the ribbon on my cluster. Is it a tricky job? The write ups I have found online aren't entirely helpful.
  24. #99
    Aug 2008
    Hesperia, CA
    2001 740 i Sport
    Ran 2 self tapping screws into front and rear of side sill spoilers to get rid the sagging. Feeling good about it
    [/IMG]
  25. #100
    May 2010
    NRW, Germany
    You can choose one of two options. If you have the tool for tacho needle, that's the easiest way. If you don't have the tool, then you need to drill holes trough the front panel as it showed on the pics. It is a bit tricky but it' 5th time to me and every time i did it better.
    http://www.m5board.com/vbulletin/e39...-pictures.html
  1. 2017 what did you do to your e38 today?
    By Jamos in forum 1995 - 2001 (E38)
    Last Post: 01-03-2018, 12:14 AM
  2. 2016 what did you do to your e38 today?
    By 1badturboe38 in forum 1995 - 2001 (E38)
    Last Post: 01-01-2017, 07:03 PM
  3. 2015 What did you do to your E38 today?
    By Mayorchuck in forum 1995 - 2001 (E38)
    Last Post: 01-06-2016, 03:36 PM
  4. 2014 What did you do to your E38 today?
    Last Post: 01-01-2015, 03:13 PM
  5. What did you do to your E38 today???
    By kooljess in forum 1995 - 2001 (E38)
    Last Post: 01-30-2014, 12:28 AM
